Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-08-2001, 03:56 PM   #1
PURE EPI
Member#: 2642
Default Crankwalk???
can someone please explain what this means?
PURE EPI is offline   Reply With Quote
Old 11-08-2001, 05:18 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
will never happen on a horizontally opposed engine.
try reading some DSM sites, they're very familiar with the problem especially the 2nd generation.
ColinL is offline   Reply With Quote
Old 11-08-2001, 05:25 PM   #3
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
basically, int v and i engines the pistons want to push the crank out of the bottom of the block, but at different times during the rotation... eventually things can wear and the crank starts to walk or wobble and that's bad... since the H configuration pushes back and forth instead of down down down, we don't have that problem... also our cranks are much shorter(haha... I just realised how funny that sounds) so there even less chance of it happening...
mrbell is offline   Reply With Quote
Old 11-08-2001, 05:30 PM   #4
lgkahn
Member#: 9793
2002 2010 legacy gt
red
why did the 1st generation talons and eclipses (I had a talon) not have this problem???
lgkahn is offline   Reply With Quote
Old 11-08-2001, 05:46 PM   #5
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Because the piston oil squirters on the 1G cars drew their oil from the main oil gallery, while the 2G car squirters drew their oil from the same source as the thrust bearing. These squirters had extremely high variability in their opening pressures, made worse by dirt and time, and they would start opening at idle oil pressure, starving the bearing of oil.
Ben
bsquare is offline   Reply With Quote
Old 11-08-2001, 05:56 PM   #6
wRx14pSi
Member#: 6203
basically its just that Mitsu manufactured cranks that are like a few millimeters short. Over time due to a few millmeters difference ,witht he crank spinning will cause wear on the bottom end of the engine. So basically the crank just dremels its way out of the housing Like slowly walking out of the housing. Hence the name "Crank walk".
wRx14pSi is offline   Reply With Quote
Old 11-08-2001, 06:17 PM   #7
PURE EPI
Member#: 2642
Talking WHOO HOOO!!!
God bless the I-Club!!! an endless supply of knowledge!!!
Old 11-08-2001, 07:09 PM   #8
bsquare
Member#: 1911
2000 Impreza 2.5RS
I've never heard this, and it seems like engine builders would notice it quickly and use 1G cranks in 2G blocks (which they don't). Where did you hear it?
Ben
Old 11-09-2001, 12:14 PM   #9
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
The problem wasn't just the crank difference, I think it also had to do with the block and/or bearing manufacuring problems. It's too bad, really, beacause those later gen, not the current model, Eclipses were really nice looking cars, but they only ran well when they didn't have problems, and that wasn't very often.
HondaH8er is offline   Reply With Quote
Old 11-10-2001, 11:20 AM   #10
skeptik
Member#: 3055
my04 sti
blue and gold
read about this awhile back on this page. here's an excerpt from one of the posts:
"Apparently, the factory had a bad run of CRANKSHAFTS, not bearings. The crankshafts were machined just slightly out of spec, and as a result the main center thrust bearing on the crankshaft wears prematurely. When this happens, the crankshaft will move or "walk" every time the clutch pedal is depressed. Some people have complained of difficulty in getting the car into gear (manual transmissions) and the diagnosis has been the same: a "walking" crankshaft. Well, it seems my crankshaft walked so much that it pushed the crank sprocket and the trigger plate forward and caused the trigger plate to come in contact with the crank sensor."
very sad story
mark
skeptik is offline   Reply With Quote
crankwalk. How much is too much? kalescustom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-09-2007 09:27 PM
DSM owners! A cure for crankwalk! soundwave Off-Topic 10 09-19-2004 08:42 PM
