Alaskan Impreza Club
Old 10-22-2006, 11:10 PM   #1
edo2000
Member#: 68709
2012 WRX
red
Default More turbo troubleshooting...advice needed.
I'm still trying to help out my friend whose 04 wrx got sick recently. The turbo locked up on him, so we found a used TD04 and put it on.
The car started making boost with the new turbo, but it is still sick. When I drove it, the symptoms were:
1) Much noisier intake sounds than my car (which is also an 04 wrx).
2) When you go WOT, boost builds slowly and never goes above 5 lbs or so.
After searching on NASIOC, we tried a couple of things:
1)We pulled the boost control selenoid and tested it with a 9V battery, it seemed to work perfectly.
2)To check the wastegate actuator diaphragm, we replaced it with the one off the locked up turbo, the car acted exactly the same...
I'm starting to wonder if something else other than turbo & boost control, is wrong with the engine.
Any suggestions? If he had a serious engine problem like low compression, etc., could it act like this? Any advice would be appreciated.
I'm recommending that he take it up to Conti or SIAS for diagnostics. I don't think we have anyone here in Soldotna that knows much about the wrx.
edo2000 is offline   Reply With Quote
Old 10-23-2006, 12:11 AM   #2
prometheum
Member#: 92003
04 bicycle!
maybe a boost leak perhaps? in the 2.0L forum there was a thread on how to make your own tester using some pvc pipe and a valve stem
prometheum is offline   Reply With Quote
Old 10-23-2006, 01:08 AM   #3
ponamy
Member#: 115511
2005 wrx /w babyseat
2015 Legacy
schucks sells leak testers, for around 40-60$or you can make your own with what prometheum said
ponamy is offline   Reply With Quote
Old 10-23-2006, 01:25 AM   #4
edo2000
Member#: 68709
2012 WRX
red
Thanks guys, I'll check on the leak test idea.
Old 10-23-2006, 02:13 AM   #5
ponamy
Member#: 115511
2015 Legacy
i work at schucks in fairbanks, i can check on the price tomorrow for you if you want me to, too bad i dont live in anchorage, i could pick one up for you at the employee discounted price
Old 10-23-2006, 02:44 AM   #6
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
a ciggerette is cheaper and works better, just take a drag, and blow it into the brake booster nipple, or the pcv hose depending on whether you want to check pressure or inlet side.
o yeah, and look for the smoke
00Maddog is offline   Reply With Quote
Old 10-23-2006, 03:43 AM   #7
ponamy
Member#: 115511
2015 Legacy
well fooey, just buy some cigarettes then, cancer good, boost leak tester bad!!!
Old 10-23-2006, 03:48 AM   #8
Jaylyons1
Member#: 113884
1989 Skyline GT-R
lol, hmm smoking helps with something afterall!
Jaylyons1 is offline   Reply With Quote
Old 10-23-2006, 04:01 AM   #9
prometheum
Member#: 92003
04 bicycle!
hypothetically couldn't you just pull out one of the hoses in the turbo inlet hose and stick the cigarette in there and have the car doing all the sucking for you?
Old 10-23-2006, 04:44 AM   #10
ponamy
Member#: 115511
2015 Legacy
sure if the line you hook up to has a vacuum just stick the smoke in and see where the smoke comes out lmfao
Old 10-24-2006, 02:51 AM   #11
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
hahaha Jerry is just too cool. He's cooler than the camels. Too bad he smoke's marb lights. Right cowboy?
Arctic Assassian is offline   Reply With Quote
Old 10-25-2006, 11:01 PM   #12
04Aspenwaggy
Member#: 93614
When this happened to ours (before we sold it, while it was still under warranty) we took it in and originally it was the tumbler valve, after driving it for a little while, we took it back and they had to put a new ECU into it.
04Aspenwaggy is offline   Reply With Quote
EZ30 sequential turbo build. Advice needed. Rs30 Subaru Conversions 3 03-19-2010 03:25 AM
Need some troubleshooting advice and help MyRedScooby North West Impreza Club Forum -- NWIC 12 07-03-2008 10:32 AM
Audio Experts--Troubleshoot Advice Requested JT99 Car Audio, Video & Security 13 04-15-2008 01:04 PM
Flawed turbo logic? Adviced needed. JayZ28 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 08-15-2005 08:57 PM
Turbo system troubleshooting help needed... Rovah New England Impreza Club Forum -- NESIC 0 05-03-2002 11:23 PM
