10-16-2006, 02:53 PM | #1 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
Element Time Attack STI 1.20 Summit Point Video
I was at Summit Point this weekend running the NASA TTU class to finish up testing for "Limited" class Time Attack. One of the major limitations in the "Limited" class is that we have to run tires with a wear rating of 100 or higher so I chose Toyo RA1s to test with. Our other car running the same tires but with 100 whp more lapped Summit with me driving at 1.23 so I'm really happy we've got the new STI handling well. My goal was really to only hit 1.22 on the RA1s and 1.20 on Hoosiers so I'm ecstatic we did it on the tires we have to race with. We placed first overall and 1st in TTU but there really wasn't much competition except a Monte Carlo "stock" car. This is an unofficial time as I'm still waiting on transponder data but I believe we hit a 1.20 on the third lap. http://www.elementtuning.com/Videos/...t 1.20 web.wmv Engine Modifications: Element Hydra EMS Element Hydramist Element GT52 Bolt-on Turbocharger Element Header Element Fuel Surge Tank Aeromotive A1000 fuel pump TurboSmart E-Boost 2 Clutch Master's STG4 Clutch 1000cc Low Impedance Fuel injectors FMIC TBE Suspension: JIC Element Spec FLT-RS 6 Gun Ball Joint Extenders Wheels and Tire: Prodrive GC06 17 X 9.5 et 44 Toyo RA1 255/40-17 Brakes: Stock (Lines, fluid, pads, Ti backing plates) RCE Kool Brake Kit These tires are really easy to over drive so I had to run a few hot laps and a lap to cool the tires then another couple hot laps. You'll see what happens when they get a little too hot at the end of the video. Thanks, Phil http://www.elementtuning.com
10-16-2006, 03:32 PM | #2 |
Member#: 91208
SCIC
Vehicle:'16 GTI & '14 WK2 |
Congrats phil, a 1:20 is hauling some serious ass!!
oh, and do you know how much air that car displaces when you go by at 140? a TON my car shook when you passed me during your practice!!! haha, congrats again, and i cant wait to see, hear, and brace as you fly be my lil' 944 again!! |
10-16-2006, 03:52 PM | #3 |
Member#: 54304
South East
Vehicle:04 STi TopSpeed-dAng! |
Congrats Phil!
If you don't mind sharing, how much camber did you run up front and what are your wheel / roll rates. This was in the dry correct? Did you get the issue with the rotors / Hawk pads worked out? Good luck at Super Street! Javid 6Gun Racing |
10-16-2006, 05:55 PM | #4 | |
Member#: 54918
It was definitely dry this weekend and the temps in the 60s. I don't want to get into specifics here about my current settings but also it's nearly impossible to find level ground at Summit to accurately measure camber. I pretty much relied on tire temps and when I thought they could be slightly suspect like on the passenger side, since the track rotates clockwise, I marked the tires with white shoe polish to see how much tire was being used. I gained 2 second by finding the tire pressure sweet spot, dialing in a better camber setting on the front, and finding the differential setting that suited my driving style best and the available tracking. The ball joint extenders are definitely doing the trick up front and the car feels very much planted there. I need to work on the rear setup but I just don’t have any more time before Time Attack. I’ve found so much grip with the new setup that even with RA1s I need to go back to drawing board with the suspension configuration. Throwing a better driver out of the equation I know I can get the car to go another 2 seconds quicker on the RA1s without adding any power to the car. There were definitely sections of the track that were intimidating me this weekend and I’m not sure why. Turn 3 for some reason I just couldn’t get comfortable and find the “sweet” line like I could in our other car. I was also a little gun shy going down the “shoot” and felt a little slow through 10 coming onto the main straight. It could also be the tires compared to the last event there where I was on Hoosiers. The RA1s at this pace just aren’t planted and it’s hard to nail your line as the car drifts much more. If money was on the line the Hoosiers are the way to go but at $1000 a weekend it’s a little pricey for me to run them. We didn’t have many brake issues this weekend given how used the pads were. The titanium backing plates and the RCE Kool Brake Kit have controlled the brake temps enough that I didn’t have that extreme wear I’ve been getting over the last handful of track events. My rotors have been cracked for the last two events but they are still relatively small and not yet at the edge of the rotor. I would never have been able to run the last 3rd of the brake pad material before the brake ducts and titanium backing plates. Thanks, Phil http://www.elementtuning.com |
10-16-2006, 06:18 PM | #5 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, 16 Outback Crystal Gray, Silver |
Great video. You were definitely flying. Seemed like you were constantly correctling the car through turns.
