Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Vendor Classifieds
Closed Thread
Old 10-18-2006, 07:51 PM   #1
Precision Tuning
Vendor Sales Rating: (9)
Member#: 38696
Default More Specials!!!! Cobb, GReddy, Prodrive,Tial Worx!!!
PrecisionTuning
Phone: (732)451-0200
Fax: (732)451-0110
945 Cedar Bridge Ave
Brick, NJ 08723
www.precisiontuning.com
sales@precisiontuning.com
NEW!!!:
SHOPCAM!!!
Weekend Specials!!!!!
Prodrive Boost Solenoid
Prodrive’s 3 Port Boost Solenoid is designed to allow any aftermarket engine management system to more effectively control boost at higher pressures. It is a vast improvement over the factory Subaru solenoid, which becomes progressively more difficult to control at higher boost pressures. No cutting or soldering nessacary, included harness provides for an easy plug & play installation!!!
Included:
  • Boost Solenoid
  • Wiring Harness
  • Mounting Bracket
Regularly $99.00,
ONLY: $90.00!!!!
GReddy Informeter
Designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and datalog your vehicles performance though it's own OBD sensors. Select through important signals like Speed, Tach, Temps, Air Flow, Voltage, etc. (up to 25 channels), to monitor. The easy to use navigation menu allows you to select between various screens and displays: Digital, Analog or Bar Graph and 2ch, 3ch, or 6ch screens. You can also set warning points and pre-warning points, which will alert you with audible and visual highlights of important readings. Datalog up to 6 channels of data, and replay them. This is great for tuning. In addition to being functional the Informeter is also infinitely fashionable. Seamless changes in backlighting color, GReddy signature wall papers and colored backgrounds, along with a clear bezel to install colored face plates or even custom face plates, offer a endless options to match any vehicles interior. And to aid in mounting the unit can flip the display 180 degrees to free even more options. The GReddy Informeter is a key tool for all; beginners to pro tuners.
Included:
  • GReddy Informeter Unit
  • OBD Cable
  • OBD II Cable
  • Cigarette Lighter Power Cable
  • 9 Different Color Face Plate Inserts
  • Japanese Instruction Manual!!!!
Regularly $360.00, ONLY $275!!!
Choice of White or Black
Tial Sport 50 mm Blow Off Valve with Aluminium Weld On Flange
The body and all internal components are CNC-machined from 6061 aluminum alloy. It features a large 1.98 in (50.5mm) valve; we believe this is the largest valve available with the highest flow capacity. The V-Band design aluminum mounting clamp gives a very clean and unique appearance. The clamp is anodized and uses Stainless Steel hardware for a long lasting, corrosion-free appearance. The valve seal utilizes a Viton O-ring that is clamped in place to prevent the possibility of sticking to the seat and pulling out. The valve stem and guide are Teflon-lubricated, hard anodize-coated for wear resistance. The Blow Off Valve also comes with our own machined aluminum banjo-type air fitting and bolt, with over sized 10mm hose barb for quick actuator response. The actuator has a high temp silicone Nomex-reinforced diaphragm for long life.
Included:
  • Tial Blow Off Valve Assembly
  • V-Band Clamp
  • High Pressure O-Ring
  • Banjo Style Air Fitting
  • V-Band Weld On Aluminium Flange
  • Tial Sticker
  • (Not Pictured) Nifty diagram showing you where to install it!!!!
Regularly $250.00, ONLY $225!!!
Choice of Silver, Blue or Purple
CobbAccessPORT
Ability to use AccessECU maps without removing ECU
10 Instantly Switchable Maps
Read and Clear Check Engine Lights
Download new maps via the Internet
Revert back to Stock programming
2 In Stock
  • 2006 Legacy GT Auto
  • 2006 Legacy GT Manual
Included:
  • AccessPORT
  • OBDII Cable
  • Serial Cable
  • AccessPORT Software
  • A/C Cable
  • User Guide
Regularly $645.00,
ONLY: $620 SHIPPED!!!
Worx TuningCatless Turboback Exhaust
The Worx Tuning Turbo-Back upgrade will provide a deeper, throatier performance sound without excessive uncomfortable resonation associated with many performance systems on the market. Throttle and boost response, and overall performance is noticeably improved due to our free flowing design. With a low to mid 30 lb. weight, it will shave 20+ pounds off of your vehicle weight, and the fully polished stainless system looks great too.
