Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 11-07-2001, 11:28 PM   #1
mick dundee
Member#: 8200
98' 2.5RS
Question Blitz rear section info needed
Im interested in purchasing a blitz (I think nur spec) rear section. What I need to know is what is the diameter of the piping? I plan on having a mid pipe fabbed, and it would probably be wise to have the same diameter for both sections......
mick dundee is offline   Reply With Quote
Old 11-08-2001, 12:00 AM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
The only 2 options for the Nur Spec are 70 and 80mm. Both are too large for a small NA engine like the EJ25 (which will suffer if you go past about 57mm). The problem only becomes worse if you try to put the same diameter piping all the way through. Unless you are putting a turbo on the car in the near future, I'd pass on the Nur Spec. Nice can, but not appropriate for your apparent application.
Ben
bsquare is offline   Reply With Quote
Old 11-08-2001, 12:05 AM   #3
wistful
Member#: 745
2004 STi
Java Black Pearl
i've got a Blitz NUR Spec can. How far is Worthington from Akron? you're welcome to come up and look/feel/hear it whenever. The mid-pipe I used was a 2.5" and then welded it to the larger 70mm rear piping. It might be too big, but hey.. I dunno. I know a few other RSs are running it and are totally happy with it, as am I. It sounds and looks straight-up awesome.
Don
wistful is offline   Reply With Quote
Old 11-08-2001, 02:25 AM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
How big is the 70mm?
I have the WRX specific NurSpec rearsection on mine, and there's a bit of large 3" piping coming from the muffler. Then the real piping beyond that (2.25") which you can't see unless you're under the car.
Keiho is offline   Reply With Quote
Old 11-08-2001, 02:50 AM   #5
bsquare
Member#: 1911
2000 Impreza 2.5RS
70mm is 2.75", 80mm is 3.15".
Ben
Old 11-08-2001, 06:01 AM   #6
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Ah..mine's the 80mm then.
Turbo Timer - Blitz VGTT - Installation Info Needed... *PICS* BoostAddictPL Electrical & Lighting 4 11-28-2005 10:58 AM
N.VA trade blitz rear section All8up Mid Atlantic Impreza Club -- MAIC 2 11-08-2003 10:08 AM
New Blitz Nur Touring rear section sherifx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-29-2002 11:15 AM
FS: Blitz Nurspec rear section for 00WRX S201 Vancouver Impreza Club Forum -- VIC 8 10-17-2002 12:17 PM
Anyone wanna buy a Blitz Nur Spec rear section? :) Verdugo North West Impreza Club Forum -- NWIC 13 05-30-2002 02:59 AM
