Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 11-07-2001, 11:22 AM   #1
SCOOTAE
Member#: 10735
1995 2.2L COUPE
BRIGHT ASS RED
Default Wont start AFTER it is warmed up.
Lets see if anyone can help. In the morning my car starts right up, no problem, but after i have driven for a while and turn off the car,I will leave it for about 15 min or longer and when i come back i have to turn it over for like 9 seconds let it sit and do it again, then it starts up very hesitantly.It even does this if I turn the key to the on position and let the car chime for a couple of seconds.
Let me tell you I have already checked for a vacuum leak,none.
I installed new plugs properly gapped and new wires, cleaned my injectors, I use 92 octane gas, installed new fuel filter, and I am pulling no codes. If anyone can offer any helpful suggestions I would very much appreciate it, THNX
SCOOTAE is offline   Reply With Quote
Old 11-07-2001, 12:28 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
You get a sulphur/ rich smelling exhaust when you start it up warm?
Midwayman is offline   Reply With Quote
Old 11-07-2001, 01:31 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sounds like it's got an fuel bleed problem.
Jeremy
Old 11-07-2001, 05:20 PM   #4
SCOOTAE
Member#: 10735
1995 2.2L COUPE
BRIGHT ASS RED
Default I checked
the sulphur smell idea and its a, no.
By fuel bleed problem you mean what,It might be leaking somewhere?
any one else?
Scott
Old 11-07-2001, 05:31 PM   #5
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Could your engine be flooded due to a leaky fuel injector? Next time when you try to start your car after a trip, try pressing the gas pedal to the floor while cranking the engine.
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 11-08-2001, 02:16 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yes i was reffering to an injector leaking. Also have you had any overheating problems??
jeremy
Old 11-08-2001, 12:26 PM   #7
SCOOTAE
Member#: 10735
1995 2.2L COUPE
BRIGHT ASS RED
Post
Fortunatley I have never overheated,but it does sound like it could be a leaky injector so how do i go about fixing this?
do I buy new seals or do I have to get new injectors?
Thnx
Scott
Old 11-08-2001, 12:33 PM   #8
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
If it's really injector, I would try to determine which one is defective, and then replace just that one.
It could also be your starter getting heat soaked.
Richard
Old 11-09-2001, 06:47 PM   #9
SCOOTAE
Member#: 10735
1995 2.2L COUPE
BRIGHT ASS RED
Unhappy
This might sound dumb, but since I dont know, how would one go about finding the defective injector. What would I do to test this?
TIA
Scott
Old 11-09-2001, 08:42 PM   #10
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
You can have all the injectors removed and flow tested. If an injector fails the test, then you will know that it's bad.
Richard
Old 11-10-2001, 11:36 AM   #11
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
could be a possible cam or crank sensor
dave
PerformanceAutoSolutions is offline   Reply With Quote
Old 11-10-2001, 03:16 PM   #12
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I wouldn;t replace just the one. Always replace all injectors at the same time if you are going to replace them
Eric
Eric SS is offline   Reply With Quote
Old 11-11-2001, 12:42 AM   #13
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Sounds more like a sensor than a fuel injector to me. Thats just my .02.
Garret
Ghomer1 is offline   Reply With Quote
Old 11-11-2001, 03:21 AM   #14
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I'm an auto tech and I have seen this caused by a bad crank sensor that fails when hot. But the more likely cause is the fuel pressure regulator. The rubber diaphram inside leaks and when you crank the motor the fuel floods the motor via manifold vacumn. Find yourself a hand vacumn pump, and with the car off, pump the vacumn port on the FPR down. If you get fuel, it's leaking. I see it all the, especially in hot climates. It takes five minutes to change out. I'd check it out before pulling all the injectors! sometimes when there leaking bad enough you can just pull the vacumn hose off and see, and smell fuel come out.
LVSUBARU is offline   Reply With Quote
Mechanical Engine Knock After Car Is Warmed Up buzz313th Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-26-2013 09:10 AM
is warming up the car from a cold start a must? LapTak Newbies & FAQs 18 10-12-2008 02:16 PM
sti wont start when engine is warm RichWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-09-2006 05:54 PM
Car wont start after tank fill up!! SSsleeper96 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-22-2005 10:05 AM
car wont start after warmed up?? gotawd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 12-20-2005 06:26 PM
