#1 |
Member#: 90879
TXIC
#2 |
Member#: 80663
SWIC
Vehicle:1997 Outback |
That is wierd. What do you mean by the bumper's black?
#3 |
Member#: 90879
TXIC
#4 |
Member#: 94447
Vehicle:2005 2.5RS PSM |
bumper IS black...not bumper's black...
anyway..good luck man...cant believe it happened to a 07 limited edition... your car too new to have any paint problem... |
#5 |
Member#: 99289
the dealer will most likely not spray it themselves, but contract it out too a local shop. Inspect it VERY closely when done.
#6 |
Member#: 90879
TXIC
#7 |
Member#: 90879
TXIC
Anyone else?
#8 |
Member#: 127534
South East
Vehicle:05' WRX Silver, 95' Miata Black |
+1 for inspecting VERY closely. Check for waves in the paint etc...
#9 |
Member#: 116666
Vehicle:2011 STI Limited Looks nice, plays dirty |
Can you post some pictures of this?
#10 |
Member#: 123536
SCIC
Vehicle:2008 STI LR |
As others here have said, check your paint closely before you accept the car again. I bought an '06 steel grey WRX wagon and I made the mistake of taking delivery of it at night. The next day, I noticed a small scratch on the hood scoop and a small spot on the tailgate where the paint had been eaten through the clearcoat somehow. I looked at the digital pics I took the night I took delivery of the car, and when I zoomed in on the areas in question, the defects were visible. I took the pictures before I drove the car off the lot so there could be no debate, and the dealer scheduled me to bring the car in to have it fixed. They contracted out to a bumper repair company and took about 4 hours to do the repairs; I trusted them. when I got the car back, it looked awful. There was very pronounced orange peel and the color did not appear to match. The service writer began acting like I was a pain as soon as I complained, but they took the car back to have it wet sanded and the clear coat they sprayed on looked much better. Then, when I got it home, I had the tailgate facing the sun, and there was a very distinct color mismatch. The dealer acted as if I was too picky and they couldn't see anything wrong, but they agreed to switch the gate with another new '06. They did that, but I never got to see it with the other gate. They said it didn't match, and put the original gate back on before I ever saw it. They said they could paint the rear gate, but they would need to take out the rear glass, etc. etc. etc. The dealer had no more '06 steel grey wagons, but they said they would try a swap with an '07 when they began coming in. The '07's are urban grey, so I will need to go back and probably battle a little to get it painted since the idea of a swap is out. Since the repairs were made, I noticed the car is missing a hood scoop bolt from when they took it off to touch it up; the dealer said "you don't need that". Yeah, right... another thing to contest before I go to the BBB. I decided to call the person who actually did the paint work, and the reason he painted a 10" diameter section to repair a defect less than an eighth of an inch in diameter was because he burned the paint with a buffer, even though the dealer and I had already determined buffing wouldn't fix it. I asked if he sanded or primed the area he painted and he said no. I have since wet sanded off all of his paint, and the factory paint is intact with the exception of the area he burned. So, even if the repair had been done properly, I doubt it would have held up as well as the rest of the paint. Your dealer may try to have one of these "spot repair" guys do the work; DO NOT LET THEM. Insist that their body shop do the work, and demand to speak with who will do the work. If you have to leave the car for several days, it will be worth it so you don't end up with a situation like mine. If you aren't happy with their work, don't accept their excuses like "the metallic flipped a different direction" or "no paint match is perfect". I've worked at Cadillac, Oldsmobile and Ford dealers, and they all like to try to get off as cheaply with possible with similar excuses. However, I've seen all of them turn out nice work when you force them to. Maybe your experience will be much easier than mine. Good luck.
#11 | |
Member#: 90879
TXIC
Here's the first defected spot. I don't have a picture of the other one under the tail light. I will try to get a pic of it tomorrow or something...
I will defiantly be strict and look at it very closely when it's done. One question though, since SOA is paying for it why does it matter how cheap or expensive it is to the dealer? Last edited by nxttruck2002; 11-09-2006 at 03:22 PM. |
#12 | |
Member#: 99289
) rant in this forum if you want to read about how warranty payments are handled. |
#13 | |
Brain Stew
Moderator Member#: 4562
NWIC
Vehicle:1998 Forester,lifted 1975 VW Westfalia tin top |
However most dealers do not have a body shop (all claims require a SOA to inspect as well) The work will be sent to a body shop for repair. The dealer will tell the body shop what SOA pays for the job and the body shop will either decline or accept the work. If they accept the job the dealer will submit it to SOA as a sublet repair. The dealer could care less what it pays. |
#14 | |
Member#: 99289
#15 |
Brain Stew
NWIC
#16 |
Member#: 99289
#17 |
Member#: 90879
TXIC
Guys, do you know if they will use the same paint as SOJ did? Also, what if it's not an identical color to the SWP, do I keep bitching about it and have them do it over and over?
#18 |
Member#: 92750
Vehicle:2003 Impreza RS Blue |
I dunno whose paint Subaru uses, but I know with my VW when I needed parts re-painted and I wanted to be sure it was a match, I asked VW corporate for the PPG color code for the paint used. Now, I dunno if pearlescent paints are quite so easy to match. I'm unfamiliar with how many coats of different stuff make up the actual color, so your mileage may vary, but it might be useful to see what SOA or your dealership can tell you about the paint...
#19 |
Member#: 90879
TXIC
I'm going tomorrow, I will keep you guys updated.
#20 | |
Member#: 3313
I've got a local Subaru dealership that's a relatively large bodyshop for this area...unfortunately, locals haven't had a lot of luck with the quality of their work many times. |
#21 |
Member#: 90879
TXIC
Well they took pictures and are going to send the to SOA. He's (service guy) pretty confident that SOA's going to pay for it (both spots)!!!!!!
They do have their own body shop, which made me feel a little better about the whole painting deal. One question... How do they apply the "STI" emblem? I don't want it at all slanted/angled. |
#22 |
Member#: 90879
TXIC
They're going to cover it (as they should
)!!!!! I drop the car off Monday and get a free rental. I just am praying to God that The work is down correctly....Q:How do they apply the "STI" emblem? I don't want it at all slanted/angled. Will the paint guy just eye ball it? (It better not be that way...) |
#23 |
Member#: 122680
NESIC
Vehicle:2006 STi Rally Car WRB |
the emblem goes in lil holes so it should be straight . . unless the guy really fs it up for ya
#24 |
Member#: 88304
Vehicle:05 VF34 Aspen WRX |
looks like someone tried to take the emblem off and scratched the paint up
#25 |
Member#: 39401
RMIC
| Thread Tools | |
| Display Modes | |
| I'm going to my first real job interview today. HELP! | Impreza88 | Off-Topic | 42 | 05-21-2008 01:27 PM |
| So I'm going to my THIRD bootcamp... | skimmilk68 | Off-Topic | 33 | 06-08-2007 03:14 AM |
| If this sets a precident, I'm going to be rich. Suing for Chat Room Addiction | runnah | Off-Topic | 5 | 12-15-2006 09:48 AM |
| I'm going to meet a chick for coffee in 2 mins...and I have mad gas!!! | GooseMan | Off-Topic | 24 | 02-16-2005 03:12 PM |
| I'm going to be Petter Solberg for Halloween | meebs | Motorsports | 7 | 10-08-2002 11:50 PM |
