Old 11-08-2001, 02:13 PM   #1
fourwheeldrift
Member#: 11967
97 OBS
Question 1997 OBS Oil Leak
My 1997 OBS is leaking oil from around the timing cover. Is this somethng that needs attention immediately? Also there is a ticking sound coming from the same area most noticeable as revs drop when lifting off gas. Water pump? The car has 94k miles on it. As long as i'm not overheating and keep oil in the vehicle can I postpone the timing belt fix ( i assume when the timing belt is replaced the oil leak will stop with a new gasket.) If the belt breaks and i am stranded no problem, just don't want to damage the engine. Any advice is appreciated.
Thanks in advance,
Ben
fourwheeldrift is offline   Reply With Quote
Old 11-08-2001, 03:46 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
if the belt breaks... BIG PROBLEM
trust me.. u dont want that.
get it fixed now or cry later.
likely it's the seal on the timing cover -
take it in.. get it fixed....
best advice i have for ya
j.
www.subiegal.com
Old 11-08-2001, 05:04 PM   #3
fourwheeldrift
Member#: 11967
97 OBS
Default problem?
I thought the 2.2 was a "non-interference" engine. Are you saying that if the timing belt breaks i will crush my valves etc...?
Old 11-08-2001, 06:58 PM   #4
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
In '97 Subaru increased compression and the motor became an Interferance Motor. One reason for this change was the very broken Cam Belts on the EJ motors.
A common source for an oil leak behind the Front Cover is the Front Crank Seal. You should have the problem taken care of before the oil soaks the Cam Belt.
"Pay me now (a little) or pay me later (a lot)."
SubyTechMaster is offline   Reply With Quote
Best diagnose/fix for 98 OBS 70k mile oil leak? newrxnj Service & Maintenance 5 10-08-2004 01:40 PM
1997 OBS brake conversion? walnats Brakes, Steering & Suspension 6 05-28-2002 01:28 PM
2.2L (EJ22) 1997 OBS Interference or Not? fourwheeldrift Service & Maintenance 1 11-16-2001 03:41 PM
('93-'01) 1997 OBS ---> 1998 OBS What's Different??? SportRacer Impreza Forum 2 04-24-2001 10:31 PM
97 OBS Oil Leak llonman Technical Forum Archive 5 08-02-2000 10:30 AM
