Welcome to the North American Subaru Impreza Owners Club Tuesday July 29, 2014
Old 10-23-2006, 02:02 AM   #1
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Default Element Gt52 tuning notes - great unit
Tonight I was tuning a 2006 STI with the following mods
Gt52 Turbo
TX's fmic
850 injectors
Walbro 255 pump
3" exhuast
Dyno Flash custom reflash tune
What a nicely balanced turbo this is
First full pull after some initial dialing in was at 20 psi and the Tq curve was a nearly FLAT 350 on a dyno dynamics dyno
Sadly, with 21 psi I maxed out the stock mass air flow meter - 370 whp and a really nice looking power curve
I am ordering a BIG MAF for the customer tomorrow and will see what it maxes out at in the next few days.
It looks like a nice 375 whp pump gas tubro with 15 psi of boost at 3600 and 21 psi at 4100 rpms
Basically my summary is a turbo a bit laggier than stock but which can pull hard all the way to red line while bolting into the stock location with miminal effort
I, personally, would not look to run one of these up way high in the boost and try and squeeze out over 400 whp - there are better choices if you want that kind of power
This is a great turbo for someone who does not want to radically transform the driveability and spool up of the stock unit while eveing out the power band on top and picking up a solid 50 - 60 whp from 5,000 to red line
When I am done on the BIG MAF I will post dyno comparison of stock vs this one
Dyno Flash is offline   Reply With Quote
Old 10-23-2006, 06:49 AM   #2
stu
Member#: 25768
35R bugeye
Slowbaru
how would you compare it to a green or sz49.
stu is offline   Reply With Quote
Old 10-23-2006, 08:11 AM   #3
THE-95-STi
Member#: 113734
1998 FSTi, 95 sold!
the JDM yO!(MAIC4LIFE)
Here's mine, next to the stock VF39
THE-95-STi is offline   Reply With Quote
Old 10-23-2006, 08:32 AM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
ahh..nothing prettier than a nice shiney new turbo
jigga is offline   Reply With Quote
Old 10-23-2006, 09:19 AM   #5
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
Thats really high. With those minimal mods theres no way to hit 370whp on a DD dyno.
What correction factor are you using?
SuperSTI is offline   Reply With Quote
Old 10-23-2006, 09:27 AM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
aparently the dynodynamics these days are reading pretty close to dynojets.... so that might explain things a bit...
Old 10-23-2006, 12:43 PM   #7
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
This DD dyno is at zero correction and was calibrated by the factory rep only 3 weeks ago
The big issue I would say is what a VF39 does on THIS dyno compared to the Gt52 unit
The stock turbos nose dive after 6,000 in tq and whp and the GT52 is not only making 50 more whp - it holds it and is rising higher to red line (at least at 21 psi)
Old 10-23-2006, 12:58 PM   #8
SuperSTI
Member#: 67182
2004 Subaru STi
Oh ok. Then that DD must read really high from the factory then cause there is definitely no way to hit that number with those little mods.
Old 10-23-2006, 01:08 PM   #9
wrex03
Member#: 29963
04 sti
So..... What does a stock sti make on this dyno?
wrex03 is offline   Reply With Quote
Old 10-23-2006, 05:21 PM   #10
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
I have been posting this for months... The Dyno dynamics dynos no longer read low.. A huge amount of complaints from Dyno owners caused the company to cave in and raise the calibration. Remember guys.. A dyno is a marketing tool just as much as it is a tuning tool.. You read that this turbo made 370 and you buy this turbo..
The Dyno dynamics is a great dyno. I love them.. But rest assured they no longer read super low.. I tested this the same day with the same car.. Dynjet read 4whp higher... Mustang read 35 lower then Dynodynamics..As the cars go up in power the differences are greater.
Good job Al!
Clark
AZScoobie is offline   Reply With Quote
Old 10-23-2006, 05:36 PM   #11
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Good job Al!
Clark
I agree
In fact I was wondering to myself what Shiv was whining about with his "moon" dyno after playing with this DD it seemed right on the Dyno Jet money
In fact my STI made the same 320 whp on this dyno and Pruven's Dyno Jet
The main function of any dyno is to use it as a TOOL OF COMPARISION to see how parts and tuning changes effect the power
It is silly to compare one dyno's results to another one - epsecially on this kind of dyno which can change the power number with a click of a mouse
I will post the comparison between this car and a stock vf39 STI later tonight - that should clarfiy a few issues
Al
Old 10-23-2006, 06:02 PM   #12
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Good job Al!
Clark
Please keep it up. I have read several of your posts saying this, and yet i still look for what type of dyno someone dynos on to see if it is/was the lower reading dyno.
I guess i just have it engraved in my head to expect lower numbers out of DD and Mustangs.