Features:
  • 3" aircraft grade 304 Stainless Steel Construction
  • Flanged and slip fit joint construction
  • Includes all necessary clamps, hardware, and gasketing
  • 1 piece design Downpipe for cleaner exhaust flow path
  • A/C Cable
  • Made in the USA with a LIFETIME MANUFACTURER'S WARRANTY
ONLY: $699.99!!!!
Thank You!
Kyle
Precision Tuning
Brick, NJ 08723
http://www.precisiontuning.com
AIM: Precisiontuning1
Fax: (732)451-0110
Precision Tuning is offline
Old 10-19-2006, 06:01 PM   #2
norexyet
Member Sales Rating: (22)
Member#: 39149
11 elantra
yea i said elantra
thats a funny looking turboback kyle smith
norexyet is offline
Old 10-20-2006, 09:25 AM   #3
wrxbert
Member Sales Rating: (9)
Member#: 89886
2006 WRX
SGM
how much for just the catback?
wrxbert is offline
Old 10-24-2006, 04:23 PM   #4
Precision Tuning
Member#: 38696
Its all one kit. Shoot over an offer, if its reasonable its yours.
Rich
Old 10-27-2006, 09:16 AM   #5
DieselClown
Member Sales Rating: (25)
Member#: 36135
2005 WRX
Hey Rich or Kyle...do you guys carry the Cobb catted dp? If so, please shoot me a pm. This is going onto an 05 wrx btw. I want to get that and the intercooler hoses from you guys installed. I'll try to gut my stock uppipe but so far the instructions sound a bit scary to me.
DieselClown is offline
Old 10-27-2006, 03:51 PM   #6
norexyet
Member#: 39149
11 elantra
yea i said elantra
we don't have them in stock, but getting them isn't an issue. We can also get intercooler hoses without a problem. I will have an sti uppipe for sale pretty soon if your interested in that.
-Justin
Precision Tuning
norexyet is offline
Old 10-28-2006, 12:29 PM   #7
xerox445@yahoo.com
Member Sales Rating: (2)
Member#: 111556
2006 STI
When are you guys open? Im local, and i just picked up a black 06 sti, want to stop by, see your shop, ask a few questions and shoot the ****/get to know some of the subbie dudes round here, coming from the honda camp.
xerox445@yahoo.com is offline
Old 10-28-2006, 02:14 PM   #8
norexyet
Member#: 39149
11 elantra
yea i said elantra
monday-saturday 9am-6pm. were usually there till at least 7 though
norexyet is offline
Old 10-28-2006, 05:56 PM   #9
fog
Member Sales Rating: (1)
Member#: 35911
2002 WRX Gutted
Some of us are here. Others are enjoying the affects of prescription drugs at home today. Right Justin?
R
fog is offline
Old 10-28-2006, 10:40 PM   #10
norexyet
Member#: 39149
11 elantra
yea i said elantra
the oxy's are oo so nice.
norexyet is offline
Old 10-30-2006, 08:39 AM   #11
DieselClown
Member#: 36135
2005 WRX
-Justin
Precision Tuning
thanks for the info justin. how much would you sell the sti uppipe for? Also, would you know how to install it without tripping the o2 sensor and can you recommend a good DP other than the catted Cobb as well? I just want to either retain the 3rd cat or get a DP that's catted to be able to pass inspection. If you can give me a good price on the sti uppipe installed, I might as well also do the DP/ IC hoses together with you guys!! Let me know..thanks!
Steve
Old 11-02-2006, 06:09 PM   #12
Precision Tuning
Member#: 38696
Bump!!!!
Still available, had to close for new Clutch Specials!!!!
Closed Thread
WTB :: Exhaust - Cobb - Greddy - Tanabe ++ Myth21 SCIC Private Classifieds 27 06-22-2010 12:29 AM
Prodrive, Cobb, Cusco, 5Zigen, STi, Worx, & more! bliu SCIC Private Classifieds 43 11-03-2007 04:33 PM
February Specials!!!! TurboXS, Perrin, Prodrive, APEXi and Much More!!! Precision Tuning Engine/Power/Exhaust 29 08-06-2007 10:01 AM
Greddy, HKS, TiAL, Prodrive and More!!!!! Precision Tuning Engine/Power/Exhaust 27 01-13-2007 08:19 PM
New Vendor Specials!! HKS, GReddy, Invidia, Perrin, Tanabe, TurboXS and More!!! HPOutlet Engine/Power/Exhaust 72 08-16-2006 08:20 AM
Message Board Statistics All times are GMT -4. The time now is 05:44 PM.
