Old 10-13-2006, 03:37 PM   #1
seattleswimboy
Member#: 111804
2006 STI
Question STI short throw linkage with Kartboy shift lever?
Hello all,
My 06 STI came from the dealer with the STI short throw shifter. Since the STI one changes the linkage, can I use the Kartboy shift lever with the different linkage? If so, can I also use the Kartboy bushings with the STI linkage to improve feel or is it even necessary?
Thank you,
Evan
seattleswimboy is offline   Reply With Quote
Old 10-13-2006, 03:42 PM   #2
spritefiend
Member#: 101190
2016 WRX Limited
my sti came with the sti short shifter too, and i recently changed it out to the kartboy with both the front & rear bushings. it is definitely noticable, mostly from the bushings;
i COULD be wrong, but i believe the kb shifter is slightly shorter than the sti shifter too.
John.
spritefiend is offline   Reply With Quote
Old 10-13-2006, 04:00 PM   #3
Member#: 67
1999 Outlasting
the competition.
Hi Guys
the linkage is the same on the 6 Speeds. you can use our shifter with great results. FYI the STI "Short" shifter is only a 10%reduction over stock. ours is about 40%.
Tom
FS NJ: STi Shifter Kit, STi Short Throw Shifter Lever, Linkage, Trans Mount SupraToWRX Drivetrain 32 02-27-2009 01:07 PM
Kartboy Shift lever for STi/SPT factory short throw linkage JBravo920 Drivetrain 9 05-04-2008 05:28 PM
FS/WTT-WRX 5-Speed Short-throw Shifter with KartBoy Bushings ScoobyNubieToo! Drivetrain 7 03-26-2007 10:15 PM
Aftermarket Short Throw lever with STI short throw shifter? anti.team Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-24-2004 12:57 PM
('93-'01) STI short-throw shifter vs. Kartboy? Verdict? bryant aka sky Impreza Forum 15 08-09-2001 08:36 AM
