10-15-2006, 08:43 AM | #1 |
Member#: 65267
Vehicle:2002 WRX Silver |
Gear Dependent Boost Trim
I wasn't able to find much info on this.
I am using the Hydra to control the boost w/ a Perrin EBCS. The car has a road tune by Phil. None of the gear boost trims have any values in them and I am seeing lower boost in 1st and 2nd as they are lower load gears. Are the values in the gear boost trim fields always negative?
10-16-2006, 08:43 AM | #2 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
How to set the gear based compensation maps is in your user manual. You will first need to setup the gear ratios before you can use the boost trims. You will need to add duty to the lower gears and reduce duty in the higher gears.
Thanks, Phil www.elementtuning.com |
Socal: Turbo XS DTEC-BCFC gear dependent boost control and fuel controller | methaddict | Engine/Power/Exhaust | 40 | 10-31-2009 03:38 PM |
'06 WRX AP Stg1 3rd gear datalog...boost OK? | Airboy | AccessPort | 0 | 07-08-2006 02:40 AM |
anyone tuned for running gear-mapped boost? | erggy | Engine Management & Tuning | 0 | 04-17-2005 07:38 AM |
Low RPMs + High Gear + High Boost = Detonation? | Hagwag02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 08-25-2004 07:46 PM |
2nd Gear... uhh... boost leak? | AdmireWantWillLove | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 10-15-2003 12:59 AM |
