Old 10-19-2006, 02:10 PM   #1
mizh
Member#: 128604
Default Is it normal to hear the sound like water dropping inside car?
It is my first car, 2001 forester, just bought.
After I turn off the engine, I can hear some sound like water dropping inside car.
So is it normal things or is sth leaking?
mizh is offline   Reply With Quote
Old 10-19-2006, 02:31 PM   #2
tasq
Member#: 62362
2005 wrx
CGM
tasq is offline   Reply With Quote
Old 10-19-2006, 04:18 PM   #3
benw
Member#: 103320
1998 swapped
Forester L
mine sounds like that when I turn it on and give it a tap on the throttle. swear it sounds like water running, and I heard it on my bugeye too.
benw is offline   Reply With Quote
Old 10-19-2006, 06:19 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
Sounds like you have trapped air in your coolant system - take it to a shop and have them burp it and add some coolant.
flycaster is offline   Reply With Quote
Old 10-19-2006, 06:46 PM   #5
benw
Member#: 103320
1998 swapped
Forester L
if there is, it's from the turbo swap. What I did was hook everything back up, and as the car was running, added coolant to the turbo reservoir. Never opened the other radiator cap. Advice?
Old 10-19-2006, 10:54 PM   #6
mizh
Member#: 128604
Thanks
Is it a serious problem?
When doing inspection today, I ask the guy who did the inspection for me the same thing.
He said it might come from the cooling system of engine.
Do I need to bring the car to a shop and have it checked?
Thanks again!
Old 10-20-2006, 01:13 AM   #7
poormansporsche
Member#: 79798
Yeah I also swear I have a faucet in my dash. It's always done it however. Even when I had the 2.5 NA engine and now with the WRX motor.
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 10-20-2006, 12:20 PM   #8
mizh
Member#: 128604
I also found some water-like things in the ground under the car.
Does this means that the coolant is leaking?
Old 10-20-2006, 12:42 PM   #9
Rayman21287
Member#: 105125
2005 WRX/ 2008
Stage Pi/MercedesC300 4MA
Did you have your A/C on?
Could just be condensation if it was on.
Rayman21287 is offline   Reply With Quote
Old 10-20-2006, 12:48 PM   #10
mizh
Member#: 128604
No, my A/C is definately off.
So it is so strange that I can find some water like things in the ground under the car. It is just under the front of the car.
I saw this car has a recall for the coolant conditioner on Sep.
Is it sth wrong with the coolant?
So worry about the coolant or sth else leaking.
Thanks for all replies.
Old 10-20-2006, 12:49 PM   #11
mizh
Member#: 128604
I mean the car did coolant conditioner recall in Sep.
Is it normal to hear noises when "engine braking" SinisterMinister Transmission (AT/MT) & Driveline 6 08-28-2005 01:32 PM
How is it possible to mount the car body six inches the left of the frame? scaryfastskier Off-Topic 16 10-26-2004 08:30 PM
Is it normal to be able to hear your brakes engage? Robmat South East Region Forum 9 09-18-2001 08:38 AM
Is it normal to hear the brakes engage under normal braking conditions? Robmat Brakes, Steering & Suspension 0 09-13-2001 01:01 PM
Is it normal to hear the brakes engage when.... Robmat Brakes, Steering & Suspension 2 07-08-2001 10:41 AM
