Old 10-25-2006, 11:17 AM   #1
NW OBS
Member#: 101361
05 OBS
Obsidian Pearl Black
Exclamation Need Some Help On Setting/Changing Idle Speed on '05
I am stumped. Help, if you can.
I am driving an '05 N/A car that has 'fly by wire' throttle control. There is no way to set the idle speed it appears (if you have an '07 the ECM now allows a Suby Tech to set the idle from 0-2000 rpms) either through the ECM or mechanical.. stupid.
The issue is this. I just put in performance cams and the car pulls like a rhino ~ but the ECM continues to set the idle @ 450 rpms and the car will stall when coming to a stop. If I could adjust the throttle to say 900 rpms all would be rosey!
Any help would be appreciated. All three of my service guys at the dealership, do not have an answer on how to fix this issue. Obviously, I can't keep driving it as it stalls 50% of the time when I come to a stop!
NW OBS is offline   Reply With Quote
Old 10-25-2006, 11:25 AM   #2
drummerRS2505
Member#: 111331
2005 Impreza 2.5 RS
congrats on getting cams! what knid did u go with? As far as idle on my 05 RS it idles when warm at 700-750 rpm which is normal for our cars stock. The only way i would think to adjust idle if the techs cannot set it with scantool via the ecu would be maybe then can adjust the accelarator pedal position switches (3 used commonly for multiple back-ups) on the gas pedal somehow.
Rick,
drummerRS2505 is offline   Reply With Quote
Old 10-25-2006, 11:41 AM   #3
NW OBS
Member#: 101361
05 OBS
Rick,
Hey, thanks for the tip. I pulled that assembly to put on the aluminium peddle... I don't remember seeing 'switches'. I will have to crawl back under the dash and have a look.
I went with Delta re-grinds. Just got them in late yesterday and still tip toeing around. I can already feel the harder pull across the middle rpm ranges.
Need some help with cluch change kx02wr Transmission (AT/MT) & Driveline 10 04-08-2010 11:23 PM
Need Help On Setting/Changing Idle Speed On '05 NW OBS Engine Management & Tuning 14 11-10-2006 02:29 PM
need some help with setting up wheels SilverBulletWRX Tri-State Area Forum 1 05-24-2004 10:49 PM
Need some help with setting up the AVC-R Hojai Normally Aspirated with bolt-on Forced Induction Powertrain 16 06-26-2003 11:03 PM
need a little help on setting boost vs speed on unichip HM3SC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-22-2001 08:05 PM
