Old 10-25-2006, 12:57 AM   #1
03boxer4
Member#: 66622
2002 WRB wrx - Sold
Big White Jeep Unlimited
Default clay bar and waxing process?
what is the process to use claybar, washing, and waxing? like which order.
thanks guys
03boxer4 is offline   Reply With Quote
Old 10-25-2006, 01:00 AM   #2
wirolla
Member#: 109725
2001 GM6
SRP
thy this
i found it pretty useful
wirolla is offline   Reply With Quote
Old 10-25-2006, 01:14 AM   #3
RAPTR
Member#: 104742
2006 STi & 11 EVO X
I clay-bar about once every 6 months and I'm religious about it because it makes your paint sooo smooth, especially if you polish after you clay bar. A nice coat of cleaner wax and you are ready to go! Takes a bit of time if you do it right. If you drop the clay bar don't even think about using it again. You would just cry after you saw what happened. Have fun!
RAPTR is offline   Reply With Quote
Old 10-25-2006, 11:06 AM   #4
06-SportWagon
Member#: 123802
2006 2.5i Wagon
Steel Grey
Wash, Clay Bar, Wax/Polish...oh, and dont get the clay bar on any unpainted surface or rubber. Just like wax, it can leave a film on the material. Good luck!
06-SportWagon is offline   Reply With Quote
Old 10-25-2006, 11:24 AM   #5
RockBlocker
Member#: 36230
2002 Sedan
Silver/Black
You can actually clay bar any surface of the car IF you keep it wet and lubricated. yes I said lubricated. After many years of detailing and having to remove overspray I can say its not much fun on non painted surfaces, but can be done.
On painted surfaces you can use water, soap or some type of clay bar solution as well.
RockBlocker is offline   Reply With Quote
Old 10-25-2006, 12:59 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
The following is an excellent article on the use of clay:
http://www.autopia-carcare.com/inf-clay.html
.....you may also want to check out the other topics they cover regarding car care:
http://www.autopia-carcare.com/how-to.html
Kean is offline   Reply With Quote
Old 10-25-2006, 03:02 PM   #7
AllAWD
Member#: 17079
I used the instruction provided by Zaino Bros.
I washed with Dawn
clay bar
wash again
wax
AllAWD is offline   Reply With Quote
Old 10-25-2006, 05:00 PM   #8
JnJassociates
Member#: 69539
2004 wrx wagon
red
We strongly recommend that you do not use a dish detergent on a relatively new car.
There is a good chance that there are very few layers of wax.
Wash with a soap designed to be used on automobiles.
You do not have to dry if you are using a clay bar.
Break the clay bar up into two pieces. One for the upper half and one for the lower half.
Use a spray detailer as your lubricant (some soap and water in a spray bottle will work in a pinch).
Spray the area you will be working with, then glide the clay bar over the painted surface.
When done you may want to give the car a quick wash, we do.
Then a good polish, followed by a good wax or even better a good paint protectant like RejeX.
Bryan
JnJassociates is offline   Reply With Quote
Freshly Clay-Barred and Waxed! WagonMonster Member's Car Gallery 45 07-31-2006 10:33 PM
Pics of my Steel Gray '06 WRX TR after Wash, Clay Bar & Wax... Chiketkd Member's Car Gallery 28 02-20-2006 04:21 PM
Clay bar and wax Glockperfection Car Care & Detailing 29 06-12-2002 08:21 PM
California Gold Clay Bar + Zymol wax Andrew Car Care & Detailing 19 04-11-2001 01:05 AM
Where to get a clay bar.. and only clay bar ? DEVO Vancouver Impreza Club Forum -- VIC 6 08-30-2000 01:03 AM
