Old 10-19-2006, 08:01 PM   #1
faheyr12
Member#: 125999
2006 WRX TR
CGM
Default Question Regarding General Modification on O6 Impreza WRX TR
My apologies if this is in the wrong thread, but I was unsure where to put it based on covering a few different topics. I recently purchased on 06 WRX TR and am considering putting a turboback exhaust on the car. At this point in time, everyone has advised engine management (Accessport) in order to be safe from overboosting. My questions are as follows: What kind of gains will I be looking at with full turboback exhaust plus engine management? My second question relates to the fact that some individuals have recommended a upgraded turbo (16G) OR external wastegate for other issues that I am unaware of. My questions on this matter are as follows: Is it necessary and the safest measure to upgrade the turbo on 06 WRX TR when putting a turboback exhaust plus EM on the car? Secondly, what kind of gains and price should I be expecting to see with an upgraded turbo such as 16G (looks like around $699 or so) along with turboback exhaust and engine management? Thanks for the help.
faheyr12 is offline   Reply With Quote
Old 10-19-2006, 08:06 PM   #2
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
With the EM and turboback you should be getting around 225 whp. Add a 16G and you'll be damn close to 300 whp depending on the dyno. You won't need an external wastegate for the stock turbo or the 16G.
Capt Crunch is offline   Reply With Quote
Old 10-19-2006, 08:32 PM   #3
dillsky
Member#: 109485
06 Blue TR
FP18g'd
First off get Cobb's Accessport....you'll have to wait a couple of weeks cause they are coming out with an updated version(Accessport 2.0). Once you get that, flash Stage 1. Save up some cash and get a TBE system, then flash Stage 2.......very noticable increase in power! After that if you want to do a turbo upgrade, Cobb has 2 maps available for the '06 WRX: vf39 map or the Fp18g map. I choose to do the fp18g map. Along with the upgraded turbo, you will have to get a bigger TMIC. The fp18g map is rated for 293whp. Cobbs website has all the info.......good luck
dillsky is offline   Reply With Quote
Old 10-19-2006, 09:04 PM   #4
Bboy AJ
Member#: 127021
2006 OBP WRX TR
This is the right answer.
Oh, by the way, break in the car first.
Bboy AJ is offline   Reply With Quote
Old 10-19-2006, 09:22 PM   #5
dillsky
Member#: 109485
06 Blue TR
FP18g'd
I did forget to mention that!.......even though, i think i had stage 1 flashed at 600-650 miles. Probably a little to soon, but i just had that itch.
Old 10-19-2006, 10:17 PM   #6
faheyr12
Member#: 125999
2006 WRX TR
CGM
Thanks for the input. The car has been broken in, made sure of that with dealer recommendations and all the input on this website. Have about 3,000 miles or so on the car at this point in time. I guess the other two areas I am curious on are 1. Whether or not the upgraded turbo or external wastegate are initially necessary when purchasing a turboback exhaust along with engine management? and 2. What should I be expecting to pay if I were to do a full turboback exhaust with engine management, along with an upgraded turbo (i.e. 16G or 18g)? Thanks again for the help.
Old 10-19-2006, 11:09 PM   #7
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
I waited 'til 5k miles to mod my car....
give it time to make sure the factory didn't f anything up before you mess around with modifying the car.
AWD>FWD is offline   Reply With Quote
Old 10-19-2006, 11:19 PM   #8
blueribbon
Member#: 22668
2006 AE86 Levin it
NA1
I say you don't need EM until you upgrade turbo or want more out of your engine.
I have done a TBE with uppipe to free all the cats and made 225awhp and didn't need a tune but my friend at the time had the same mods and got a tune he made 250awhp so you can see the different. However getting your car dyno tune isn't cheap so if your low in the bank save the tune for major upgrades like stage 4.
Mike
blueribbon is offline   Reply With Quote
Old 10-20-2006, 12:03 PM   #9
REX8
Member#: 24038
Do all of you guys work for Cobb or something?
Honestly, this is getting retarded around here...
Old 10-20-2006, 12:22 PM   #10
deblas66
Member#: 114096
An upgraded turbo or an external wastegate are never necessary. Getting a TBE and EM will give you lots of power on the 06 and is a great upgrade. It in no way requires an upgraded turbo.
A full TBE with EM can run anywhere from 1 to 2 thousand depending on brands. An upgraded turbo will require an upgraded IC and (for safe measure) an upgraded fuel pump. The turbo, IC, and fp will run anywhere from 1500 to 2500.
deblas66 is offline   Reply With Quote
Old 10-20-2006, 01:02 PM   #11
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
Fine he could even get an EcuTek, you happy?
