10-18-2006, 05:48 PM | #1 |
Member#: 9596
NWIC
Vehicle:2007 Toyota Prius |
98 Legacy stumbling, changed ignition coil
Hey, I'm car *dumb*.
With that said, my mother in law's Legacy Outback 1998 base model (manual transmission) "stumbles" very badly when you try to accelerate and the RPM's are below 2k. Not just bogging, but really bad missing/stumbling. So, I looked at the ignition coil and one of the connecters was fouled, so I replaced it. It is still doing it. Is the next step to change the plugs and wires? -Allen
10-18-2006, 05:58 PM | #2 |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
When was the last time they were changed? Is the check engine light on?
10-18-2006, 11:39 PM | #3 | |
Member#: 9596
NWIC
Don't know the last time they were changed, this is a "new" car for my mother in law. (She purchased about a week ago) -Allen |
10-19-2006, 10:35 AM | #4 |
Member#: 63616
South East
I would replace the spark plugs and wires then, especially because you have no history of them being done. Also make sure that you put the correct ones in. Subarus are touchy when it comes to plugs.
Also, get the check engine code pulled....that will help put you in the right direction. |
10-19-2006, 11:42 AM | #5 |
Member#: 9596
NWIC
Thank you, is the dealer the best place to go for the "right" plugs, or does autozone or whatever carry them and I just need to be specific about which ones I need?
-Allen |
10-19-2006, 07:16 PM | #6 |
Member#: 9596
NWIC
Got the plugs and wires changed. Problem went away.
Now onto the emergency break not gripping tightly enough... Thanks Rexy you were very helpful! -Allen |
10-20-2006, 12:25 AM | #7 |
Member#: 63616
South East
The emergency break either needs adjusting or you need rear brakes.
Your welcome.....although I didn't get to answer your last question You can get the "proper" plugs other places than the dealer. Your owners manual tells you which ones are best. |
98 legacy 5 speed - flashing check engine light after ignition... | Box This | Electrical & Lighting | 4 | 10-12-2009 10:16 PM |
Ignition Coil my2000 rs, is the same year outback coil work? | GregBolby | Normally Aspirated Powertrain | 5 | 03-31-2007 11:47 PM |
sti ignition coils vs wrx coils | wickedwrx2002 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 08-23-2006 07:23 PM |
DPR Headquarters releases Ignition Solutions direct replacement ignition coils. | DPR Racing Int. | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 05-22-2005 07:36 PM |
4 Wrx Coils, Ignition Coil Packs, | navyissuesuby | Private 'For Sale' Classifieds | 16 | 03-05-2005 01:07 PM |