You should post some video of you passing people to give a better impression of just how fast you were. |
10-16-2006, 06:33 PM | #6 | |
Member#: 54918
I'll see if I have video from the first TT session. I was definitely driving the RA1s hard so the car was very loose. Also at this speed and grip the track is very bumpy and would often upset the car. Thanks, Phil http://www.elementtuning.com |
10-16-2006, 07:10 PM | #7 |
Hoodbridge!
Yeah, sometimes it was hard for me to deal with traffic, so it must have been REALLY hard for you. Not trying to brag, but I was one of the faster cars in HPDE3 and you went by me like I was stopped. It was great. As you came flying up on slower cars, I'm sure you had a lot of, "Give the point-by. Please give the point-by! PLEASE GIVE THE POINT-BY NOW!"
10-16-2006, 07:44 PM | #8 |
Member#: 54918
If you like watching a Subaru easily drive inside a Lotus and a Miata you'll like this video of me moving through traffic.
http://www.elementtuning.com/Videos/...TI NASA TT.wmv Enjoy it's only 10 megs. Phil www.elementtuning.com |
10-16-2006, 09:33 PM | #9 |
Member#: 70252
Vehicle:05 STI blue |
phil what kind of sway bars are you on? are you gonna bring the monster to california in november?
10-16-2006, 11:13 PM | #10 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
I need to save my pennies for a track day
10-17-2006, 12:17 AM | #11 |
Member#: 96084
Vehicle:98 obs green |
All these people talk about time attacks. Are there qualifing's and finals? Where are these things anyways and when can we see the element tuning car in action again
10-17-2006, 08:13 AM | #12 | |
Member#: 54918
Thanks, Phil www.elementtuning.com |
10-17-2006, 08:15 AM | #13 | |
Member#: 54918
10-17-2006, 11:33 AM | #14 |
Member#: 96084
Thanks Phil!
Does anyone know if the Super street deal is open to the public? Like can I go watch? |
10-17-2006, 01:19 PM | #15 |
Member#: 54918
The Super Street Time Attack is open to the public and free to spectate. Competing is by invite only or through a regional qualifier. We finished in 2nd place last year and were invited again this year.
10-17-2006, 01:50 PM | #16 |
Member#: 37938
Vehicle:02 WRX Blue Mica |
Phil, May I know why don't you use gt65? Is it too big for the track? Thanks
10-17-2006, 03:20 PM | #17 | |
Member#: 54918
10-17-2006, 03:57 PM | #18 |
Member#: 54304
South East
10-17-2006, 04:16 PM | #19 |
Member#: 8302
Vehicle:2002 WRX WRB Sold! 2006 Scion TC-T |
Wow, that looks like so much fun. I am very jealous and that car sure does rotate well.
10-17-2006, 05:54 PM | #20 |
Member#: 4374
Vehicle:2017 BRZ PP |
results are up
http://www.nasaracing.net/Summit_Oct...nt_results.htm |
10-17-2006, 07:19 PM | #21 | |
Member#: 94494
NWIC
Vehicle:2005 Element 92x Black |
10-17-2006, 11:36 PM | #22 |
Member#: 54918
Dang my timer was off by .4 seconds. Better step it up! LOL! Now I feel like a dork and can't change the title Thanks elgorey
10-30-2006, 12:20 AM | #23 | |
Member#: 110957
Vehicle:05 STi Stg 2 Cobb HBspeed, Autopower, KW |
Thanks. |
11-06-2006, 12:17 AM | #24 |
Member#: 54918
Understeer is not at all an issue with our current setup. The RA1s will always screech when used to their full potential. With our current setup we can run less than 3 degrees of camber in the front.
11-06-2006, 07:21 AM | #25 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
I need to pick me up wunna them Mote Carlos, those things are fast, too!
Good stuff, Phil. What size Hoosiers do you guys run on those 9.5" wheels? 255s on a 9.5" wheel is kind of a waste, so I'm guessing your "real" tires are bigger? Pat Olsen '97 Legacy 2.5GT sedan |
Element Tuning Time Attack STI- From Grassroots Motorsports | GrassrootsMotorsports | NASIOC Official News, Articles and Polls | 43 | 05-03-2010 03:28 PM |
Element Time Attack STi, Hydra, Hydramist, GT65 563 whp at 24 psi Video Inside! | Element Tuning | Proven Power Bragging | 56 | 09-09-2008 09:39 AM |
Redline Time Attack Summit Point Video Air Time Baby! | Element Tuning | Motorsports | 18 | 10-04-2007 09:31 AM |
A couple more Summit Point videos, including the Ferrari F355 | Patrick Olsen | New England Impreza Club Forum -- NESIC | 2 | 10-25-2001 08:28 PM |
A few Summit Point videos are up | Patrick Olsen | New England Impreza Club Forum -- NESIC | 11 | 10-23-2001 01:12 PM |
