Old 10-20-2006, 09:23 PM   #1
Mean
Member#: 12116
2002 Impreza WRX
Sedona Red Pearl
Default Shift Rod Seal Leaking
So I am having a local shop change my clutch and they called because they noticed evidence of fluid leaking from the seal where the shift rod enters in the rear. Anyone else have this problem? I am trying to track down a part number just to get the job done faster. It isn't huge but you can definitely see it. Might as well do that while the tranny is sitting on the bench.
Thanks,
G
P.S. It is a 02 WRX with 51K miles.
Mean is offline   Reply With Quote
Old 10-22-2006, 01:32 PM   #2
Mean
Member#: 12116
2002 Impreza WRX
Sedona Red Pearl
Can I assume that no one has ever had this problem?
G
Old 10-22-2006, 04:42 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
funny you should mention that - I was under my car yesterday and noticed that the shift rod had some oil on it (there was enough that the spring pin had about a drop of oil held in it) - it looked wet, but hadn't really dripped everywhere or anything like that.
Old 10-22-2006, 05:27 PM   #4
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
I had it quite early on in my 02 - fixed under warrenty
RE & RE TRANSFER CASE AND REPLACED SHIFTER SEALS
1......803926070......GSKT-26.3X30
1......028................75W90 GEAR-O
1......10953463........BRAKE CLEAN
1......44022AA180....GASKET T OUT
The second gasket is the turbo-downpipe one so they obviously dropped the exhaust to get access to the back of the case. I assume 'RE & RE' stands for 'remove and refit'
UkNuck is offline   Reply With Quote
Old 10-22-2006, 10:38 PM   #5
SubeTek
Member#: 1714
1999 RS-T COUPE
You have to remove the transfer case to properly remove/replace the selector shaft seal. I see them leaking all the time, just usually not bad enough to warrant the cost/labor of replacement.
SubeTek is offline   Reply With Quote
Old 10-23-2006, 08:06 AM   #6
Mean
Member#: 12116
2002 Impreza WRX
Sedona Red Pearl
Just something to do when the tranny is out for a clutch change then. Luckily, that is my situation.
Thanks,
G
Old 10-23-2006, 07:23 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I believe the part number is 806718100.
Tim Sanderson is offline   Reply With Quote
Old 10-23-2006, 11:45 PM   #8
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
so could you remove the extension case without removing the whole transfer case assembly, or is that a no-no (I haven't done anything which has involved removing/taking apart the transmission, so I bet there are things which you can't put back together that way or something...) - I am still inside my 5/60 powertrain, so I'll probably ask the service dept. about it at some point...
Old 10-24-2006, 08:55 AM   #9
SubeTek
Member#: 1714
1999 RS-T COUPE
the seal is pressed into the transfer case section, so you relly should remove the transfer case to properly replace the seal.
Old 10-24-2006, 10:44 AM   #10
Mean
Member#: 12116
2002 Impreza WRX
Sedona Red Pearl
I think it is 806935010.
Here is the link to the parts lookup on Subaruparts.com:
http://www.subaruparts.com/diag/?mod...category=130-1
It is the only seal listed under Mt, Shifter Fork & Shifter Rail. You need to register to see these pages.
G
Old 10-24-2006, 12:01 PM   #11
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
G
That's an o-ring, not a seal. If you pull the transfer case you'll need 32145AA030 also. It's a gasket. Look in transfer and extension section. The top picture you'll see part number g7181. That's the seal you need. It comes out to be 806718100.
Old 10-24-2006, 06:46 PM   #12
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
so pressed in with an actual press, then?
Old 10-24-2006, 11:46 PM   #13
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
No. Before you remove the existing one, measure the install depth. Then you can use a socket that's a hair smaller than the o.d. of the seal to drive it in.
Old 10-25-2006, 08:55 AM   #14
Mean
Member#: 12116
2002 Impreza WRX
Sedona Red Pearl
Just as an update, the dealer is being a little slow getting the parts but all should be done today. Woohoo!
