Old 10-17-2006, 01:27 PM   #1
scooby_snacks_imprez
Member#: 103702
2011 WRX
Question JDM V7 wrx wheel installed into 2001 RS airbag question
Okay, well i installed the wheel over the weekend regardless but i've had a few problems on the way that would like to clear up and sort out.
The first one was that on both of the airbag set ups, the RS wheel and the wrx wheel had these sort of harness inbetween the charge and the plastic cover with the clip
(this is the wrx one)
So i swapped the charges from the RS into the WRX wheel and that was all ok. The problem arises when i try to put that harness from above back on the the wrx unit after the RS charge has been placed in it. The circle in the middle is just a few mm too small to fit it in.
Here's what it looks like
And here's one of the unit without the metal thing just for reference
Well i read from someone over on rs25.com that their newer wrx USDM wheel didnt even have one of these metal things in there so that made me worry slightly less about not including it. My plan is to try and get someone to cut it a bit and increase the diameter but that sounds a lot easier than it is unless you can suggest any metal workers in the atlanta area (chain stores or anything). Does this unit play a vital role?
By the way the RS one will not fit due to different size units and shape.
The steering wheel is about 10 degrees off to the right also but that can be fixed with the toe rod adjustment or so i have read.
This weekend i'll probably be taking the unit back off to make sure i tightened the steering wheel properly as i don't actually have a proper torque wrench, just a little one with a 3/4in drive which i used with all my strength to tighten the bolt but better to be safe than sorry eh? Also gotta hook up the horn wires from the cruise control because i can't honk atm.
Right, thanks for any help or information
Jack
scooby_snacks_imprez is offline   Reply With Quote
Old 10-18-2006, 10:02 AM   #2
Member#: 103702
2011 WRX
hmm would have thought this have been moved to the suspension and steering forum... but its all cool
Old 10-18-2006, 07:02 PM   #3
Member#: 103702
2011 WRX
has anybody who swapped steering wheels at least noticed whether or not they have this metal thing in there or not??
Old 10-20-2006, 06:24 PM   #4
Member#: 103702
2011 WRX
...so has nobody on here never swapped a steering wheel and noted the parts inside??
Old 10-21-2006, 02:27 PM   #5
Member#: 103702
2011 WRX
bump anyone?
JDM V7 STi wheel bearings same as WRX? CTKAG Brakes, Steering & Suspension 3 06-25-2013 08:58 PM
2004 RS 5MT into 2001 RS 5MT? BlackfeetVI Transmission (AT/MT) & Driveline 1 10-22-2008 01:48 PM
2002 WRX swap into 2001 RS swap question dtl1218 Subaru Conversions 14 08-13-2008 01:58 PM
STi v7 front lip spoiler for 2001 RS Scooby_WL Private 'Wanted' Classifieds 1 05-11-2004 12:43 PM
98 rs alarm system into 2001 rs? imprezey Newbies & FAQs 1 08-13-2002 02:40 AM