EcuTek is a custom flash done by a tuner, which makes it a very custom to your car specifically.
Black-Falcon is offline   Reply With Quote
Old 10-20-2006, 01:11 PM   #12
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Mike
Im sorry but this is just wrong. It may have worked great for you, but an 06 is a different beast then an 02.
If you're adding a TBE you really do need EM to control the boost more effectively, its not a pro Cobb or anti Cobb deal. The AP is just the most hassle free way of achieving EM and still maintaining OBD emission testing (which is important to those of us in emission tested states).
I agree with:
Start with Stage 1 (Cobb AP flash, maybe a CATBACK if you can afford it, do not add a downpipe or TBE in stage 1)
Stage 2 is next, a downpipe or turboback depending on what you did for 1 along with the stage 2 AP map
Stage 3 involves a turbo swap and usually an IC swap. The real common one is an STI VF39 with STI top mount. You can pick up these parts used here or on E-bay all day long. And again the approproate AP map.
There are MANY other forms of EM out there but most require a much more tech. savy/hands on approach then the AP. While I have no problem with the other forms of EM I dont want to have to lug a laptop with me everywhere I go, nor do I want to return my car to stock to have to pass an OBD emission test.
Sorry for the long winded post, I dont want to see someone pop a motor due to incorrect advice.
STiShawn is offline   Reply With Quote
Old 10-20-2006, 02:52 PM   #13
stealthydrew
Member#: 122765
06 WRX BEAST
steel grey metallic
ive got an 06 wrx with a headers back exhuast system, and sti top-mount. im using a utek delta as my EM. as the car sits right now im pleased, its making 1/4 mile passes in the 12s. i havent had a chance to dyno it yet, but i would say the hp is in the 310-320 range. also the car is still going rich at the top end.
you do not have to do a turbo upgrade unless you want to, the stock td04 is a decent quick spooling turbo, but lacks in the top end.
as far as em is concerned Cobb AP or Utek are the most populaar piggy back. both are excellect in there own respect. i choose the over the ap becuase i am fortunate enough to know people who can tune a u-tek well.
if you do decide to get a turbo upgrade, get a a wide band O2 sensor.
stealthydrew is offline   Reply With Quote
Old 10-20-2006, 02:59 PM   #14
mgsm666
Member#: 111683
05 Aspen STi
flying under the radar ;)
^^ its a uteC...you spent 900+ on engine management, and you con't even know how to spell it :wow: U....T....E...C...
~Jesse
p.s. Pick up an AP, see how you like it. Then get a turboback and flash to stage 2...see how you like it. If you want more top end power, and are willing to sacrifice some low end spool time (and spend a few $$), then go get yourself a turbo. You can do it all in small, relatively inexpensive steps. Good luck. Its fun
mgsm666 is offline   Reply With Quote
Old 10-20-2006, 08:33 PM   #15
momolicious
Member#: 128151
i thought downpipes were bad for 06 wrxs
momolicious is offline   Reply With Quote
Old 10-20-2006, 10:20 PM   #16
bourne
Member#: 119598
Nope. Just make sure that if you get a downpipe that you back it up with proper engine management.
bourne is offline   Reply With Quote
Old 10-20-2006, 11:40 PM   #17
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
Correct
TopEndPull is offline   Reply With Quote
Old 10-24-2006, 03:46 PM   #18
thehollowrift
Member#: 86788
04 STi
HYDRA!!!!!!! but that Engine management system will set you back at least 2800 after install + tune.
thehollowrift is offline   Reply With Quote
Old 10-24-2006, 04:12 PM   #19
hornyturbo
Member#: 108618
2010 10 RX350, 04 A4
12 IS350, 08 STI
ask your tuner what to go with. no sense in getting a Cobb AP if theres no pro tuners around
hornyturbo is offline   Reply With Quote
Question regarding newer tires on rear with less tread on front??? Nettalp Tire & Wheel 4 08-28-2009 09:57 AM
Star Wars People: Questions regarding General Grievous and Force Powers hikeeba Off-Topic 30 04-23-2009 08:48 PM
Question Regarding Modifications on an 06 WRX faheyr12 Newbies & FAQs 2 12-17-2006 10:26 PM
Specific question regarding exhaust modification Impresario Newbies & FAQs 7 10-15-2005 11:03 PM
Questions regarding first mods on an 05 STI. zasy99 Newbies & FAQs 25 05-23-2005 11:52 PM
