Old 10-19-2006, 05:12 PM   #1
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
Default Confused on PCV valve replacement
I'm doing my 30k mi service on my 2004 WRX. I wanted to replace the PCV valve but I'm not sure if I have the right part.
goldice42 is offline   Reply With Quote
Old 10-19-2006, 05:19 PM   #2
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
First the dealership gave me one that looked like this (not sure what part number they gave me because I returned it)
Old 10-19-2006, 05:23 PM   #3
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
Then I read on another forum that the part for the 04+ was different than the previous years and that the model number should be 11819AA001. So I went back to the dealership and got this one.
Old 10-19-2006, 05:26 PM   #4
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
Now as you can see these two valve look completely different...So anyways I took my IC off and began to look for the valve that needed to be replaced. This is the spot of the one that needs to be replaced on Imprezas < 04 year. (At least that is what I believe from reading various forums)
Old 10-19-2006, 05:28 PM   #5
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
Here is where I think the one I have needs to go. Right under the turbo outlet.
Old 10-19-2006, 05:31 PM   #6
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
Another
Old 10-19-2006, 05:36 PM   #7
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
Zoomed out
Old 10-19-2006, 05:38 PM   #8
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
So basically I'm not sure which part I have to replace, or if I have to do both, or if I don't have to do either at all. BTW each part costs $12 so they aren't too expensive if I need to do both.
Old 10-19-2006, 07:37 PM   #9
Kansai Subaru
Member#: 59065
1995 Impreza 2.2LX
Dark Green
the first picture is the PCV valve. It has a valve in it and it rattles when you shake it. Did it for you? Your old one should rattle too, but have a little oil in it. As for the second picture, it looks like a vacuum hose connector. The pictures you supplied looks like you located the PCV valve. I don't have a WRX, but I know a PCV valve when I see one. Does it connect to the crankcase? If yes, then it is. I heard for the WRX, it is located under the intercooler. And also, when you put your new one on, put some teflon tape on the threads of the new PCV valve.
Kansai Subaru is offline   Reply With Quote
Old 10-19-2006, 09:40 PM   #10
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
You will use the AA001. It's easier to replace the whole assembly than it is to get the valve out without breaking the plastic. The valve itself is the same as the 11810AA040 most 02+ nonturbos use.
Brian
Old 10-19-2006, 11:19 PM   #11
goldice42
Member#: 43113
2004 WRX Sedan
Java Black Pearl
Brian
Do you have to remove the turbo to get at the valve? It's right under the turbo outlet and the clamps are very hard to get at with regular pliers. Any tips on getting it out?
Old 10-20-2006, 12:38 AM   #12
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Honestly, Subaru says that the PCV valve is a non-serviceable part on your car- they didn't intend for it to ever be changed, though it really should be. You should in no way need to remove the turbo to change the PCV valve- the clamps aren't easy to get off, but once you do you can replace them with pinch clamps or standard hose clamps to make things easier next time around.
Brian
Old 10-20-2006, 04:11 PM   #13
Snitt
Member#: 36361
2004 WRX Cobb Stg II
WR Blue
That T-shaped part that you have is the correct one, and that looks like the spot where it goes. It's been awhile since i've done mine, but that looks like it.
Snitt is offline   Reply With Quote
Old 10-31-2009, 01:30 PM   #14
Beam
Member#: 29742
2011 Ah Subaru.
I missed you.
Would the placement be the same on the '04 STi? And does anyone have pics of an '04 since the ones above no longer work?
Beam is offline   Reply With Quote
Old 10-31-2009, 01:55 PM   #15
Beam
Member#: 29742
2011 Ah Subaru.
I missed you.
Found it. n/m
Old 11-27-2010, 04:33 PM   #16
stereophonic
Member#: 232291
Exclamation video of 2004 WRX PCV valve
This was helpful in identifying the pcv valve (Subaru p/n: 11819AA001) on my 2004 WRX:
It's on the passenger side of throttle body, a few inches below. It is not the same as the older WRX's (which is screwed into the manifold, '04 pcv is on the other end of that hose). Large end of the T goes to the crankcase (straight down, hose), small end of the T goes to the turbo inlet (straight up, hose), and the metal part (the actual valve) points toward the driver side and connects to a hose that runs to a fitting where the pcv was on the older models, just under the throttle body.
To try to replace just the metal part I cranked on it and broke the plastic, so now I'm stuck for 3 days till my replacement comes in, $25 rush shipping... should have ordered it before I started messing with it.
stereophonic is offline   Reply With Quote
PCV valve replacement db97 Service & Maintenance 37 11-07-2010 07:31 PM
PCV Valve REPLACED Idle Problem GONE!! deebee8 Factory 2.0L Turbo Powertrain 5 06-03-2007 10:55 PM
PCV valve replacement interval HudsoN456 Service & Maintenance 10 05-23-2002 03:22 PM
PCV Valve Replacement Interval? Silver2000RS Technical Forum Archive 1 10-12-2000 09:26 AM
PCV Valve Replacement richeich SVX Forum Archive 2 06-26-2000 06:53 AM
Message Board Statistics All times are GMT -4. The time now is 07:49 AM.
