Old 11-07-2001, 10:54 AM   #1
Mister Toro
Member#: 9792
04 Blackwing
Without the Wing
Question Different Power Steering Problem?
I have 2300 miles on the clock and have had 3 occurances of the following:
Moving from a stopped position (or moving VERY slowly out of a parking space), I happen to be letting the clutch out after a 1-R or R-1 shift while turning the steering wheel. For about 1/2 second I get a loud noise some where between a groan and a honk, and a moment of stiffness in the wheel.
If feels like the PS pump is being swamped or something. My reservoir is full, so fluid loss isn't the culprit. It has only happened to me and not my wife, and on occasions 300-400 miles apart. Could this be my driving style, or is this something others are seeing?
Mister Toro is offline   Reply With Quote
Old 11-07-2001, 03:02 PM   #2
Corpsie
Member#: 10502
'04 Ford Ranger 4x4
Red Metallic
perhaps it is a belt slipping?
Corpsie is offline   Reply With Quote
Old 11-08-2001, 10:55 AM   #3
Mister Toro
Member#: 9792
04 Blackwing
Without the Wing
I don't really think it is the belt. This noise is LOUD and nothing like normal belt squeal (not pitched as high). It sounds hydraulic like really noisy plumbing, but again nothing like a relief valve opening when you put your front wheels on a lock. It's just a short loud 'HONK!!!' that shakes the car and scares everyone inside. Any ideas? Anyone?
BTW, I am not sure if this post belongs in the General Forum or here.
Old 11-08-2001, 07:52 PM   #4
Corpsie
Member#: 10502
'04 Ford Ranger 4x4
Red Metallic
shakes the car?
maybe an air bubble in the PS fluid?
I'm just tossing up ideas until someone smart says something.
Old 11-08-2001, 10:06 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
This could be normal. According to the service manual:
[The power steering] oil pump makes whine or growl noise slightly due to its mechanism. Even if the noise can be heard when steering wheel is turned at stand still there is no abnormal function in the system provided that the noise eliminates when the vehicle is running.
Jon [in CT] is offline   Reply With Quote
Power Steering problem ZMANNH25rs Brakes, Steering & Suspension 9 04-30-2002 05:30 PM
Power steering problem Br0kWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-17-2002 01:13 PM
Power steering problem subix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2002 01:28 AM
Power steering problem ZMANNH25rs Warranty Issues & SOA Problems 4 10-17-2001 11:39 AM
Power steering problem? psoper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-08-2001 08:07 PM
