10-18-2006, 02:34 AM | #1 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
Hydra not remembering my maps?
Ok I
opened the program opened the map andrew@hydra sent me, it was encrypted so i clicked unencrypt downloaded it turned off ignt for 15 seconds clicked upload (it failed a couple times, thank you I/O gear ) clicked maps its blank opened another map a friend sent me he made clicked download downloaded it turned off ignition for 15 seconds clicked upload map clicked maps its blank wtf is going on? i have the full unlock code, but dont know why it would be needed to have the hydra retain the information.... please let me know thanks alex hydra2.17
10-18-2006, 09:34 AM | #2 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
Seriously I don't mean to sound harsh but you need to read the manual. I know you didn't buy your Hydra via Element Tuning but you are welcome to read our tuning guides.
By selecting "Decrypt File" you've wiped out your Hydra completely. You will now need to unlock your box and get the original map file that was originally downloaded to your Hydra via Andrew. |
10-18-2006, 11:29 AM | #3 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
10-18-2006, 11:35 AM | #4 | |
Member#: 39936
ive read the manual, at least the section concerning my current problem the file andrew sent me was encrypted, he told me to hit decrypt. ill try the unplug plug in thing |
10-18-2006, 07:59 PM | #5 |
Member#: 39936
10-19-2006, 10:46 AM | #6 |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
10-19-2006, 11:57 AM | #7 |
Member#: 39936
no ive been bugging him a lot
drac 9 says he has this problem and after 10 downloads it finally worked... sigh i thought they worked out the big problems! |
10-19-2006, 03:09 PM | #8 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
10-19-2006, 03:54 PM | #9 |
Member#: 39936
ok
read my problems and tell me its common for the ecu to not interface properly with its own software come on man, im unfamiliar but im not braindead |
10-19-2006, 04:03 PM | #10 |
Member#: 27108
10-19-2006, 11:17 PM | #11 |
Member#: 447
Vehicle:1999 RSTI WRB |
try a different serial cable.
10-20-2006, 09:17 AM | #12 |
Member#: 54918
That is usually what happens when you are using a USB-Serial adaptor and its a high speed version. Try to find a low speed adaptor for a Palm Pilot etc. I've heard the Belkin works well. If you do a search brands that work well have been listed.
10-20-2006, 11:37 AM | #13 | |
Member#: 39936
maybe i can drop the baud down a little just so i dont have to buy something else? i guess it couldnt hurt to try it |
10-20-2006, 12:04 PM | #14 | |
Member#: 54918
"Note: Do not use USB to serial interface on laptop computers as this may cause PC to ECU connection problems." With that said 90% of my customers use a USB to serial adaptor but from my experience some work and others do not. You can try to slow the speed down but maybe others can chime in on what USB adaptor they use works. The one I use is a no-name brand. |
10-20-2006, 12:16 PM | #15 |
Member#: 39936
sorry i must have heard it from andrew and thought i read it
10-20-2006, 01:12 PM | #16 |
Member#: 27108
I've been using an IO Gear brand adapter with my Hydra all along, and I've never had a problem with the Hydra not storing a map.
You might want to try a different laptop just to try and narrow things down. |
10-21-2006, 03:03 AM | #17 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
Just to put in some input here, I can only upload and view information, not download with my adapter on my laptop. However I tried the same cable on my sisters laptop, both Vaio's different models but bought like months apart, and hers works no problems, downloads and everything. I couldn't use the one we used at PDXTuning either on my laptop i had to use Jarrads laptop.
I have my usual theory as to why mine sucks, yep you guessed it, too much porn. Ben |
10-22-2006, 10:01 AM | #18 |
Member#: 54918
It might be something simple like your default COM settings in your laptop. Try and compare your settings to those of your sister's.
10-23-2006, 07:59 AM | #19 |
Member#: 11926
Vehicle:2011 Outback Limited Dark Grey |
I use a I/O gear I just slowed my adapter down in the device manager to 9600 and it worked fine. that will also give you the com number so you can verify that.
10-23-2006, 11:52 AM | #20 |
Member#: 27108
I've never had to slow my IO Gear adapter down in the device manager for any application (Hydra, UTEC, old DeltaDash cable, LM-1, LC-1, Xede, AEM, etc...)
10-23-2006, 08:42 PM | #21 |
Member#: 11926
me either it worked fine on my utec . I couldn't get my hydra to connect without slowing down the baud rate to 9600 .instant connection after that.
10-24-2006, 10:37 PM | #22 |
Member#: 447
Have tried nth laptops and nth cables.... don't ask.
its hit and miss every laptop will have its own drivers, arch, blah blah. if its usb and serial its most likely the cable. |
Hydra 2.5 losing map? | pignoseSTI | Other Engine Management | 3 | 06-30-2009 05:48 PM |
AP not letting me switch my map.. HELP!!! | Pepo | AccessPort | 7 | 05-28-2008 11:51 PM |
Hydra and optional fuel maps | japslapr | Other Engine Management | 4 | 04-04-2007 09:51 AM |
Cobb AP not loading my maps. | ockS | AccessPort | 9 | 11-15-2006 05:11 PM |
Why does my map not hold?? | mikeG8U | Engine Management & Tuning | 1 | 03-06-2005 05:37 PM |
