Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 11-07-2001, 08:34 PM   #1
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Proper procedure after ECU Reset?
Okay I was just at my dealership and I cleared a few of my usual codes you know high pressure and and one misfire. Anyways after the reset my car was running supper lean in all gears with the negative corrections on my S-AFR. So I set all my corrections to zero and now it is super rich. What should I be doing after an ECU reset?
yebokmj is offline   Reply With Quote
Old 11-07-2001, 09:17 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Driving the crap out of it . It's a learning ECU, so the more aggressive you are with it, the more aggressive the timing/fuel maps will become (to an extent... the stock ECU only does so much after all ).
You and the Captain make it happen!
Old 11-07-2001, 09:56 PM   #3
Joe Hogan
Member#: 699
2002 golf TDI
Or better yet use a 20lb sledge and beat the crap out of it. It will never give you a problem again
Joe Hogan is offline   Reply With Quote
Keyless entry- reset after ECU reset? sir_aspen_white Electrical & Lighting 1 04-22-2003 08:24 PM
cammed cars--- slower after ECU reset? ColinL Normally Aspirated Powertrain 18 04-11-2001 12:06 AM
Sick of alarm making you deaf after ECU reset? AccidenT Normally Aspirated Powertrain 9 03-26-2001 12:23 AM
Problems after ECU reset Gorio Normally Aspirated Powertrain 10 12-05-2000 06:49 PM
Idle problem after ECU reset Spectre23 Technical Forum Archive 1 05-19-2000 12:42 AM
