Alaskan Impreza Club
Old 10-12-2006, 03:15 PM   #1
12vpro
Member#: 62975
2004 WRX
Default turbo question (gurus plz)
I am curious as to whether or not I may have a serious problem. I noticed the other day that my y pipe from the turbo to the intercooler has a black residue on it. my intercooler also seems to have a light coating of oil in it. very minimal but none the less.
at times, when I autostart it and let it run for more than 15 min, I notice that I get a lot of white smoke, only untill I get going, then the smoke dissapears.
I am curious as to whether this could be the seal between the intake side and the exhaust side of the turbo going bad.
any suggestions?
12vpro is offline   Reply With Quote
Old 10-12-2006, 03:52 PM   #2
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
exh leak...and just "normal" oil blow-by
SQUAD_907 is offline   Reply With Quote
Old 10-12-2006, 05:49 PM   #3
12vpro
Member#: 62975
2004 WRX
ok, so not such a bad thing? dumb question, but how does the oil get in the intake outlet of the turbo?
Old 10-12-2006, 06:16 PM   #4
Alaskan_awd
Member#: 117002
2010 >40psi, oh yes!
POWERSTROKE
I belive it is caused from crank case gasses that are passed through the pcv valve back into the intake.
Alaskan_awd is offline   Reply With Quote
Old 10-12-2006, 06:52 PM   #5
prometheum
Member#: 92003
04 bicycle!
search for oil catch can
prometheum is offline   Reply With Quote
Old 10-12-2006, 08:41 PM   #6
12vpro
Member#: 62975
2004 WRX
^^^^ thats what I thought. I found a catch can system that is completely internal or something and puts the oil back in the oil pan instead of in a can.
Turbo question The Surrey Scooby Newbies & FAQs 0 06-03-2010 04:10 AM
Blow through carb turbo question... any gurus here? markman Off-Topic 40 01-05-2008 12:46 AM
tie-rod locknut question (help plz) sd 05 sti Brakes, Steering & Suspension 10 05-11-2006 10:36 AM
can somebody explain me?? cat/turbo back gurus BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-23-2004 01:54 PM
19 psi on stock turbo??? - Tuning Gurus what gives??? meisnerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 10-03-2003 07:21 AM
