Old 10-24-2006, 05:32 PM   #1
hova
Member#: 78463
07 35R-STI
2011 E92 M3/ 08 135I
Default Idle issues?
04 WRX auto, 18g, alky(100% meth), turboback, pe800, all other supporting mods. Car idles low so my ? is can the idle be turned up while the car is in gear. Instead of just turning the idle up while in park or neutral.
hova is offline   Reply With Quote
Old 10-25-2006, 07:25 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I don't see any maps for that. But I think the TCU tells the ECU what idle to run while in gear so you aren't over heating the transmission while sitting in traffic.
You need to figure out what the problem is with the idle, not try to tune around a possible mechanical problem. My guess is a slight intake leak.
Old 10-25-2006, 11:11 PM   #3
hova
Member#: 78463
07 35R-STI
Thanks because it really is starting to get annoying. The car never idled like this before until recently
Jumping idle issues, any ideas? Also fueling issues. roninsoldier83 Factory 2.5L Turbo Powertrain 3 05-20-2009 11:32 AM
weird idle issue...not average idle stuff slingshot Factory 2.5L Turbo Powertrain 5 09-25-2006 04:24 PM
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain 3 07-05-2006 09:45 PM
Idling Issues KTB Warranty Issues & SOA Problems 7 04-17-2002 08:00 PM
Long overdue update on idle issue plus website info :) Warp3 South East Region Forum 4 01-17-2001 07:38 PM
Message Board Statistics All times are GMT -4. The time now is 01:02 AM.
