Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 11-06-2006, 02:26 AM   #26
narenji
Member#: 12727
Its got internal
combustion ftw!
did the following today; sti tmic, injen short ram intake, jdm sti uppipe, invidia catless downpipe... had a few issues...
i had a one piece header uppipe, like this one;
and i couldnt get it to fit- the crossmember has less room than a wrx one- also, i think to get this type of header to fit, you have to really get your motor high- jack it up directly, possibly remove motor mounts as well.
since i had the jdm sti uppipe, i just put that on. its catless (my intention behind doing the uppipe), and it fit fine.
the downpipe was another issue- the brace was in the way, and instead of notching the brace or the downpipe, i just removed it- i intend on putting a strut tower brace, so hopefully it compensates for the brace i removed. a non-bellmouth downpipe may have fit... any tips on getting the brace back in there?
i also have a leak between the downpipe and the catback- shouldnt be too difficult to fix.
performance wise, it definitely feels better... the car only seems to make about 11 lbs boost- im going to keep an eye on it w/ my accessport (that i have for my sti, but it'll read boost b/c the baja doesnt have a gauge)...
narenji is offline   Reply With Quote
Old 11-06-2006, 11:34 AM   #27
downhilbil
Member#: 74675
2005 subaru BAJA T
blue
cool will be looking at updates when its all working well im doing a few things myself but just a downpipe and a ecutek reflash .
downhilbil is offline   Reply With Quote
Old 11-06-2006, 12:18 PM   #28
narenji
Member#: 12727
Its got internal
combustion ftw!
you should do uppipe as well- the cat may eventually break loose- ive seen it on my friends 04 wrx uppipe- part of the material was coming apart- he replaced the pipe at the right time- otherwise turbo would be destroyed.
uppipe is a little bit of a pain, if you can find someone to do it for 100 bucks or so, its worth it. anything over that ill do it myself.
honestly, if i knew from the start that that header wouldn't fit, it would've taken me less time.
Old 11-06-2006, 05:45 PM   #29
Hawk296
Member#: 14555
1995 Impreza L
Baja
lol wow, jdm sti uppipe must be waaaay better than my usdm sti uppipe!
Hawk296 is offline   Reply With Quote
Old 11-06-2006, 06:39 PM   #30
downhilbil
Member#: 74675
2005 subaru BAJA T
blue
is one catted and one not?
Old 11-06-2006, 08:33 PM   #31
Hawk296
Member#: 14555
1995 Impreza L
Baja
I was just messing around. The JDM sti one and USDM sti are both catless and look identicle. I was joking at the fact he specifically mentioned its JDM, cause we all know JDM makes it waaay more betterer!
However the USDM 2002-2005 WRX (non sti) as well as FXT and all Baja T do have the precat and EGT probe in the uppipe. So switching to an STI or Bosal (same as STi) uppipe eliminates this pre-cat.
Old 11-06-2006, 09:08 PM   #32
narenji
Member#: 12727
Its got internal
combustion ftw!
well the jdm pipe is the same as the usdm, save for the egt bung. the jdm doesnt have one... no big deal- i mentioned that it was jdm not b/c its cooler, but for completeness of info... ive got a mad leak somewhere in the right header side... the downpipe-catback leak is fixed...
im still debating the brace... apparently, turboxs downpipes, even though they are large fit without removal of brace... other downpipes may be hit or miss... bajasti04 has a perrin catted downpipe.. dont know if he removed the brace to make it fit.
Old 11-06-2006, 09:15 PM   #33
Hawk296
Member#: 14555
1995 Impreza L
Baja
Yeah i was just joking around, nothign aimed at you. USDM sti up pipe also does not have EGT bung.
I am running an Oakos downpipe, It fits perfect with the brace in there but it is not a divoriced or bellmouth. Just catless.
Old 11-06-2006, 10:51 PM   #34
downhilbil
Member#: 74675
2005 subaru BAJA T
blue
any probs with the catless like CEL's
Old 11-06-2006, 11:05 PM   #35
Hawk296
Member#: 14555
1995 Impreza L
Baja
with the catless uppipe and downpipe the cat efficiency below threshold (P0420 I think??) came on after about 250 miles.
I just went into the ecu and turned that particular code off (I had already shut off EGT CELs since i removed the sensor with the uppipe install) No other CEL since.
Old 11-06-2006, 11:15 PM   #36
downhilbil
Member#: 74675
2005 subaru BAJA T
blue
what EM do you have?
Old 11-06-2006, 11:23 PM   #37
Hawk296
Member#: 14555
1995 Impreza L
Baja
I just use the opensource tools to reflash the oem denso unit. Usually Enginuity to edit.
see my response on scoobytruck for more info..http://scoobytruck.com/bb/viewtopic.php?t=744
Old 11-07-2006, 01:12 AM   #38
narenji
Member#: 12727
Its got internal
combustion ftw!
cool so the oakos downpipe fits... i think im going to make a compendium of what works...
so far:
turboxs
oakos downpipe... the exhaust shop that fixed the leak wanted to cut the brace to make it fit, but i didnt want to do that... im going to try to get my hands on either one above...
on second thought, i got my invidia for 100 bucks, im going to modify it to fit... will report once done.
