#1 |
Member#: 15669
TXIC
Vehicle:2009 Cadillac STS-vvvvvvvvvv |
I wouldn't even know how to try
![]() Here she is, in just about complete form. I have a few more things to put on, but appearance wise she is just about the way I want her. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Mod list Power adders * Gimmick Motorsports 3 pulley kit (lightweight flywheel safe) * Gimmick Motorsports custom cast maf housing/velocity stack * HKS Downpipe * Invidia Titanium Cat-back * Cusco Exhaust Hangers * Turbo XS UTEC * Turbo XS Tuner Pro Bosch\ * Turbo XS Map Selector * Walbro 255lph fuel pump * Turbo XS Map Selector * Power Enterprise V-mount * Gimmick Motorsports tune * PNP, lightened and wrapped manifold * Gimmick Motorsports 321ss uppipe * Forge Recirc BOV * Forge wastegate actuator * Gimmick Motorsports prototype air/oil separator Suspension and drivetrain * Cusco Zero 2r coilovers * Cusco Titanium front strut bar * Cusco CF rear strut bar * Cusco rear V-brace * Cusco Master Cylinder bracket * Cusco GC VII lower arm bar front * Cusco rear pillowball trailing arms * Cusco rear lower arm bar * Cusco Rear camber adjustable pillowball top hats * Cobb front and rear hollow sway bars * Progress front and rear camber kits * Aluminum endlinks front and rear * TIC rear diff bushings * TIC Rear subframe mount kit * TIC Shifter bushings * TIC Linkage bushings * TIC Clunk killer * Whiteline subframe lock bolts * Whiteline steering rack bushings * Kartboy short shifter * Group N engine mounts * Group N trans mount * Group N Pitch mounts * ACPT Carbon fiber driveshaft * Stoptech 355mm front brake kit * Stoptech stainless rear brake lines Interior and electronics * Kenwood KDC-MP7026 CD player (temporary so I can use MP3 disc) * Sparco Harness bar * Sparco 3" 6 point harnesses * Sparco lap 5 steering wheel * Hardwired Valentine 1 * Odyssey 680mjt battery * Custom grounding kit * Arospeed XCS box * Titanium 26% tint * Auto dimming mirror * Defi 60mm triple pod * Defi 60mm BF boost, oil pressure, egt gauges and controller * Sti Limited leather door panels * JDM Black/metal look dash trim Bling and rolling stock * Full deluxe clear shield with custom back pieces * CF hood dampers * Completely debadged all around * Ravspec cf roof spoiler * Vinyl Grafics from Gimmick Motorsports * 18x9 Enkei RC5 custom color matched to car * Michelin Pilot sport PS-2's 255-35-18 * Custom Radiator/intercooler shroud * Forge Polished aluminum coolant tank * Forge polished aluminum P/S resevoir * light grey interior parts, and headliner custom suede * Custom black rear seats and door panels * JDM Spec C mesh grill * Reverse scoop * Carbon Creations Trunk * Custom black cluster trim * Spec C black interior dash trim * STI limited rear spoiler * Blacked out headlights * 6000k HID Bulbs * Evo 8 front lower mesh grill * STI limited rear lip spoiler * 2.5i hood Shaved over 332.4+lbs so far... Pending... Jet hot sterling intake manifold and TGV deletes (need to install) 800cc PE injectors SARD fuel rails HKS FPR APS Rotated kit Cusco twin plate clutch GT Spec fender braces Audio system??
#2 |
Member#: 125975
do it bro. this is one of the sickest cars here. the build up is awesome from begining to end. i would actually buy that mag just to read it all over again, plus your thread is like 500 pages long. good luck.
#3 |
Member#: 30610
Vehicle:1996 WRX STi Type R 555 Blue |
On page 18 of the December 2006 issue, it tells you how to submit your car.
#4 |
Member#: 15669
TXIC
Not sure of the validity, but apparently Im in the readers rides of the current issue.
![]() I am not sure cause I just set up my subscription and have yet to get a issue... |
| Thread Tools | |
| Display Modes | |
| red light ticket, need help to see if i can get it dismissed | 949 | South East Region Forum | 14 | 12-29-2008 07:23 PM |
| We should see if we can get Fisher-Price to sponsor OT | Davenow | Off-Topic | 19 | 03-29-2006 07:43 PM |
| OT: See if you can get past level three! | kracka99 | Canada Region Forum | 8 | 11-01-2005 01:17 AM |
| See if you can get this question... | txl146 | Off-Topic | 15 | 07-15-2005 09:54 PM |
| hey NY, OT'er from so. cal here... see if you can help me out.. | skimmilk68 | Tri-State Area Forum | 6 | 12-20-2004 12:22 PM |
