Old 10-25-2006, 11:51 AM   #1
awdguy
Member#: 59101
2004 wrx
white
Default trans oil change: do it myself or dealer
The dealer servive has a BF machine that will clean the entire trans but will it be fine if i just drain it myself and refill?
It may not be clean but will it be clean enough if I drain and refill?
awdguy is offline   Reply With Quote
Old 10-25-2006, 12:52 PM   #2
Pain++
Member#: 88289
2006 WRX: Stage 2
Urine-soaked Subway Car
While I haven't had to do it on my WRX yet <way too low mileage > it seems that many on the forums do it themselves w/o too much of a problem.
http://forums.nasioc.com/forums/show...49&postcount=5
Happy wrenching
Pain++ is offline   Reply With Quote
Old 10-25-2006, 01:19 PM   #3
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
Wow. Just get the right fluid, and this is like a 15 minute change. Getting the Subaru OEM fluid is what I suggest, but THAT part is up to you. If you can change oil, you can change the tranny fluid.
I have used the OEM ExtraS on the STI and RS, and only the STi it seems to matter. Regardless, I used it on both.
Good luck.
- dow
dowroa is offline   Reply With Quote
Old 10-25-2006, 01:26 PM   #4
sigurd
Member#: 128721
2002 impreza WRX
psm
yeah man really easy. I did it on my lunch break at work 45min. even had time for a little test drive.
oh and that was also including differential fluid. You should go ahead and do that aswell. Just as easy and you just have to buy 1 qt. more.
remember 3.7qt in tranny and .8 qt in differential. Mine took 3.5qt to fill it back being you wont get all of it out. Drain it warm you will get a bit more fluid out and quicker.
oh and personaly I think those flushing systems are bs. In fact I think they do more harm than good. Just drain it and put some new juice in there and your good to go.
sigurd is offline   Reply With Quote
Old 10-25-2006, 01:28 PM   #5
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
Take a look under you car first. You might need a t-70 torx bit for the drain plug. that's what it was on my 05. You can't find em anywhere except online
Sausage is offline   Reply With Quote
Old 10-25-2006, 01:29 PM   #6
sigurd
Member#: 128721
2002 impreza WRX
psm
yeah I ment to say that. Dunno bout the 04' though. Mine was just a regular bolt head.
Old 10-25-2006, 03:48 PM   #7
jdbewl01
Member#: 80541
2004 WRX
not necessarily true. i got my 1/2" t-70 at a tool supply place that's open to the public for about 6 bucks. most cities have something like this. just changed my fluid over the weekend to scotty's cocktail. already noticing a difference. good luck,
-jeremy
jdbewl01 is offline   Reply With Quote
Old 10-25-2006, 03:52 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Do you have a manual trans or auto? There is no machine to "clean" a manual, it's just drained and refilled. Even with an auto, the flush isn't necessary on a relatively low mileage car that has had regular service.
Old 10-25-2006, 04:03 PM   #9
awdguy
Member#: 59101
2004 wrx
white
i have an manual transmission, with 80000 miles on it. i do the oil changes regularly and air filters that all.
Clutch install Shop or do it myself? aznburn210 Texas Impreza Club Forum -- TXIC 22 04-01-2008 10:56 PM
Do it myself or take it back to the shop? v. wheel bearing pumpkyn Rocky Mountains Impreza Club Forum -- RMIC 17 12-19-2007 06:17 PM
Pay somone to install my downpipe or do it myself ? wrxhunter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 07-14-2005 06:03 PM
Oil change: every 3 months or 3,000mi? Kitt Service & Maintenance 19 02-05-2005 07:44 PM
Oil Change: Doing it clean dowroa Service & Maintenance 8 09-30-2003 10:25 AM
