Old 10-16-2006, 08:05 PM   #1
mummer43
Member#: 113985
2006 Outback Sport
Steel Grey Metallic
Default Need help installing a ground kit on an 06 2.5
I got the paranoid grounding kit and I'm not quite sure if the directions I got are for my motor. Does anyone have any pics of an install or can you walk me through it?
mummer43 is offline   Reply With Quote
Old 10-17-2006, 01:58 AM   #2
mtwilson81
Member#: 108862
2004 impreza RS
platinum silver
im no scientist myself but you can make a grounding kit for lots cheaper than ur kit cost. anyway, all you need to do is disconnect your neg. terminal on the batt. From there attach the links (I assume the kit is a bunch of links with eyeloop ends); attach systematically from your alternator to each head and anywhere else you can see a engine sensor. the closer to the sensors, the more effective(I have attachments all over the place). you attach end to end daisy chain style with those storebought kits. they work just fine but kinda tangle up your engine when you go to clean it. I have a single wire with a bunch of splices coming out directly to my grounding points. that way there is still wires around but they are tucked in and minimal. both are equally effective in terms of conduction.
Just attch end to end and back to the neg. terminal of your battery. pretty easy stuff, and effective too(though some may argue). Cleaned up my idle and made an all around smoother ride when shifting and in low gears especially. good cheap mod.
mtwilson81 is offline   Reply With Quote
Old 10-17-2006, 10:40 AM   #3
mummer43
Member#: 113985
2006 Outback Sport
Steel Grey Metallic
I'm lazy plus it's a good kit and relatively cheap. I got directions, but it would be helpful to see it installed on the same engine.
Old 10-19-2006, 11:08 AM   #4
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
here's a link to some helpful tips and some pics - LINK
Surfer Steve is offline   Reply With Quote
I need help installing a cf hood on a 06-07 wrx JustAnotherSubie Interior & Exterior Modification 14 06-10-2010 04:39 AM
06 STi rims on an 06 2.5 snowman87 Newbies & FAQs 4 10-11-2006 01:56 AM
need help on an 05 injen intake install on an 06 2.5i skribblez32 Normally Aspirated Powertrain 3 08-23-2006 08:11 PM
$16,295 a good price on an 06 2.5 Impreza? BAM6I4 Newbies & FAQs 20 12-21-2005 02:31 PM
Need help with emergency brake issue on 2000 Impreza 2.5 RS PastorBrian Brakes, Steering & Suspension 2 09-10-2005 11:07 PM
