Old 10-24-2006, 03:53 PM   #1
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Default jdm ej25t swap
i just bought an jdm 06 legacy gt engine to swap into my 02 wrx from gruppe-s. from what they have told me the swap is straight up and my stock harness and ecu can be used and all i'll need is the reflash. is this true? from what i've read in the forums everyone just argues back and forth. should i try to run the legacy gt ecu? or would a sti's work?
domestic_abuser is offline   Reply With Quote
Old 10-26-2006, 06:20 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yesh
its not that straight forward
you will have to swap your wrx manafold on
avcs won't work w/ your ecu
its not much of an upgrade if any
Old 10-27-2006, 03:35 AM   #3
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
i already know that i have to swap the manifold over with the throttle body to get around the fly by wire. I'm in the process of buying a ver.7 spec C ecu, will this help any. I don't see how this isn't much of an upgrade.
Old 10-27-2006, 11:37 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i just noticed somthing you said 2.5 and jdm legacy .... the jdm legacy is 2.0
Old 10-27-2006, 12:38 PM   #5
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
according to gruppe-s it's a legacy engine. i'm thinking fxt though.
Old 10-27-2006, 01:05 PM   #6
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
Or.... the Forester STi, which is far more likely. If so, then that would be a huge upgrade. But any EJ25T will be an upgrade over the US EJ20
You should really try and use the ECU from the engine that you got... but at the very least, it must be an ECU that supports all the features of the engine, like AVCS. As long as it can do that, then a re-flash should fix it.
AruisDante is offline   Reply With Quote
Old 10-27-2006, 01:10 PM   #7
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
i plan on running a ver.7 C spec ecu anyways. im just curious about it. can't i just leave the avcs unplugged? I just looked up to make sure and the new legacy's are 2.5t. http://www.rsportscars.com/eng/cars/legacy_gt.asp
Old 10-27-2006, 01:13 PM   #8
AruisDante
Member#: 122365
Ice Silver
No, you can't leave the AVCS unplugged, the cam timing would be all f'd up. You'd have to put on heads that didn't have AVCS. The JDM Spec C ECU should be able to handle AVCS on a JDM engine (which is dealt with totally differently then it is on the USDM engines)
And I think that link is to the USDM Spec B... the JDM one is a 2.0 liter if I remember correctly.
edit: yep, that's the USDM spec B... this is the JDM spec B: http://translate.google.com/translat...&hl=en&ie=UTF8
Old 10-27-2006, 01:17 PM   #9
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
hmm...good to know. thanks. if you find out anything let me know.
Old 10-27-2006, 01:20 PM   #10
AruisDante
Member#: 122365
Ice Silver
This is the total rundown for the JDM 2006 legacies.... only 2.0T's and 3.0 NA's
Old 10-27-2006, 01:23 PM   #11
AruisDante
Member#: 122365
Ice Silver
The ONLY 2.5 turbo in Japan is the Forrester STi.
http://translate.google.com/translat...language_tools
Old 10-27-2006, 01:30 PM   #12
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
hmm...what about the FXT
Old 10-27-2006, 03:11 PM   #13
AruisDante
Member#: 122365
Ice Silver
the FXT in japan is a 2.0T as well.
edit: just realized that for some reason it only will link to the main subaru page....
Well, go to the third option down on the list on the left side, it will bring up a model list. Then click on the forester, then on any one of the models, and it will bring you to a spec page. On it, it list the engines as:
2.0XS / 2.0X / 2.0XT / CROSS SPORTS 2.0T / CROSS SPORTS 2.0i
Old 10-27-2006, 03:47 PM   #14
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
hmm...well i guess i scored. thanks for all the info.
Old 10-27-2006, 05:01 PM   #15
AruisDante
Member#: 122365
Ice Silver
Well.... make sure it's actually a 2.5 liter...
if you actually have the engine, look at the block, there will be a tag that says either EJ20 or EJ25. Obviously you know which is which.
it looks like this:
Old 10-28-2006, 12:38 AM   #16
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
i thought for sure that it was from an FXT when i bought it from gruppe-s. they said legacy so i went with it. it is a EJ25 for sure.
jdm ej25t swap domestic_abuser Subaru Conversions 16 11-10-2006 09:29 PM
98 Legacy GT EJ25T swap - need hood sk8erord Legacy Specific Parts 27 05-04-2006 05:51 PM
Who's done a EJ20 or EJ25T swap ? Legacy Legacy Forum 16 03-16-2005 08:25 PM
EJ25t swap into WRX ScobyWRX Subaru Conversions 6 03-13-2004 07:40 PM
('93-'01) EJ25T swap - who will be the first? Radar_Lover Impreza Forum 8 03-05-2003 11:12 AM
