Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 11-07-2001, 01:14 PM   #1
scoobywanted
Member#: 10118
1991 Pimpssan
****ra
Talking 15-30psi turbo kit...
I started the best engine yet thread and finalized on my decision. I will be buying a 99-00 2.5rs, and will be looking for extremely high boost applications. My question to you is...What is the recommended turbo kit that will get me EFFICIENTLY make 15psi-30psi? I don't want a segnificant lag on the turbo, but realize one must make sacrafices for higher boosts. I also stumbled upon a website that had almost everything immaginable for the 2.5rs on their online shopping cart. I have somehow lost this adress and was wondering if it sounded familiar to anyone here.
scoobywanted is offline   Reply With Quote
Old 11-07-2001, 01:18 PM   #2
Jewbaru
Member#: 1994
2013 Impreza WRX
my suggestion, Vishnu. You'll need a custom turbo prolly, but you WANT engine managment. Custom as in a different turbo than they give you.
Anyway, why 99? 2000s have the rear LSD, and you're gonna need new pistons anyway. If you get the TEC II, you won't have to worry about the MAP Sensor.
Jewbaru is offline   Reply With Quote
Old 11-07-2001, 01:50 PM   #3
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Maybe you were thinking of Graham Goode as the website?
You could probably get a ball-bearing turbo to help spool-up.
iodine23 is offline   Reply With Quote
Old 11-07-2001, 02:16 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I'm with Jewbaru on this for the most part. The key pieces will be a good turbo setup (either Vishnu or Forced Air Tech), a strong tranny & clutch setup, engine management (TEC-II) and a built engine (pistons, valves, springs).
Make sure you have plenty of money because your looking at needing to spend around 12k for that setup.
kastle is offline   Reply With Quote
Old 11-07-2001, 05:07 PM   #5
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
didn't we just have this discussion? psi in terms of what??? maybe you should thinking in terms of power instead of psi... psi really is not relevant without turbo sizing and other factors... front mount? etc etc...
"...started best engine thread yet..." hehehehehe n00b
HOK is offline   Reply With Quote
Old 11-07-2001, 06:55 PM   #6
scoobywanted
Member#: 10118
1991 Pimpssan
****ra
Default HOK,
you are always triing to bust my balls on this aren't you . Okay then i want to have a car capable of producing 500 hp. I figure it will take me about 28-30 psi to get me there.
"Maybe you were thinking of Graham Goode as the website?"
Thanks. That isn't the same website but it will work.
Old 11-07-2001, 07:07 PM   #7
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
If you want to know what it'll take to get that 500hp, check this link...
http://www.turbofast.com.au/tfcalc.html
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 11-07-2001, 08:11 PM   #8
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Vishnu or Technik Motorwerks.
You're going to have to run a standalone engine management system.
Bring your wallet.
Keiho is offline   Reply With Quote
Old 11-07-2001, 08:55 PM   #9
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
Hmmm, so with Vishu turbo kit, TEC-II, and maybe a boost of 10psi, will be sufficient to get me to 250-280hps range? Of coz clutch/flywheel need to be changed. If so, I'll imagine 250-80 to the wheel or flywheel?
I considered the power output and speed factor more...so if a 5psi on Impreza will make the same power, I'll take it! Of coz the lag must not be too outrageous.
-Benson (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
Old 11-07-2001, 09:06 PM   #10
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
With the right injectors along with the parts you list you can have over 300hp to the wheels on pump gas. For 500hp, you won't be able to use stock internals, period.
Ben
bsquare is offline   Reply With Quote
Old 11-07-2001, 10:29 PM   #11
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Don't forget the much needed stronger tranny.... A lot of people who run over 7psi end up needing new gears.
Old 11-07-2001, 10:53 PM   #12
Joe Hogan
Member#: 699
2002 golf TDI
A conservatively tuned Vishnu kit [the old style using a Minnam type setup] will produce about 325hp at the crank at 10 psi. About 250hp at the wheels. The "new" kit is expected to be much more effiecient due to optimized up/down pipes and turbo design.
That is about the numbers the MY99RS-t that I drive everyday makes as per a Dynojet. You can expect better than this with the new Vishnu kit.
If the car is used daily and run hard be warned that higher power levels youwill be doing major R&D engineering throughout the drivetrain. If you don't have "the wallet" and facilities you may want to rethink your 500 hp goals..
You can have a very fun and safe 7-9 psi car that is otherwise mostly stock that can be driven hard everyday. Many guys are doing this with proper tuning and electronics ie TECII etc. These cars are plenty fast.
Just my $.02
Joe Hogan
Joe Hogan is offline   Reply With Quote
Old 11-08-2001, 01:28 AM   #13
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Default scoobywanted...
No way man... i'm trying to help... see when you quoted power look at all those responses... and good ones too...
you should thank me hhheehehehe
Old 11-08-2001, 03:23 AM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
hope you are ready to take out a loan.
Jeremy
Old 11-08-2001, 09:31 AM   #15
GGrahnVI
Member#: 7190
What do you plan on doing with the block after you have blow the cylinder walls apart into little teeny tiny pices? You know it IS an open deck block. Resleeving it will never work for a street application unless you have it resleeved in such a way as to make it a closed deck block. And i do not believe that make sleeves like that for a 2.5 engine.
30psi is un-reasonable on that block. 15psi is do able with aftermarket internals. At 18psi I believe you would be at THE limit of the factory block.
