#1 |
Member#: 7996
Vehicle:1980 Human Biped Flesh tone. |
#2 |
Subaru Bounty Hunter
Moderator Member#: 7131
TXIC
Vehicle:2008 STi DGM (3rd STI) prev 05 STi (white) |
10:5:1 if I'm not mistaken...
#3 |
Friendly Neighbourhood
Moderator Member#: 269
VIC
Vehicle:2005 ABP LGT LTD BP6 00 Impreza RS GM6 RIP |
That info is in there too, along with other vital information.
LaterZ! Darren!! |
#4 |
Member#: 11931
Vehicle:2001 2.5 RS Turbo 257/FMIC/T3-T04S |
I know the 01 RS's are 9.7:1, I would be suprised if it was higher than ten for the 2000 model.
Graham |
#5 |
Member#: 9213
Vehicle:2000 RS Red |
I thought the compression ratio for the 01 rs was 10:1?!?!
#6 |
Member#: 1911
Vehicle:2000 Impreza 2.5RS Silverthorn Metallic |
9.7:1 for 98-99, 10:1 for 00-01 (and probably for 02).
Ben |
#7 |
Member#: 9015
Vehicle:2002 Impreza 2.5RS Platinum Silver Metallic |
It is indeed 10:1 for the MY02 RS. The recent car and driver issue has lots of specs you might want to know.
#8 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
the 02 RS's are 10.0:1 as well as the MY00-01. They made no changes because they have gotten what they wanted out of the motor.
Jeremy |
#9 |
Member#: 251
Vehicle:1998 Impreza 2.5 RS Black |
What would the compression ratio be for the Phase 1.5 motors? My '98RS has DOHC heads w/ SOHC block.
Thanks, -Chris |
#10 |
Member#: 1911
Changing the heads on the EJ25 doesn't change the compression ratio. You'll still be at 9.7:1.
Ben |
#11 |
Member#: 251
Cool, thanks.
-Chris |
#12 | |
Member#: 8465
NWIC
Vehicle:'00 2.5RS Coupe, AW '93 GMC Typhoon AWD |
-- Richard http://www.whitetyphoon.com/impreza/ |
#13 |
Member#: 251
The tech that installed my new engine thought the compression was raised, since the SOHC engines are higher now. I hope not. I think I'll ask him to find out what it is when I drop my car off to fix the valve chatter. It wasn't a problem on my original DOHC engine, but this new Phase 1.5 engine is loud as hell.
Btw, nice Typhoon Richard! When I finally buy a house in the mountains and need an SUV, I'm buying a Typhoon... -Chris |
#14 |
Member#: 1871
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
I believe the heads do affect the compression ratio. 98's and 99's(all 99's, that I am aware of) are both labeled as 9.7:1 compression. and since the block changed mid-99, but the compression did not, it is not something to do w/ bore or stroke. The only other option is the pistons themselves, which did get redesigned, but the heads were a more significant change...
#15 |
Member#: 1911
I believe they changed the pistons. Can someone with detailed knowledge comment?
I am aware of how compression ratio is calculated, but I sepcifically said that THIS head swap on THIS engine shouldn't change the ratio. Ben |
#16 |
Member#: 251
Actually, I think Subaru changed the block mid-98, as mid- to late-98 2.5L owners have the Phase 1.5 from the factory.
-Chris |
#17 |
Member#: 1871
I thought the block changed in 99... I could be wrong about that... i also realized my other mistake... I think they went to SOHC in 99, not 00, right? 00 was the year they switched to MAP... sorry, my bad
| Thread Tools | |
| Display Modes | |
| Compression ratio? | Naturally Aspirated | Normally Aspirated Powertrain | 31 | 11-30-2003 10:37 PM |
| ('93-'01) what is the compression ratio on a... | wop | Impreza Forum | 9 | 06-15-2001 05:34 AM |
| Boost and compression ratios | 98mpreziveRS | Normally Aspirated Powertrain | 4 | 03-29-2001 06:58 PM |
| Compression Ratio for 98-01 RS | Delhi | Normally Aspirated Powertrain | 4 | 03-14-2001 03:00 PM |
| Compression ratio question | fellfrosch7 | Normally Aspirated Powertrain | 12 | 03-14-2001 12:43 AM |