Swine is offline   Reply With Quote
Old 10-23-2006, 10:50 PM   #13
THE-95-STi
Member#: 113734
1998 FSTi, 95 sold!
Still a great turbo
Old 10-24-2006, 02:22 AM   #14
my_sti_1
Member#: 86713
04 STi GT35r .82
C16 Java Black Pearl
on SHIV's DD a fpgreen (non8cm) makes around 370whp with a FMIC and MODS above but this was on 100octane. what will your gt52 make on 100octane on your DD dyno.
i'm just trying to compare turbos; gt52, fpgreen, gt30r. ive heard alot about your turbo having LOTS of power and minimal lag. i had a gt30r and green and the spool up with those were close.
so does the gt52 have the kinda power a gt30r will have on your DD which can make +400whp on our local DD. if so then i believe a gt52 being a stock mount turbo beast is something i need to look into.
now that the fpgreen 8cm is now available the three turbos above are the turbos for the street imo. but being rotated makes me sweat more every time a cop is around me while driving
so what would you think a gt52 can make tuned on 100 octane do on your DD whp??
on a DD a gt30r can hit 400whp with a .82 and maybe 380whp on a .63 A/R with sick spool up and a fpgreen 8cm can make 385whp both on 100octane. based on the numbers above it seems like the gt52 turbo can hang with a gt30r rotated on 100octane, but that's if this turbo shines on HIGH OCTANE gas.
my_sti_1 is offline   Reply With Quote
Old 10-24-2006, 07:35 PM   #15
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
One redaction and modification to my previous post
I would NOT suggest this turbo without a EXTERNAL wastegate on a pump gas car
The set up is has on it with an apparent 19 psi gate spring boost creeps to 21 psi at red line on this car
This car is making 350 whp on 93 pump gas with a fairly conservative tune
19 psi creeping up to 21 at red line
I would think an external wastgate mod would help matters
Old 10-25-2006, 02:35 AM   #16
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Here is a fairly agressive Vf39 with top mount STI at 21 psi falling to 15 at red line
VS
The Gt52 at 19 psi creeping to just under 21 at red line on a very mild pump gas tune
You can see how the Gt52 is all busines after 4500
Its a really great turbo to drive on the street
Old 10-25-2006, 02:38 AM   #17
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
You know sti's can rev to 7k...
Old 10-25-2006, 10:59 AM   #18
Element Tuning
Member#: 54918
Great job Al. It looks like this turbocharger was shipped with a 19 psi internal gate instead of the standard 10 psi gate. The 19 psi internal gate is what I run but you can't really run less than about 20-21 psi. The standard WG will let you run as little as 15 psi but it won't hold much more than about 19 psi. This turbocharger really shines in the 22-23 psi range due to the GT series compressor wheel.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 10-25-2006, 12:32 PM   #19
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Thanks,
Phil
I think its good the way it is now
I will advise the customer about the lower spring watsgate actuator
I am hoping to do some water / alcohol injection on this car and get it into the close to 400 whp range
The dyno sheet does not really give justice to how well sorted and balanced this turbo feels on the street - it really transforms the STI without adding huge lag and making it unpleasnt to drive around town
Old 10-25-2006, 12:33 PM   #20
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
We were using the wheel speed as the reference and not rpms so the rpms on the sheet do not line up 100%
Main thing is that both cars had same settings
The end of the pulls was 7,000 even
The tach sesnor on that dyno is temp broken
Old 10-25-2006, 01:02 PM   #21
Element Tuning
Member#: 54918
It really is a great all around setup. It won't set any drag racing records but I think it's good enough that we'll be racing at Time Attack with it.
Thanks,
Phil
Old 10-25-2006, 01:59 PM   #22
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I would say its a solid 11 second pump gas turbo - and is very pleasant to drive
Old 10-25-2006, 05:49 PM   #23
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Any odds on it making 11.5x or faster with A/WI (just for reference sake)?
offset
offset is offline   Reply With Quote
Old 10-25-2006, 07:03 PM   #24
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I am sure it could be pushed to low 11's with the boost maxed out and a very agressive tune - however someone looking for the ultimate dra turbo will prob want to go larger
This is a good street and road racing set up
Old 10-25-2006, 09:36 PM   #25
THE-95-STi
Member#: 113734
1998 FSTi, 95 sold!
so if you added some C16 where do you see it running??
Element GT52 Tuned at EFI Logics Ray_STi Proven Power Bragging 32 12-24-2008 01:46 PM
Bailey Tuned 04 STI w/ Element GT52 turbochad Proven Power Bragging 38 05-23-2008 02:55 PM
Element GT52 Turbo/Hydra/Hydramist 436 whp Element Tuning Proven Power Bragging 60 10-25-2006 11:05 PM
AZ: Element GT52 Turbo, TXS FMIC, Tial 38mm WG hulkmanj99 Engine/Power/Exhaust 5 10-24-2006 09:40 PM
element gt52 redrex2002 Factory 2.5L Turbo Powertrain 70 10-19-2006 03:07 PM
