Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 11-07-2001, 07:26 PM   #1
Niloc
Member#: 3296
99 2016 STI
Default Timeing Map ?
Can any one get me or tell me where I Can find a Timeing Map for A NA EJ25
Niloc is offline   Reply With Quote
Old 11-08-2001, 07:01 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Subaru has never published a "Timing Map" for any of the vehicles. One reason being that the ECU learns as you drive and so it continually adjusts the "Map" and would only be accurate for a cleared ECU.
SubyTechMaster is offline   Reply With Quote
Old 11-09-2001, 02:26 AM   #3
Niloc
Member#: 3296
99 2016 STI
What about all of you out there with Tec II's & other ECU's would you share your map with me?
Old 11-09-2001, 02:50 AM   #4
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
If you don't have a TEC-II, our map files won't do you any good. They aren't exactly in ASCII.
Ben
bsquare is offline   Reply With Quote
Old 11-10-2001, 12:36 AM   #5
Niloc
Member#: 3296
99 2016 STI
Timing for a NA EJ25 is a Constant, the fuel map would be the veritable. if you have 16? of timing at 1500 RPM thats 15? from 0. So if I could get a timing map down then that would gine me a place to start. Let me see a TEC II timeing map for a NA EJ25 it might just help, right now I got nothing. Thanks
Old 11-10-2001, 03:36 AM   #6
slamck
Member#: 1436
'00 RS
'03 LLBean, '05 B4
You can get the timing by hooking up a OBD-II scanner. I think I saw timing advance from 10 degree at idle to about 40 degree at 3000rpm or higher last time I have a OBD-II scanner connected to my car. Too bad I haven't got my OBD-II scanner to work with my new laptop, which has no serial port. Maybe someone with a OBD-II can get a more accurate reading for you.
slamck is offline   Reply With Quote
Old 11-11-2001, 12:25 AM   #7
Niloc
Member#: 3296
99 2016 STI
that would be good 40?? I have the highest I got is 27??
Old 11-11-2001, 10:46 AM   #8
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Timing varies widely, depending on RPM and load. IE, you could have 10 degrees at 2500 rpm and high load, and 35 degrees at 2500 rpm with low engine load.
yamarocket630 is offline   Reply With Quote
Old 11-11-2001, 10:35 PM   #9
Niloc
Member#: 3296
99 2016 STI
bump
Old 11-14-2001, 01:04 AM   #10
Niloc
Member#: 3296
99 2016 STI
Bump
Stage 1 Base MAP ON TOP of Real TIme MAP? jeraljay AccessPort 3 08-20-2007 08:27 PM
real time maps compared to base maps ultraspdWRX AccessPort 15 10-20-2006 01:48 PM
Accessport Base Map/Real Time Map overlay question ruski Engine Management & Tuning 0 01-09-2006 06:37 PM
anyone have timing maps for cobbs stage 2.5 vf34 map? blackie Engine Management & Tuning 0 03-31-2005 01:26 PM
regarding anti thef maps and real time maps for the accessport bubba03wrx Engine Management & Tuning 2 05-24-2004 11:01 PM
