#1 | |
Member#: 1170
BAIC
Vehicle:2005 STi White |
Since Im upgrading to 440cc injectors I would like to control them with something. IIRC the SAFC can only control the MY00+ during WOT (closed-loop I believe). If I'm wrong PLEASE correct me. What I was looking at was the Split Second ARC2. I did a search and found 3 threads that didnt help at all. The ARC2's specs and everything can be seen here:http://www.splitsec.com/products/arc2/arc2ds.htm
SplitSec's overview of the product is as follows: Quote:
And obviously I would want to organize a group buy because of the price. I was also looking at a TMC1. It would be great if we could get a group buy on both pieces going. But first lets discuss the ARC2 and if it would work properly or not.
#2 |
Member#: 168
SCIC
Vehicle:2011 M3 and STI white |
I ran a ARC2 on my RS and it works 100x better than the AFC. If your interested in one, I have a friend that works at SS that can answer some of your questions.
http://albums.photopoint.com/j/Album...6189&f=0&vt=vp |
#3 |
Member#: 1170
BAIC
TMR, I forogt what you used to have...pre00 or post00?
also can you get a discount or find out how low they can go on a group buy? |
#4 |
SCIC
Moderator Member#: 85
SCIC
Ummm Hey Don where are you!!!!!
#5 |
Member#: 1170
BAIC
I called splitsecond up and they told me the ARC1 fits my needs better so I ordered it. They are the only ones I know of that can control the fuel during normal driving and WOT.
#6 |
Member#: 1994
hmm... you're turbo'd, 2000, hmm... But what about that stupid voltage problem? How can you use the ARC1?
#7 |
Member#: 1170
BAIC
i think it acts as a voltage clamp as well. he said it has a map within it that sends a signal. if i ****ed up please tell me so i can call them back and ask them some more questions and/or cancel my order.
#8 |
Member#: 1994
CALL 'EM!! Ask about the MAP Clamp and explain our situation. Hell, I'll call if you want, pass on the number.
#9 |
Member#: 1170
BAIC
#10 |
Member#: 1994
allright, he recommended the ARC1-002 I think was the part number. The person you spoke to wasn't available (Mark), but he's going to call me back so I can pry as much info as possible from him. He said the ARC1-002 has a boost input.
I'll keep you updated. |
#11 |
Member#: 1170
BAIC
Thanks Jewbaru. I really appreciate this.
#12 |
Member#: 1109
Vehicle:1999 Suzuki Samurai Blackish |
I think you'll have to get a 2bar MAP sensor and run it in parallel to use the ARC1. Our MAP is 1 bar only, and since we have to clamp it, the ARC1 will never get a "boost" voltage.
#13 |
Member#: 1994
The way the guy I spoke to made it sound, the ARC1 has a vacuum line that the turbo connects to so it'll see boost, and compensate for it for the ECU.
We'll see when Mark calls me. |
#14 |
Member#: 1109
That's not one the description of the product says. The TMC1 has a built in MAP sensor, though.
#15 |
Member#: 1994
the model number he gave me isn't on their website.
#16 |
Member#: 1170
BAIC
the model number he ordered for me isnt on their site. i think he ordered me the same one Jewbaru is talking about. Its also more expensive (~320). and about the vacuum, i was thinking the same thing you are. he made it sound like there wouldnt be a problem. I hope Mark calls you back.
#17 |
Member#: 1994
he hasn't called yet. If I don't hear from him, I will call him back at around 4:30-5pm my time (CST).
#18 |
Member#: 1994
I talked to Mark a little while ago, I just recently got a chance to post, here's the scoop.
The ARC1-002 works like this: There are two knobs, a low, and a high kindof like how the regular unit is, BUT the knobs work differently. The low knob only works in the minus, so you use it to dial back the mixture if you're running overly rich off boost (like most 2000 owners are). This works up till 0 vacuum. The ARC also has a built in MAP sensor, so when it sees positive pressure, the high knob kicks in. With it, you can adjust fuel delivery, and enrichen/lean out the mixture as needed. Aside from this, the ARC1-002 has a built in clamp, and it can be set to whatever we'd like. Now, in order for the ARC1-002 to work at it's full potential, you'd still need to increase fuel pressure when the car is on boost. Upping the fuel pressure a bit, then using the ARC to fine tune it will yeild the best results. Andrew, I'm gonna e-mail you with some more details and such. I want to be sure to stay in close contact with you in regards to the tuning and such. This sounds like it could be a reliable alternative to the more expensive full engine managment for those who are looking to run reliable low boost. |
#19 |
Member#: 3334
i don't quite understand how this unit works to control fuel after the voltage clamp kicks in. does it control the injectors directly? i seem to be missing something here. anyone have any details on how this unit works with the stock ecu?
#20 |
Member#: 1994
ok, basically, it "scales" the voltage down depending on your settings.
Say N/A at a certain vacuum point, the ECU was seeing 2.8v and adjusting fuel accordingly. What the ARC would do is take that voltage coming in and scale it. So if N/A you saw 2.8v, with the ARC tuned you might see 1.8v. What this would do is offset the car's running rich with a high flow fuel pump, and at the same time give a smooth rise in fuel delivery. The only time it would "clamp" is if you had the HIGH knob turned high enough to where it would max out the voltage at a certain PSI. It intercepts the MAP signal from the sensor, and alters it for the ECU, never going over a set voltage. Does that help? |
#21 |
Member#: 1170
BAIC
Guys, I got some good info that I think you will all be interested in. I'm going to start up a new thread.
| Thread Tools | |
| Display Modes | |
| Split Second arc 2 question? | spgavin | Normally Aspirated Powertrain | 0 | 07-31-2001 01:29 AM |
| Wiring In A Split Second! | spgavin | Normally Aspirated Powertrain | 1 | 06-20-2001 07:45 PM |
| WTB Split Second Timing Controler | SubaFastR | Factory 2.0L Turbo Powertrain | 0 | 05-29-2001 07:53 AM |
| Local Sale: Split Second Boost Guage | Revision | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 02-20-2001 02:06 PM |
| Apex S-AFC or Split Second ARM/ARC-1 | Kyle Paton | Technical Forum Archive | 5 | 08-18-2000 10:58 AM |
