Old 10-23-2006, 10:17 AM   #1
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Default Rescaled MAF table question
If I have rescaled my MAF table back, will I see lower engine load, mafv, and g/sec flow numbers? I used to see 250g/sec, 4.5mafv, and 5.9 engine load numbers...now that I rescaled my MAF table I see 240g/sec, 4.4mafv, and 5.3 engine load's.
Does that seem correct?
akira02rex is offline   Reply With Quote
Old 10-23-2006, 06:45 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Which way did you scale it? Depending on which way you scale it you can make the stuff go either way.
cdvma is offline   Reply With Quote
Old 10-24-2006, 11:50 AM   #3
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Decreased voltage, and in one place increased airflow rate. So, basically it takes a higher mafv to reach higher g/sec air flowrate I beleive now. Makes sense to me!
Old 10-24-2006, 02:48 PM   #4
Division By Zero
Member#: 7555
Why did you rescale it? Larger MAF housing? I did one on a 3.5" housing and I had to scale up (massively). The MAFv numbers were lower for several reasons.
Division By Zero is offline   Reply With Quote
Old 10-26-2006, 10:10 AM   #5
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Helped bring my target afr and realtime afr real close, within .1 to .2 of each other. For some odd reason the modded stock injectors flowrate is not quite linear I don't think...more of a curve to them, who knows. I just know what I did works though!
Old 10-26-2006, 10:15 AM   #6
Division By Zero
Member#: 7555
If it works, then it works I wasn't really questioning that you did it, rather why you needed to.
Old 10-27-2006, 08:54 PM   #7
xolosis
Member#: 103373
Definitely works. Scaled the MAF down -22% to bring the actual AFR's to within .1 of the Map as akira02rex has done. Had to do this becasue upped pressure from the FPR which is a good alternative to replacing injectors.
You will see lower engine load etc so you must rescale you engine load columns as you don't want to be running excessive timing when leaning things out.
xolosis is offline   Reply With Quote
quick romraider table question sen7inel Open Source Reflashes 4 08-19-2009 08:31 AM
Boost Compensation (Vehicle Speed) table question ihadmail Open Source Reflashes 4 08-08-2009 07:41 PM
Romraider learning view table question...... BBBsti LTD Open Source Reflashes 19 04-09-2008 06:29 PM
Rescaling MAF question Bike Psyco Engine Management & Tuning 2 01-16-2008 02:56 AM
VE table Question boysetsfire Engine Management & Tuning 10 03-24-2003 12:26 PM
