Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 10-19-2006, 10:51 PM   #1
Clark Kent
Member#: 75682
2004 WRX
Default TGV sensor the same as TPS sensor on 04 STi??
Hello,
I need to replace the TGV sensor, and as per scoobymoods, it is the same as the TPS sensor.....on a forester. I was wondering if it was the same on a 2004 STi. Thanks!
Ck
Clark Kent is offline   Reply With Quote
Old 10-19-2006, 11:28 PM   #2
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
I doubt it but I have a couple extra TGV sensors if you need one. 04 STi.
R0DENT is offline   Reply With Quote
Old 10-20-2006, 06:35 AM   #3
Clark Kent
Member#: 75682
2004 WRX
why would you doubt it? do the ones you have new or used? also, if you could, there are numbers pressed or stamped into the gray plastic of the part. Could you write them down or post a pic??
Thanks man! I REALLY appreciate it!!
Ck
Old 10-20-2006, 06:38 AM   #4
Clark Kent
Member#: 75682
2004 WRX
If anyone else has info or can confirm this, please post! I need to get the car running!
Old 10-20-2006, 09:31 AM   #5
TheMadScientist
Member#: 23717
2005 Big red
The Sti is DBW and the TPS sensor is intergrated into the DBW module. You need to use the cable throttle TPS sensor in place of the TGV sensor.
I all so have a couple of TGV sensors laying around.
TMS
TheMadScientist is offline   Reply With Quote
Old 10-20-2006, 03:06 PM   #6
vaj
Member#: 59136
04/5 APRWidebody STi
Parts all over the state!
Per scoobymods and my own personal experience with cracking/replacing the TGV sensor, the part listed on Scooby mods (DBC - TPS) is exactly the correct swap in for the tgv sensors on an MY04 STi.
TMS is correct. Not the first time.
Lemme guess, you busted the tgv when you were working on the turbo?
Good luck with this sensor. Get a buddy to hold stuff out of the way when you swap the tgv. It's tricky but managable. A flex socket handle and u-joint 7mm socket (teeny tiny craftsman kind) worked well for me.
vaj is offline   Reply With Quote
Old 10-20-2006, 03:07 PM   #7
vaj
Member#: 59136
but if you still have the turbo out, the sensor swap is cake.
Old 10-20-2006, 10:25 PM   #8
Clark Kent
Member#: 75682
2004 WRX
okay thanks guys! I was just nervous about it because I know the STi is a little more advanced than the wrx/ forester engine I wanted to make sure so I PMed Peaty himself and he confirmed it is the same sensor. I feel better, hehe. I was so nervous when it popped! I did remove the sensor already, so I just need to bolt the new one in.
How much are you guys asking for one shipped?
Which wire for TPS signal on 04 STI B136 17 or 18 roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-25-2006 09:34 PM
Are 04 sti wheels the same as 04 wrx ? WRX82 Tire & Wheel 8 02-09-2006 11:22 AM
04 sti Pink bits the same as 04 jdm oem? serious Brakes, Steering & Suspension 9 05-25-2004 12:34 PM
04 STI, are the strut tops the same as a WRX? Davenow Brakes, Steering & Suspension 2 01-12-2004 12:40 AM
Are 98-99 Rear Brake Assy. the same as a 2k1 on a RS? Deznuts05 Brakes, Steering & Suspension 4 04-21-2003 02:29 PM
