Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 10-15-2006, 11:16 PM   #1
snowcrzy
Member#: 110895
Default I'm doing a 6 speed swap into my wrx and I need some advice!
This is my first swap and I am putting a 05 sti 6 speed w/ the entire drivetrain into my 04 wrx. I got the whole rear drivetrain in and the wrx tranny out. I have some questions:
1) The r180 diff has a heat sensor that goes into the back of it. I also have the sti cluster and I know people that just do a sti gauge swap have the rear diff light come on. I would like to wire this up correctly but I don't know where to wire it to...
2) I have the dccd units but I don't know where to wire them, I am rarely every going to use them so would it create a problem if I just don't hook anything up? or, do you know how to hook it up?
3) When putting the clutch/flywheel back in, are there any precautions I should take? Torque to factory specs? I haven't been using a torque wrench but if I need to I can go back and use one. anyone have access to the torque specs for the drivetrain? I have a clutch alightment tool but this step in the whole swap scares me the most, if I mess up on anything I will have to drop the tranny back out(which I don't want to do).
4) What tranny fluid and how much should I use?
5) Anything other advice?
snowcrzy is offline   Reply With Quote
Old 10-16-2006, 01:54 PM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
1. You need an STi wiring diagram, techinfo.subaru.com has them
2. Same as one or you can not hook it up and you will be in Auto forever which is what most people do.
3. Factory Service Manual from the above website has your answer as there are 1000 torque specs.
4. Use what you want though even 6MTs benefit from cool mixes like Uncle Scotty's Cocktail.
6 speed swap into 08 WRX help. aboogabooga Transmission (AT/MT) & Driveline 21 02-15-2013 08:17 AM
6 speed swap into 09 WRX Darkmatter1986 Transmission (AT/MT) & Driveline 20 02-06-2013 03:51 PM
little trouble with 6 speed swap into 04 wrx tylerrusso Transmission (AT/MT) & Driveline 7 06-05-2009 08:18 PM
6 Speed swap Into Wrx ....Axle SWAP? the real suby dude Transmission (AT/MT) & Driveline 1 05-06-2009 03:43 PM
04 6 speed swap into 02 Wrx with Sti swap drftwell Transmission (AT/MT) & Driveline 28 09-10-2008 09:22 PM