That being said - Get cheap and get a 95 two door. Then go to an engine importer and buy a 22b engine. You have just paid less for the engine and car then you would have for the original intented RS. On top of that, you can run 25 or so psi on the 22b engine with correct fuel and tuning.
My 2 cents ...
GGrahnVI is offline   Reply With Quote
Old 11-08-2001, 09:58 AM   #16
Bahumut
Member#: 460
1995 Impreza Wagon
Brilliant Red/Slade
you can't buy a 22b engine.
Bahumut is offline   Reply With Quote
Old 11-08-2001, 10:58 AM   #17
63Alpine
Member#: 865
2003 BMW M3
Phoenix Yellow
What everyone seems to forget when they go down this path is that a car is an integrated system. Even if you manage to get 500HP out of the 2.5, you are faced with the problem of not destroying the rest of the car.
In addition to spending the $10K+ to build up the engine you are looking at:
Clutch replacement - $500
Transmission buildup - $5,000 - $7,000
Hard bushings throughout - $2,000 - $3,000
Axle replacement - no clue, I haven't done it yet
Three differential replacements - $3,000 - $5,000
Body kit to add wider tires - $2,000
Brake replacement - $3,000 - $5,000
Suspension replacement - $2,000 - $3,000
Rear hub replacemnt - $1,500 - $2,000
So like everyone said, I hope you have a deep wallet. This is exactly what I am going through. I have a $50,000+ MY2K Impreza sitting at Vermont SportsCar right now and it is only putting out 300+ HP.
Kurt
63Alpine is offline   Reply With Quote
Old 11-08-2001, 11:02 AM   #18
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
is there even a block out there made to handle 30 psi? even in concept cars i dont think they try that. maybe the quad turboed w16 vw thing.
as for the tranny for a 500 hp rs your looking at a custom made race tranny. i dont think theres one out there made to handle the torque that comes along with that power
Old 11-08-2001, 11:22 AM   #19
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
hollinger dogbox....but hte gearset alone cost about 8g's...IIRC
Jeremy
Old 11-08-2001, 11:38 AM   #20
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
Some guys out in Cali run up to 48psi on a VR6 block in their drag car, which ran 7.8ish in the 1320. That's a closed deck block, though... Hey Kurt, do you need a pool boy or something?
RyanC is offline   Reply With Quote
Old 11-08-2001, 11:45 AM   #21
63Alpine
Member#: 865
2003 BMW M3
Phoenix Yellow
Sorry, I had to sell the pool to pay for the brakes on the car. Trust me I didn't start out wanting to put all that money into my car.
I beefed up the HP so I needed a new clutch, the new clutch made me have to replace the tranny. The tranny caused the bushings to start squirming around on shifts making parts bang around. I can go really fast now! Oops, I can't stop! Aggghh I need brakes, and so on.
Kurt
Old 11-08-2001, 11:51 AM   #22
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
If you want those HP numbers, and that much boost, you're gonna need a:
closed deck block
lower CR pistons
dual valve spring set up
stronger rods
Stand Alone ECU
FMIC
BB turbo (big one at that)
bigger radiator
huge injectors
a WRC tranny to handle the power
4 pot front brakes
water injection system
and much much more...
STiShawn is offline   Reply With Quote
Old 11-08-2001, 02:11 PM   #23
scoobywanted
Member#: 10118
1991 Pimpssan
****ra
Default okay what the hell...
is all this talk about the ej25 not being able hold all that power. If you go to the factory forced induction forum and look for the thread titled best subaru engine yet? and you will see that they recmmend all different kinds of engines and i chose the ej25. I do have a dep wallet, and many of you are lookingover the fact that subaru is not FORD. They are alot stronger than you think they are. I need some good quality suggestions on which tranny i should get top handle all this power. Same thing with the clutch. Hum how about the axles, and so on. Please just don't tell me what i need without triing to pusjh me in the right direction. names, and websites are alway a big help to me.
Old 11-08-2001, 02:40 PM   #24
totoherbs
Member#: 7321
.... 122 IggPoints
well mr deepwallet go with a closed deck thats a must. and for trany hollinger dogbox, act race clutch, carbon drive shaft. probly have to do something with the diffs
Old 11-08-2001, 05:15 PM   #25
bsquare
Member#: 1911
2000 Impreza 2.5RS
Why is anyone taking scoobywanted seriously? He doesn't understand what you are telling him.
Could someone provide evidence that an open deck motor can't handle high boost? I've seen theory and conjecture, but no proof.
Ben
Ft: So Cal: Gt35r .82 Ar Turbo Kit For Stock Location Turbo Kit EvO KiLLeR 2005 Engine/Power/Exhaust 4 06-02-2008 02:21 PM
AVO Turbo Kit vs TSI Turbo Kit Mechkiller31st Normally Aspirated with bolt-on Forced Induction Powertrain 6 12-01-2004 08:02 PM
Wanted: Turbo Kits or Turbo Kit Parts Acejam2k Private 'Wanted' Classifieds 1 01-05-2004 02:34 PM
Attn:Legacy turbo kit drivers, didnt someone do the kit w/out changing the water pump scootr Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-03-2004 04:56 PM
pic of old turbo kit vs. new custom kit zaidallas Member's Car Gallery 15 06-12-2001 06:56 PM
