Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-08-2001, 09:29 PM   #1
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
Default which wire for A/F meter??
Please help,
I'm not sure which wire to use for the sensor.
I bought the autometer A/F meter.
any advice?
ImprezaRSX is offline   Reply With Quote
Old 11-08-2001, 09:56 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Old 11-09-2001, 10:11 AM   #3
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
here's some good advice, on a 2001, try installing another o2 sensor. The autometer won't work with the voltage range of our front o2 sensors, and the rear is not worth using for A/F
paulnose is offline   Reply With Quote
Old 11-10-2001, 09:41 AM   #4
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
wish I would have read that last one before I installed it..
I'm getting a reading that goes off scale low when I decelerate...
I'm currently assuming that my indication is leaner than my condition....
either way.. it's not right.
How much is that autometer O2 sensor?
Old 11-10-2001, 10:33 AM   #5
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
Just get any 0-1v o2 sensor and have a muffler shop weld the new bung for it into the exhaust before the cat. I think the sensor kits can be had for about 60-70$ if not cheaper.
Old 11-10-2001, 03:18 PM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Hopefully you didn;t blow up your gauge. A lot of times when people install a A/F meter on a Wideband O2 sensor without knowing it, the meter becomes junk because it fries the electronics
Eric
Eric SS is offline   Reply With Quote
Old 11-10-2001, 05:15 PM   #7
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
the only time it ever indicates off scale is when I decellerate. then it indicates lean... that's low voltage right? So I think it's still ok.
But thank you guys for the warning.
Compass/Altimeter pack: which wire for speed (not from ECU)? boulder wrx Electrical & Lighting 3 09-15-2003 02:01 AM
Which ECU wire for a/f meter in an 03? CrashN2mee Interior & Exterior Modification 7 07-28-2003 12:32 PM
which wire for an A/F guage jslegacy Legacy Forum 1 05-29-2002 09:33 PM
Which wires for indiglo install? Bighurt1 Interior & Exterior Modification 1 04-11-2002 08:31 PM
Need to know which wire for speed MadMax Car Audio, Video & Security 7 04-28-2000 08:47 PM