G
Old 10-25-2006, 07:45 PM   #15
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Mine seeps a little also.. Has for a long long time. Never gotten worse. I didn't worry about it.
subbyspeed is offline   Reply With Quote
Old 03-04-2010, 10:41 AM   #16
03Rextacy
Member#: 239497
2003 Impreza WRX
Mine has completely destroyed itself. This will be my project this weekend. All I can gather is I need the seal, and the transfer case gasket? I'd like to only make one trip to subaru..
03Rextacy is offline   Reply With Quote
Old 03-06-2010, 09:16 AM   #17
03Rextacy
Member#: 239497
2003 Impreza WRX
Is there anywhere I can find a write up for this seal? I can't find a chiltons nor a haynes for a rough around the edge way to go about it. I've dropped my driveshaft, exhaust and x-member thus far. Removed shifter linkage, and have removed tail piece of transmission. The seal is in the middle piece of the trans. Does anyone know if I can remove the seal where it is in place. ( the selector rod is still in place) or do I have to remove the middle section as well?
Old 03-06-2010, 07:40 PM   #18
03Rextacy
Member#: 239497
2003 Impreza WRX
Not that i know if anyone is still looking for any of this how to information for themselves. I finished this repair just a couple of hours ago. Would anyone care for a write up? Minimal pics, only because the car is back together already.
Old 03-27-2010, 09:44 PM   #19
gerholdwrx
Member#: 154198
Write up would be great! More importantly, how did you manage to line the shifter rod up so that it moves freely through the gear shafts? Every time i fit the transfer case up to the trans, the shifter rod gets stuck.
gerholdwrx is offline   Reply With Quote
Old 04-17-2010, 01:11 PM   #20
DrunkenDragon
Member#: 21471
BUmp! HOW do I get this seal out?
DrunkenDragon is offline   Reply With Quote
Old 04-18-2010, 08:03 AM   #21
anon_az
Member#: 160782
2004 Impreza WRX STi
I'm not familiar with that exact seal, but I've always gotten my other seals (crank seal / cam seals) out with one of two methods (I can't heartily recommend either since they're both risky in a sense, but they work damnit!) : a small pick set (be very careful not to scrape the mating / sealing surface!!) or a couple of wood screws and pliers. It sounds ghetto, but it was the only way I could get a cam seal out that someone had RTV'd into place I screwed a screw in at 9 o'clock and 3 o'clock on the seal just so a couple of threads took hold and then yanked on them alternately and the seal came right out. Again, be damn sure you don't screw in too far or too close to the edge, you may scratch the smooth surface which the seal sits on and cause a leak.
anon_az is offline   Reply With Quote
Old 01-18-2012, 01:41 AM   #22
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Has anyone replaced this seal? Any writeups? PN 806718100.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 01-18-2012, 01:52 AM   #23
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^yeap, seal pictured in yellow G7181 PN 806718100, post #25.
Old 01-18-2012, 11:40 AM   #24
buster
Member#: 41811
02 WRX
I have an open t case and can take a pic if you need.
buster is offline   Reply With Quote
Old 01-18-2012, 12:49 PM   #25
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^Yes, please. Since the seal G7181 PN 806718100 is housed in the middle trans assembly (below exploded view), can you split open the middle assy without having to unbolt the rear trans cover? Do I need to replace also the G318001 bushings or whatever those cylinders are?
Shift Shaft Seal leak?? Anyone heard of this? Sleazy E Service & Maintenance 2 05-14-2009 02:49 PM
Which shifter do you run and does your shift selector seal leak? DS1 Transmission (AT/MT) & Driveline 22 07-31-2008 02:11 AM
Shift Rod Seal Leaking Mean Service & Maintenance 1 10-23-2006 06:47 PM
crankcase seal leak 96GreenLX Service & Maintenance 5 06-17-2004 05:24 AM
Transaxle seal leak pfhlipwrx Brakes, Steering & Suspension 2 10-10-2003 04:49 PM
