Old 10-20-2006, 04:50 PM   #1
rocket468
Member#: 105959
Default Alcohol Injection Nozzle selector tool
Alcohol Nozzle size Calculator
This should give you an idea what size nozzle you need with all the alcohol Injection kits out there. Even an DIY kit. This is still kinda a beta on the figures so if anyone could give me feed back I would greatly appreciate it.
rocket468 is offline   Reply With Quote
Old 10-20-2006, 05:38 PM   #2
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Nice! Clever tool. I will have a play very soon.
Aquamist is offline   Reply With Quote
Old 10-20-2006, 05:42 PM   #3
rocket468
Member#: 105959
thanks, I plan to add more options for blower/turbo efffecy etc. Thats why i do have the assumed cfm listed and the assumed btu. It can only do so much when it does not know actually Ait and cfm. I did not want to run this off injector size, like another one of these i saw floating around. because what stops someone from shoving injectors to large for the app. You start getting into high hp per cubic inch and this gets off.
Old 10-20-2006, 07:28 PM   #4
hippy
Member#: 36528
2002 Impreza Wrx
Pretty cool, but I'm lost as to how it comes up with the required flow when there's no input for injection to petrol % and max pump pressure.
peace
Old 10-20-2006, 08:52 PM   #5
rocket468
Member#: 105959
Hippy, We use a custom made pump, we wanted this to be generic "useable" between other systems. 1 gallon of fluid at 1,000 psi is still 1 gallon of fluid. So people need to be aware of what pump they plan on using when using this. And what the nozzles is rated at for that given psi. Also nozzle size will effect pressure. And most people don't understand this. So I did not put our pumps flow data into it. So that number is the amount of fluid needed. I probley should re word it to make it more clear.
Also this does not take into effect adding extra fuel with the meth kit. This is the amount of fluid need to remove the assumed heat thats being generated by compression of the air. Now some compressers are more effecent than others. this atm is not a varable, Which will be latter. I need people to email me the stats so i can plug them in my db.
Old 10-20-2006, 10:31 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
I understand what you're sayin about pressure, and I agree. I don't agree about injection percent, and this is why. Not everyone wants to run the amount of injection you think they should run, and people who run run 5% water to fuel will want a nozzle that flows about a third of the water of a nozzle that someone who has the same setup and runs 15% water to fuel would want. Your little device has a build in figure that assumes everyone wants to run the same injection to petrol percent, and this is not the case. This value needs to be adjustable for people to be able to pick a given nozzle for a given setup and tune.
peace
Old 10-23-2006, 01:21 AM   #7
oldhat
Member#: 113036
Try writing your own app, then.
oldhat is offline   Reply With Quote
Old 10-23-2006, 06:47 AM   #8
hippy
Member#: 36528
2002 Impreza Wrx
I'll get right on that since I am a software programmer and know exactly how to do that. For what it's worth, your post is the most useful thing I've seen anyone post in years. Thanks for all your time and consideration when thinking about what to post and the way you explain yourself. Whenever I need help, I'm gonna send you an e-mail so you can tell me what to do.
hippy
ps-Try sticking your sarcasm where the sun don't shine....
Old 10-23-2006, 02:10 PM   #9
klattery
Member#: 48503
2004 STi ATP3071
How about a percent alcohol to water feature? I would think water only would require less than 50/50 which would be less than 100% alcohol.
Does yours assume 100% alcohol?
klattery is offline   Reply With Quote
Old 10-25-2006, 01:09 AM   #10
rocket468
Member#: 105959
Im not a software programer, I had the caculations just getting it into the exe and it looking good was not easy for me. I do plan to make some changes to this.
klatery this assumes a 50/50 mix. Its not going to make the world of differnce between straight water and straight meth, because this is only giving you a value for geting your ait down. With runing higher amounts of meth you can run a larger nozzle especially when you pull fuel. Any ohter questions let me know.
Coolingmist WI tap for injection nozzles Q's AXA Water/Methanol Injection, Nitrous & Intercooler Cooling 1 06-25-2008 02:56 PM
Alky / Water injection Nozzle install on FMIC Bad Noodle Water/Methanol Injection, Nitrous & Intercooler Cooling 4 06-14-2008 04:46 PM
Alky Injection nozzle on 2.5" FMIC pipe. metoo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 12-27-2006 12:36 PM
Water Injection Nozzle location WhiteKnight Water/Methanol Injection, Nitrous & Intercooler Cooling 23 11-16-2005 02:16 PM
alky injection nozzle, point up or down? nuhga Water/Methanol Injection, Nitrous & Intercooler Cooling 2 11-16-2005 10:21 AM
