Old 10-20-2006, 12:43 PM   #1
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
Default Bellagio garden water acs - how do they work?
So I went to the Bellagio garden in vegas a couple of years back and was amazed by the streams of water that arced over one of the walkways.
What I'm talking about is the stream of water that crosses over the walkway. The arc is about 8ft high. It looks like glass.
It was so smooth that i didn't believe that it was water, until I stuck my hand into it.
So my question is, how does it work? The stream of water does not dispurse at all. No water drops come off it. It is perfectly even though the whole arc. How is that possible?
Heres the best pic I can find:
Sausage is offline   Reply With Quote
Old 10-20-2006, 12:45 PM   #2
Sausage
Member#: 104998
Old 10-20-2006, 12:49 PM   #3
24
Member#: 39142
Memb er#: 39142
Simple, there's no oxygenation in the water when it exits the nozzle.
24 is offline   Reply With Quote
Old 10-20-2006, 12:50 PM   #4
MidnightSti05
Member#: 74064
it uses water.
MidnightSti05 is offline   Reply With Quote
Old 10-20-2006, 12:51 PM   #5
Immerkuhl
Member#: 51358
2007 FXT
Once a month its blue.
Immerkuhl is offline   Reply With Quote
Old 10-20-2006, 01:00 PM   #6
pityr
Member#: 31719
surface tension and other cool properties of water...
pityr is offline   Reply With Quote
Old 10-20-2006, 01:01 PM   #7
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Its molten glass.
Cosworth is offline   Reply With Quote
Old 10-20-2006, 01:06 PM   #8
Mr.Sparkle
Member#: 83725
2015 WRX
I watched a Modern Marvels show on this on the Discovery Channel. They use compressed air to shoot the water out of small nozzles. They also showed how they do the complex water fountain shows they do, obviously all doen by computer. One cool thing they showed was how if you focused a light beam down the path of the water it follows the arc of the water, like fiber optic cable.
Mr.Sparkle is offline   Reply With Quote
Old 10-20-2006, 01:08 PM   #9
BhamRoadrunner
Member#: 87294
98 Silver
POS
I'd have thought that there was a process by which they remove the air though.
BhamRoadrunner is offline   Reply With Quote
Old 10-20-2006, 01:10 PM   #10
ArcticSun
Member#: 89066
03 MK4 TDI
Biodiesel FTMFW!
the jets are designed so that the water has absolutely no interior turbulance, that's what allows it to flow so perfectly and allow a beam of light to be carried through it (that and surface tension).
ArcticSun is offline   Reply With Quote
Old 10-20-2006, 02:00 PM   #11
Sausage
Member#: 104998
I would think so to, but after doing several projects that involve the mathematics of surface tensions and turbulance of water, I can't imagine how that's possible.
I woudl think it's something chemical or maybe they use distilled water.
IE: Water in the middle moves faster then water at the edge because of the friction between the water and whatever medium it's in. That causes it to dispurse as well as causes internal turbulance...
Old 10-20-2006, 02:03 PM   #12
Immerkuhl
Member#: 51358
2007 FXT
See my above link. Why dont you call and ask how they do it? I doubt they will give you the proprietary (SP?) run-around.
Old 10-20-2006, 02:09 PM   #13
Sausage
Member#: 104998
i checked it out... it's more about the company, less about the technology.
They said:
Visually joining the two water skins are a series of steady state
Laminar Streams. Apparently motionless, and with no splash or
sound, the parabolic water arches span from one water plane to
the other resulting in a delicate and crystalline water sculpture
that reflects the ambient light and seamlessly rests within the
center of the space.
No mention of how it's done
Old 10-20-2006, 02:09 PM   #14
WRXR7
Member#: 36442
2003 WRX
Sonic Yellow
WRXR7 is offline   Reply With Quote
Old 10-20-2006, 02:10 PM   #15
limestoner
Member#: 35490
97 Impreza 2.2l
slow.
physics.
limestoner is offline   Reply With Quote
Old 10-20-2006, 02:11 PM   #16
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
I saw the same show. It was fascinating.
imprezton is offline   Reply With Quote
Old 10-20-2006, 02:49 PM   #17
Sperm
Member#: 25038
2002 PSM WRX sedan
Same here.
Sperm is offline   Reply With Quote
Old 10-20-2006, 02:53 PM   #18
MPRZIV
Member#: 49306
Originally Posted by JSpych View Post
Same here.
me too...it was awesome
MPRZIV is offline   Reply With Quote
TD05 18G 7cm2 turbo: who has one and how do they work out for you? GDAryder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 09-22-2008 01:20 PM
Strut tower bars - How do they work? Alan l. Brakes, Steering & Suspension 18 11-02-2006 04:02 PM
Fuses ? how do they work ? Extraze Electrical & Lighting 3 04-12-2004 01:50 PM
Koni Inserts...how do they work? HiVoltg12 Newbies & FAQs 3 02-11-2004 04:56 PM
Adjustable sway bars - how do they work? tomrichardson Brakes, Steering & Suspension 5 05-03-2001 01:56 AM
