Old 10-23-2006, 04:43 PM   #1
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
Default Looking for screen shots of Stock boost table from STi and WRX.
Anyone have a screen shot of some stock boost tables? Any of the maps will be fine. Specifically, I'm looking to see if there are values in any cells in any of the 'boost' tables after revlimt occurs in a stock ECU.
This needs to be from an unmolested/non-reflashed ECU.
That make any sense?
TIA
--kC
KC is offline   Reply With Quote
Old 10-23-2006, 06:28 PM   #2
chuckdez
Member#: 120187
2005 STI Stage2.5
Obsidian Black Pearl
TIA
--kC
OpenECU has all the answers. You can look at maps for any model without a cable.
OpenECU software - ecuflash_setup129a.exe
2005BajaTurbo5MT_AJ962_A2WC501L.zip
NOTE: Must be a member to download.
EDIT: Didn't read the subject at first, didn't realize you are looking for STI WRX maps. They have them in file at OpenECU.
chuckdez is offline   Reply With Quote
Old 01-15-2007, 01:36 AM   #3
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Here you go. It's an 04 WRX target boost map.
Buck
bucket7788 is offline   Reply With Quote
Old 01-15-2007, 01:51 AM   #4
qoncept
Member#: 44762
2013 BRZ
Here's are 03 WRX boost and WGDC maps, as well as a list of other tables that might be of interest. More specifically, it's from revision A4TC300L, but all of the maps I've looked at are identical.
Here's an 04 STi, revision AD3A101D.
I couldn't find any roms that had anything boost related above the rev limit. The popular opinion is that the ECU doesn't do any extrapolation, but just continues to use the last value in a row. I do remember seeing at least one ECU revision that did go above 6800rpm on these tables, but I can't find it now. I know some JDM (and probably other world markets) ECUs do, and I want to say I found an early 2002 USDM ECU that did as well.
qoncept is online now   Reply With Quote
Looking for a set of stock WRX rims and tires singincanary Tri-State Area Forum 3 12-22-2005 09:55 AM
Looking for a Pic of Factory boost solenoid lines tsquare Factory 2.0L Turbo Powertrain 7 03-13-2005 10:40 PM
Looking for local seller of stock WRX wheels bhamwrxman South East Region Forum 11 05-27-2004 02:34 PM
Looking for a set of stock WRX rims in Ottawa, Canada smokewrx Private 'For Sale' Classifieds 2 09-11-2003 07:55 PM
Looking for a set of stock WRX wheels imprezey Bay Area Impreza Club Forum -- BAIC 1 10-31-2002 12:53 PM
Message Board Statistics All times are GMT -4. The time now is 05:46 PM.