Old 11-07-2006, 05:41 PM   #39
Hawk296
Member#: 14555
1995 Impreza L
Baja
Pic of the Oakos clearance...
I got the Oakos because i thought it would fit, it was cheap, and they are local to me.
I was very suprised on how well it fit. both flanges and mount to the trans fit perfectly, no tweaking needed. And it cleared the brace.
Old 11-22-2006, 06:42 PM   #40
BajaSTI04
Member#: 121071
2004 Baja STi
TeamJDMFresh.com/CSJ
Default ram air and guages and debadged
BajaSTI04 is offline   Reply With Quote
Old 11-26-2006, 09:45 PM   #41
peiboy
Member#: 127594
2003 Baja
My 03 - washed and ready for winter.
New wheels, Sirius Radio, my pencil box volt meter (soon to be Air Fuel too), Kenwood Stereo, Neo Car Jukebox and a two way remote start.
http://jonathan.macwilliams.googlepages.com/mybaja
peiboy is offline   Reply With Quote
Old 11-26-2006, 10:18 PM   #42
WRXtr26
Member#: 112104
2004 Baja Turbo 4eat
04 Baja Turbo
MODS: Exterior(Painted Front Grill, Cleared Headlights, Painted Calipers) Interior(Belltronics Radar Detector, Boost Guage) Suspension/Wheels/Tires/Brakes(Ion Performance 2.3" Sport Springs, Hawk HPS Brake Pads, 17" by 7.5" Gold Rota D2's, Kumho ASX 235/50/17, Resurfaced Rotors) Engine(NGK Iridium One Step Colder Plugs, Perrin Short Ram Intake, Perrin Inlet Hose, Samco Intercooler Hoses, XS Turbo TMIC, HKS Uppipe, Sti BOV, Custom sillicon recirculating hose, Turbo XS Downpipe, Custom Catless 3" Exhaust, Walbro 255, Perrin Modded Injectors, TD05 16g w/ upgraded wheel, Ecutek tuned) Transmission(Hayden External Tranny Cooler)
COMING THIS WINTER: PTS Valve Body Upgrade, UR Uppipe, Tial 38mm ewg, and new turbo(sz49 or garrett gt30-12)
WRXtr26 is offline   Reply With Quote
Old 11-27-2006, 12:47 AM   #43
narenji
Member#: 12727
Its got internal
combustion ftw!
lookin nice... what injector size on your 16g?
Old 11-27-2006, 10:50 AM   #44
BajaSTI04
Member#: 121071
2004 Baja STi
nice lookin bajas people thanks for sharing!
Old 11-27-2006, 05:35 PM   #45
Hawk296
Member#: 14555
1995 Impreza L
Baja
Well he said Perrin, so if they are the modified stock injectors I think Perrin advertises them at 816cc
Old 11-27-2006, 05:51 PM   #46
baja03
Member#: 83018
2003 Baja
dark blue
Originally Posted by bflowrx View Post
Did full under belly skid plate and have the subaru rear diff plate.Custome light bar upfront,Custom short ram air intake, and a set of P zero gravel tires on a set of speedline wheels.The tire set up that day was perfect but I loved all of the low end grunt I had from runing 15 inch wheels on the car just wish I could run it with out the extra high revs on the thruway.
That bar looks good on the Baja what kind of mods did you have to do to install the bar?
baja03 is offline   Reply With Quote
Old 11-27-2006, 05:55 PM   #47
baja03
Member#: 83018
2003 Baja
dark blue
these are some nice mods on my 03 i just have the ssi skidplate, 05 springs, rear diff. skidplate, some 215/70R16 tires and some hella lights installed on the roof bar and 2 shackles on the rear hidden hitch.
Old 12-30-2006, 11:31 PM   #48
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
Ive got a VF-39, JDM STI tmic, helix uppipe, xcceleration tbe, perrin lightened crank pulley, gpmoto sri, ecutek tuned ecu, walbro fuel pump, perric mbc. Soon to get a retune following a turbo inlet hose, perrin equal length headers, fuel rails.... and maybe new 860cc injectors, rr500 turbo, and fmic. anyone interested in my tmic and vf-39 if i get new stuff? also, does anyone know of anyone else (besides tony rigoli) that has done a fmic install in our baja's?
cliffhanger is offline   Reply With Quote
Old 12-31-2006, 09:47 AM   #49
wrenchwoman
Member#: 126445
2004 Turbo Baja
Obsidian Black/Gray
Who makes that header? I want headers next, but want to get ones that fit and I don't want to order the same one you got if it won't fit.
wrenchwoman is offline   Reply With Quote
Old 12-31-2006, 09:47 AM   #50
wrenchwoman
Member#: 126445
2004 Turbo Baja
Obsidian Black/Gray
double post
Up to date pics & mods edoublepo Member's Car Gallery 4 10-09-2006 08:48 PM
Modded PStwo (slim) & Modded Gamecube llhype12ll Private 'For Sale' Classifieds 2 11-15-2005 01:28 PM
couple of pics & mods list WRX Ver.7 Member's Car Gallery 15 08-01-2002 01:40 PM
How to change pics & mods? mav1c Mid Atlantic Impreza Club -- MAIC 6 08-28-2001 12:51 PM
STI 3 Pics & 340HP Mods Hyperex Member's Car Gallery 38 07-06-2001 06:20 PM
