Old 10-20-2006, 02:55 PM   #1
IIdiceII
Member#: 90438
Default When turning left, rear right grings, when turning right, rear left grinds!!
Ok well heres the story.
I replaced BOTH rear hub assemblys on my 2002 wrx sedan about 2 months ago.
I bought the hub assemblys used. (hub,knuckle/housing, wheel bearings bla bla.)
At the time I had kyb agx's with tanabge gf210's. i didnt get an alignment but i drove the car for about a week and all was fine except a rubbing noise that seemed like my tires were rubbing (rota torques with 225/45 reo70's)
about two weeks ago i replaced the springs and struts with used JIC flta1 coilovers which are in good condition, less than 10k. I get em in, play with the camber in the rear a little so theres no rubbing and go for a couple test drives.
there were these "grinding" sounds coming form the rear wheel areas. both left and right while turning.
If I turned left it come from the rear right etc.
I finally got my car aligned yesterday as well as got some new inner tie rods installed.
final alignment settings were 1.5 up front, 1.25 rear, o toe all around.
but the grinding sounds seemed to have gotten worse.
so i pulled the rear rotors off to inspect the ebrake assembly, shoes etc. and didnt really notice any rubbing marks. I was told this was the most likely thing because the sound really indicates the rear drums.
I was told its not a wheel bearing, cv joint or the wheel rubbing as the sound clearly indicates none of these.
anyone have ANY clue what the hell it is? or what I should do to try and fix it?
it doesnt really slow the car down while the sound is happening. it only happens when i make sharp turns when theres a load put on that side of the car.
im truly stumped right now lol. ill try and take a vid and some pics of the rear right and rear left to show ya what im working with.
-Alan
just for the guys whos dont like to rear.
2002 wrx sedan. JIC flta1's. grinding from rear right and left when turning sharp. NOT wheel rubbing or wheel bearings.
IIdiceII is offline   Reply With Quote
Old 10-20-2006, 06:50 PM   #2
IIdiceII
Member#: 90438
anyone?
Old 10-21-2006, 02:13 AM   #3
IIdiceII
Member#: 90438
aaahhhhhhhhh
Old 10-21-2006, 09:17 PM   #4
T_A_C_H
Member#: 100196
2007 STI
pmmed you
T_A_C_H is offline   Reply With Quote
Old 10-22-2006, 03:19 AM   #5
IIdiceII
Member#: 90438
thanks for the PM...ill try that out.
Old 10-22-2006, 01:16 PM   #6
devil13
Member#: 80559
2011 WRX
sure your rear wheels aren't rubbing?
devil13 is offline   Reply With Quote
Old 10-24-2006, 04:33 PM   #7
IIdiceII
Member#: 90438
yea theyre def not rubbing...i got it aligned and there's plenty of clearence.
its not really a rubbing sound as the guys that did the alignment all agreed theyve never heared rubbing wheels make this sound lol.
Metal on metal sound from rear passenger wheel when making Left turns The_Triton Brakes, Steering & Suspension 2 06-09-2008 07:13 PM
Pulling to Right and Resistance Turning to Left OsirisNEB Brakes, Steering & Suspension 2 06-08-2008 03:08 PM
06 WRX - Right Rear Wheel Noise - Thumping Turned to Squeal? kpluiten Newbies & FAQs 5 05-28-2007 12:22 PM
Rear suspension clunk when left/right load is not balanced?? wayoutwest Brakes, Steering & Suspension 10 07-30-2004 12:35 PM
Are rear wheels supposed to turn when car is up in air in gear? ImportVenom Newbies & FAQs 7 11-10-2003 02:11 AM
