Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 10-13-2006, 04:22 PM   #1
isk8drugfree
Member#: 119822
2003 WRX
Sonic Yellow
Default Caliper won't come off of rotor HELP!!
We are trying to install some new rotors and pads on my friends wrx. His stock rotors are worn down and there is a lip on the outter edge of the rotor. Does anyone know what to do to get it off? Thanks
isk8drugfree is offline   Reply With Quote
Old 10-13-2006, 04:24 PM   #2
ekw
Member#: 92141
2004 loaner
Acura or diesel truck
1) is the emergency brake on?
2) can you get between the pads w/ something and gently pry them apart?
ekw is offline   Reply With Quote
Old 10-13-2006, 04:53 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
If you open the bleeder a little it should make it much easier to push the pad/piston back to clear the lip. You will have to do a proper air bleed once you're done.
UkNuck is offline   Reply With Quote
Old 10-13-2006, 05:21 PM   #4
kaisersouse
Member#: 85900
2001 Forester S
usually you can rotate the caliper down and it slides off the pads themselves (which end up falling to the ground)
And e-brake being on would only affect if it were the a) rears and b) he was trying to take the rotor off
kaisersouse is offline   Reply With Quote
Old 10-13-2006, 05:27 PM   #5
jasonallenross
Member#: 125978
2002 WRX Wagon
Default since you are replacing both the pad and rotor
take the cap off the master cylinder.
slide a screwdriver in between the pad and the rotor. You should be able to push the pad out, using the rotor surface as a leverage point.
You'll be doing similar work later in the job anyway, when you use a clamp and the old pad to push the pots back into the caliper.
If that doesn't work, opening the bleeder should do it but then you might as well change the brake fluid too.
jasonallenross is offline   Reply With Quote
Old 10-13-2006, 05:27 PM   #6
rkramer
Member#: 118209
2015 WRX Limitec
having the ebrake on will keep some pressure in the entire braking system, making it nearly impossible to get the front pads off. (i didn't believe it either until you see it happen firsthand)
Old 10-13-2006, 05:29 PM   #7
kaisersouse
Member#: 85900
2001 Forester S
no **** seriously? Thats...odd hahaha
Old 10-13-2006, 06:54 PM   #8
Hondaslayer
think you
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Especially considering that the handbrake is a cable actuated drum within the rear rotor that has absolutely no bearing on the hydraulic system whatsoever........
Old 10-13-2006, 07:13 PM   #9
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
So I've been doing it wrong all those times?
jac04 is offline   Reply With Quote
Old 10-13-2006, 08:15 PM   #10
isk8drugfree
Member#: 119822
2003 WRX
Sonic Yellow
Lol. Hey thanks for all the responses guys...We finally figured out how to do it. I'd describe it but I don't think you'd understand unless you saw it lol. Thanks again =)
rear rotor won't come off? 02 wrx cleans13 Brakes, Steering & Suspension 9 11-10-2009 08:47 AM
06 STI Front Brembo caliper won't come off, halp! WRXdonkey Off-Topic 17 04-13-2008 07:57 PM
followed all steps. engine won't come off!!! help!!??!?!?!!?? MrSaabaru Subaru Conversions 18 08-12-2005 01:58 AM
HELP! My wheel won't come off the hub! RightyTighty Tire & Wheel 9 12-05-2004 06:45 PM
Cap bolt just won't come off!! Need help! scooby5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-08-2001 12:25 AM
