Old 10-15-2006, 01:11 PM   #1
airspeed
Member#: 47919
2002 wrx
blue
Default Over Boosting after vishnu reflash, ???
Anyone experience overboosting after Vishnu ecu reflash. I did the V350 reflash with pinks and VF34 however i have been boosting to 1.4 bar (19.5)psi.
I have a Bosal 2.5" divorced Downpipe and Vishnu advised I need to change downpipe to 3" Bellmouth to correct the overboost condition.
Has anyone had this experience as I would hate to buy a new downpipe and not solve the overboostong problem.
feedback please
airspeed is offline   Reply With Quote
Old 10-15-2006, 01:35 PM   #2
cbean
Member#: 57387
02 wrxwagon
I have recently gone to a vishnu reflash, not the stage 2 like you but the subzero...When I put the reflash in I had also changed out all of the hose's to the turbo and wastegate sensor...The hose's I replaced the OEM with were regular KRAGEN auto parts store vac hoses...they were larger then OEM, just by mm but larger non the less...this minor change was giving me 18.5 / 19 lbs of boost...I replaced those hose's with the spec sizes and everything is normal now...Hope this helps
cbean is offline   Reply With Quote
Old 10-15-2006, 01:39 PM   #3
airspeed
Member#: 47919
2002 wrx
blue
Thanks for the feedback, I used all the hoses from the VF34 turbo and all other stock hoses with the boost solenoid. Vishnu claims the downpipe is the problem. I am very curious if anyone has seen boost levels fall due to a large diameter downpipe. A 3" downpipe will cost $300 + AND THIS IS A LOT IF IT DOES NOT SOLVE THE PROBLEM
Old 10-15-2006, 01:41 PM   #4
AKESREX
Member#: 110401
P silver -original owner
How's that Subzero working? Ready for the next level
Sorry for hijacking the thread......
AKESREX is offline   Reply With Quote
Old 10-15-2006, 02:11 PM   #5
airspeed
Member#: 47919
2002 wrx
blue
Dont have the subzero however their reflash is amazing in terms of power and throttle response. If I was not overboosting I would say the reflash is PERFECT
Old 10-15-2006, 09:24 PM   #6
AKESREX
Member#: 110401
Sorry, it was just my smart aleck to cbean.
I sold him his subzero ECU.......
Old 10-26-2006, 03:14 PM   #7
dust12
Member#: 13417
If you live near Vishnu I would suggest taking a drive over there and letting Shiv take a look at it. Most of the time it is the vacuum hoses (T or pill).
dust12 is offline   Reply With Quote
Old 10-27-2006, 12:33 AM   #8
airspeed
Member#: 47919
2002 wrx
blue
I live in Miami, I actually changed the DP and this did not fix the problem. I opened the diameter of the restrictor pill in the T hoses from the turbo and used a ABC from turbo XS to fine tune the boost.
Seems to be holding 17.5psi throughout the shifts now.
Is a boost reduction possible after a reflash? Rumplemenz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-15-2007 09:15 PM
Slight over boost after fluid change? epson1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-25-2007 10:38 AM
Jerky acceleration after Vishnu reflash other1lost Service & Maintenance 8 10-13-2004 11:57 PM
Vishnu reflash, how much boost? tucker63 Engine Management & Tuning 11 11-19-2003 05:17 PM
Hesitation and Low Boost After ECU Reflash bobski Warranty Issues & SOA Problems 11 03-27-2002 02:18 PM
