Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 11-07-2001, 03:19 AM   #1
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Default Boost controlers
I've heard that manuel boost controlers don't work well with boost under 10 psi. Is this true? How do they not work well? I want to run 5-8 psi. Thanks.
LVSUBARU is offline   Reply With Quote
Old 11-07-2001, 10:44 AM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Manual boost controlers are designed to work on high boost applications, 12psi or better (IIRC). Using a MBC on a low boost application will (as it has been proven to me) blow you engine.
I had the misfortune of being in AaronB's car when the MBC spiked from 5psi up to 15psi. Not a good thing. Aaron's car still isn't running and the engine blew back in May.
If you want to run 5 to 8 psi, then you don't need a MBC. You can accomplish easily with a properly set wastegate.
kastle is offline   Reply With Quote
Old 11-07-2001, 10:56 AM   #3
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Interesting, especially since I've been running an MBC for well over 2 years. Haven't "blown up" yet.
Steve
http://www.forcefed4.com
SteveS is offline   Reply With Quote
Old 11-07-2001, 12:34 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I'm rather glad that there are people out there who haven't managed to destroy their engines running a MBC with a low boost application. I'm guessing you don't ever mess with it Steve......
Old 11-08-2001, 03:12 AM   #5
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I've been checkin out the kind with the solinoid, so you can have two levels of boost. One is controled by a switch. You guys know which one I mean? What do you think about that? Maybe cruising at 5 psi, and flip the switch ans be at 7 psi.
Old 11-08-2001, 03:13 AM   #6
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Now that I've seen that writen down it seems kinda stupid.
Old 11-08-2001, 11:58 AM   #7
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
It's not stupid, but it's not going to be that easy without some type of smart engine management. Adding a couple of PSI to an already stressed system (i.e. S-AFC + RRFPR) might be disastrous. But if you had some type of decent engine management system (TEC-II, Haltech, etc.), doing something like this should be possible. As long as the system could realize the different boost level and deal with it appropriately, having a "moderate" and "high" boost option would be really great.
Steve
FS : Turbo XS Manual Boost Controller NIB jsharp2280 Engine/Power/Exhaust 13 09-20-2010 08:03 PM
WTS: Winterforce tires and TurboXS Boost Controller jouka NESIC Private Classifieds 11 06-17-2010 06:05 PM
UTEC Boost control as good or better than other boost controllers? DocDetroit Engine Management & Tuning 0 02-04-2003 10:40 PM
Manual boost controller vs Digital boost controler ScoobieSnacks Bay Area Impreza Club Forum -- BAIC 27 02-17-2002 06:28 PM
