Alaskan Impreza Club
Old 10-16-2006, 12:10 AM   #1
Turk84
Member#: 90696
2005 WRX Wagon
Have a Nice Day? I have a knock/clacking noise...
So, my car has developed this clacking/knocking noise from the passenger side of the engine. It seems to come on at about 1/4 throttle, between 3 and 5lbs of boost, and around oh... 3-4 grand on the tack. After those perimeters are met the clack/knock goes away and it isn't there prior to meeting those perimeters. Strange, but anywhoooooooo...
I've got a Cobb up-pipe and turbo-back exhaust and a PDX costume tune.
Any of you guys have a guess as what it could be? I really have to get this thing to the shop to have it looked at. I really want a '05 with a bum motor...
Thanks,
~Turk
Turk84 is offline   Reply With Quote
Old 10-16-2006, 12:46 AM   #2
JordyB
Member#: 20328
'05 Forester XT
'07 Legacy spec.B
turbo? something with the timing belt area?
some bolts that came loose somewhere...have you checked for the obvious with your hands, on a cool engine?
JordyB is offline   Reply With Quote
Old 10-16-2006, 02:33 AM   #3
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
that sounds pretty weird...
most internal engine knocks are there regardless of RPM or boost and don't go away... Anything loose under your hood?
If you want to have it checked out an Conti, just give me a call tomorrow on my direct like 261-0602. If I'm away from my desk, leave a message and I'll call you back. I'm not in until 9am and have some training to do tomorrow morning.
Mavrik is offline   Reply With Quote
Old 10-16-2006, 03:10 AM   #4
02redwagone
Member#: 87067
02 Old but tasty
SRP
Check heat shields? Mine rattle in time with the engine. Tho every heatshield has a huge dent in it.
02redwagone is offline   Reply With Quote
Old 10-16-2006, 04:55 PM   #5
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
sounds like ignition breakdown, check the plugs. maybe you smoked a coil? look for carbon tracking, split plug boot, burned coil terminal (plug side), etc.
00Maddog is offline   Reply With Quote
Old 10-19-2006, 04:46 AM   #6
shortfuseWRX
Member#: 38573
1997 toyota tacoma
Black death
man sounds like knock to me. or maybe a blown head gasket. sometimes the blow by from the head gasket can make the same noises and go away when the pressure becomes equalized. if you take your plugs out see if you can check to see if there is any aluminum on the spark plug tips. it will look gray in color and shine when a light is put on it. if there is aluminum on the plug tips try to look inside of the cylinder to see if you can see shiny spots on the top of the piston. this may be hard since you guys ahve horiztonally opposed cylinders, but aluminum is a sure tell sign of detonation. if it is detonating, you may want to change plugs or put more fuel into the mix to stop the detonation. believe me, i have gone through the trials and tribulations of detonation. no good.
sam
shortfuseWRX is offline   Reply With Quote
Old 10-22-2006, 10:13 PM   #7
Turk84
Member#: 90696
2005 WRX Wagon
Great...
Well, between work, a 3 month old baby, and everything else I've got going on I've got no time to work on my car.
Can you guys at Conti take care of this kind of thing?
~Turk
Old 10-23-2006, 01:20 AM   #8
Mavrik
Member#: 90347
Yamaha FZ8
Shoot me a PM with your number and a good time to call and I'll call you tomorrow when I'm at work. We can set something up for tuesday or so after. Got openings
Or you can call me direct at 261-0602 at Conti. I'll be there tomorrow 7am to 6pm.
knocking/Clacking noise,uphill clutch letout/braking. please help! scoobe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-27-2008 10:49 AM
clack clack clack noise...who knows their stuff bingo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 04-23-2006 04:41 PM
clacking noise coming from driver side of engine nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-25-2004 04:22 PM
help, loud CLACK CLACK CLACK CLACK noise jawbrkr Transmission (AT/MT) & Driveline 3 07-31-2004 11:33 AM
Clacking noise when starting vinman Normally Aspirated Powertrain 5 11-22-2000 07:05 PM
