Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 10-17-2006, 01:52 PM   #1
Member#: 111165
2008 Legacy (Sedan)
2005 S2000 (Supercharged)
Default Some questions regarding Alky injection options..
Looking to pick up an alcohol injection kit soon and wanted to get some feedback from you guys about the SMC and Cooling Mist systems. I have done some basic research and they both seem to be good kits...
Can you guys please let me know your thoughts on each kit (pro/cons) to help me make my descion on which one I should take a closer look at...I havent found the answers I was looking for in the search archives...
(I also sent emails to each company but would like some outside feedback from you guys)
Black-STi is offline   Reply With Quote
Old 10-17-2006, 03:49 PM   #2
Member#: 115420
Its like a STI.....
but it doesn't break
I have the SMC kit and i love it. Very straight forward and have not had any issues with it.
JMK508 is offline   Reply With Quote
Old 10-19-2006, 02:06 AM   #3
Sleeper in Seattle
Member#: 101546
2004 FXT & 04 S2000
Silver & black
I have the ALKYCONTROL.COM kit and I love it! Everyone that owns the kit has nothin but priase for it, and I've never heard of any issues with it.
You can see my results about ten posts down with before (Cobb stage two with a protune) and after (PDX stage two protune with 100% METH).
No matter what way you go- as long as you go 100% meth- you will be extremely happy.
Sleeper in Seattle is offline   Reply With Quote
Old 10-19-2006, 04:06 AM   #4
Ultimate Collision Center
Member#: 69072
Both are great kits, but I will shamelessly plug in snow performance kits, all the top kits out there are great, you just have to decide what are the most important things out of a kit that you would want and see which kit or combinations of kits fills those needs..
Ultimate Collision Center is offline   Reply With Quote
Old 10-19-2006, 11:51 AM   #5
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I always get the best tuning response from the Aquamist 2D system with 50/50 water/meth.
The reason I say this is because the Aquamist 2D matches the injection with the injector pulses. This means that the injection delivery is very uniform making tuning for it much more reliable. Also has a map switch point and a block nozzel indicator.
The systems that just turn on via boost or RPM have the issue that during that transtion from no injection to injection the tune is very hard to get right. Especially when you have 100% meth, it goes super rich as soon as it turns on.
Whatever system you do you have to install something like the Aquamist DDS3. This monitors the injection flow and will cut boost if the set points are not met. It's a great safty net when using water/meth injection. Handy as well as you can tune at wastgate boost with just pump gas and then when it's enabled you tune for full boost with injection. If injection ever fails it cuts boost to wastegate which was tuned for just pump gas, no water.
mick_the_ginge is offline   Reply With Quote
Some questions regarding a very non typical plan of action smacksube Subaru Conversions 18 06-08-2007 02:26 AM
some questions regarding to chipping my 02 wrx boreas Engine Management & Tuning 3 06-28-2005 06:09 AM
Some questions regarding the alignment I just got done. YinUCSD Brakes, Steering & Suspension 8 04-19-2004 02:55 PM
ACT Clutch Installed: Have some questions regarding engagement latinskllz Transmission (AT/MT) & Driveline 9 07-07-2003 11:02 PM
I have some questions regarding Cusco Adj sway bar. Rodan Brakes, Steering & Suspension 5 01-09-2002 10:27 AM
