Old 10-15-2006, 11:01 PM   #1
mikea322
Member#: 112314
2002 wrx wagon
platinum silver
Default factory ECU reflash?
i have an 02 wrx with full catless exhaust an up pipe and a drop in k&n. I had the factory ecu dyno tuned using the ecutek. When i first got it back it ran great. Just recently it developed a hestation/loss of power from 4500rpms to 5500 rpms. I also noticed when im cruising on the highway if a let off the gas then give it a 1/2 throttle the boost flucuates from 8 to 10 psi for a couple seconds then it settles at 10psi unless i give it more throttle. Could this be a reflash problem or do I have a A/F sensor going bad or maybe the MAF sensor messing up. Any ideas?
mikea322 is offline   Reply With Quote
Old 10-16-2006, 12:38 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
when was the last time you changed your plugs?
Old 10-16-2006, 08:10 AM   #3
mikea322
Member#: 112314
2002 wrx wagon
platinum silver
i just changed them 2 weeks ago that was the first thing i tryed
Old 10-27-2006, 01:06 PM   #4
06 Scooby
Member#: 118474
let me guess...you have aftermarket fuel rails? and you still have your tgv's
06 Scooby is offline   Reply With Quote
can you reset factory ecu to stock after factory ecu updates SHAG SCOOB Engine Management & Tuning 6 11-29-2009 03:55 AM
Beg, borrow, or fake a "CE" issue for the ECU reflash! Just got mine back... gtguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 02-05-2002 08:51 PM
On-site ECU reflash JimmyOOOOO North West Impreza Club Forum -- NWIC 5 01-22-2002 11:14 AM
