Old 10-25-2006, 12:56 AM   #1
BlowDro
Member#: 112116
2006 WRX
Default 2 tunes, one meth, one no meth?
is it possible to get my accessport tuned w/o spraying meth and running lower boost and have another map that i will run meth and higher boost? im sorry if this is a newb ? but i didnt see it answered in any of the stickys.
BlowDro is offline   Reply With Quote
Old 10-25-2006, 01:17 AM   #2
metoo
Member#: 4764
2004 STi sold :(
forizzle
Any engine management system (EMS) that can support multiple maps can have a map for meth and one for no meth. The EMS meth map will not control the meth injection at all. It will only optimize fuel, timing, and boost (some do not control boost) to get the power the meth will allow.
metoo is offline   Reply With Quote
Old 10-25-2006, 09:28 AM   #3
BlowDro
Member#: 112116
2006 WRX
so the map will tune my timing boost and fuel and i will just have to turn the controller on or off. btw i will be probly getting the coolingmist kit if that helps
Old 10-25-2006, 09:38 AM   #4
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
The map will be expecting to see the meth injection and will have increased timing, etc, to take advantage of the added knock protection and octane. Basically, you can just use an off-the-shelf map for the non-meth map unless, for some reason, you plan to run a lot without the meth active. That sort of defeats the purpose of the meth kit though, ya know?
I mean, if you run out of meth, (via your low level indicator, etc, not actually run it dry) just switch to an OTS map until you get more.
Have you read up on the value added by using the controler module(s)? Some would argue that there really isn't much value to them because they aren't able to vary the flow as much as it might seem. For most applications you would just as well off (and cheaper) using a single stage boost controlled system, or even a two stage boost controlled system.
Just my opinion.
BadTrip is offline   Reply With Quote
Old 10-25-2006, 11:16 AM   #5
BlowDro
Member#: 112116
2006 WRX
i am running the ots map now but i have a header and soon will have a new top mount too. most of the time i plan on running off meth so i guess i will have to get to maps tuned.
Old 10-25-2006, 06:36 PM   #6
Sleeper in Seattle
Member#: 101546
2004 FXT & 04 S2000
Silver & black
I have a meth tune and a non-meth tune on my Cobb Ap. You can see the difference in dyno results in my post 100% meth Alkycontrol pdx tune. S the answer is: Yes!
Sleeper in Seattle is offline   Reply With Quote
Old 10-25-2006, 09:27 PM   #7
BlowDro
Member#: 112116
2006 WRX
sleeper, do u just keep ur ap in the car and swap maps on parking lots or something? i have never changed maps on the ap, how fast does it do it?
Old 10-25-2006, 10:33 PM   #8
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
You really dont need two differnt maps when running METH. You can preset when the kit starts spraying. Mine in set at 10 pounds. For around town driving, and not slamming your foot to the floor it works just fine. It really is all in what you want.
JMK508 is offline   Reply With Quote
Old 10-25-2006, 10:54 PM   #9
flycaster
Member#: 60142
2011 WRX
Grey
While it's true the maps are identical up to the point of injection, you most certainly do need 2 separate maps if you are tuned for meth and the meth either fails or you run out. If you get into boost at all and the meth isn't there - severe, and terminal detonation is not far behind. Try to moderately pass a car without using more than 10 psi of boost in 5th gear sometime if you don't believe me. In my car, if I breathe on the throttle in 5th or 6th I'm at 13-15 psi before I can even blink, and I'm at 20 psi one blink later. Try that with an AFR of about 16:1 (no meth), and a boatload of timing, and it's buh-bye.
BloDro - just plug it in, and it takes about 12 seconds to flash in whichever map you want. It could not be any simpler.
flycaster is offline   Reply With Quote
Old 10-26-2006, 02:22 AM   #10
Sleeper in Seattle
Member#: 101546
2004 FXT & 04 S2000
Silver & black
I do carry my AP around with me, but I have been driving around for twenty days now on my meth map and I haven't even thought about turning off my meth kit. I have no intention of not running meth daily everyday all day- I bought a 55 gallon drum of the stuff. Honestly, I don't know why I carry it with me. I have enough meth in my 12L tank and my spare 1.5 gallon tank and I check the level often enough so I don't really need to- but it is there just in case.....
You definately need to get tuned to take advantage of it- unless you are just misting the smallest amount to give you an extra cushion of safety and not gain any power. I like what tim from PDX did with mine: he protuned me without meth and then he protuned me with meth and gave me both maps! Any tuner should be able to do that- and that is ideal!
Old 10-26-2006, 09:54 AM   #11
BlowDro
Member#: 112116
2006 WRX
but i want to slam the gas around town, run normal amounts of boost and no meth.
Old 10-26-2006, 06:42 PM   #12
benw
Member#: 103320
1998 swapped
Forester L
Only downside is for people on EcuTEK. It requires the EasyECU software which is like $550. I planned on using my AccessPort, but it crapped out on me.
benw is offline   Reply With Quote
Old 10-26-2006, 08:18 PM   #13
JMK508
Member#: 115420
Its like a STI.....
EcuTEK is what i happen to run... so i guess that is why i have learned to deal with only one map. I really just never let my Container get less than half full. I do agree with you Flycaster!!! It is really hard to pass someone while doing highway speeds and not get into boost hard. I guess i dont really have a choice though.
Old 10-26-2006, 10:02 PM   #14
dibblejr
Member#: 94070
05 LGT
Yep, I have 6 maps for dif octane fuels with and without alky/ water and plain water.
Jay-R
dibblejr is offline   Reply With Quote
Old 10-27-2006, 01:04 AM   #15
flycaster
Member#: 60142
2011 WRX
Grey
Wow. You must have a very happy tuner!
Old 10-27-2006, 11:10 AM   #16
dibblejr
Member#: 94070
05 LGT
Yeah, but when you charge by the hour and you have a really good tuner it still probably cost the same as a single tune at other shops.
Mike@ innovative tuning knows his business.
Jay-R
AMR: 2008 STi - PURE 93 Octane, NO METH, NO RACE GAS, 3550lbs = 10.90et!!! AMR Proven Power Bragging 182 09-19-2009 05:03 PM
04 STI Stage 2 Meth vs. No Meth Tune Tuning @ FLI Proven Power Bragging 53 04-24-2008 09:02 PM
Ideal IWG turbo for 350-375whp on 91 pump no meth? zanderspeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 05-07-2007 11:36 PM
Element Tuning and World One take 1st in Pro Class at Subiefest 2! WorldOne Member's Car Gallery 73 04-23-2007 04:09 PM
