Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Old 12-19-2006, 10:13 PM   #101
Patrick Olsen
Member Sales Rating: (30)
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by RallySport Direct View Post
We CAN, however I am guessing it will be tough to find another 10 people that are interested in the brace. We can get you the brace coming in from Japan by it self, if you would like. It will take several weeks, but we can get you one fore sure.
Keep in mind, Sinister, that the GB discount was only $10. A nice gesture by RallySport, to be sure, but if you can afford the old GB $125 price you can probably afford the $135 non-GB price. (Although shipping might tack a bit more on there, I dunno.)
I'll be putting mine in tomorrow, I'm curious to see how it affects NVH. My rear diff (Cusco RS @ 100% lockup) is rather obnoxious as is.
Pat
Old 12-20-2006, 06:48 AM   #102
elpapi336
Member Sales Rating: (1)
Member#: 82423
99 Real V5 JDM STI
90 Accord &new whip 04STI
Originally Posted by Hurley 2.5 WRS View Post
well, actually, it didnt fit quite like it should.
this is probably due to the fact that the rear subframe i have is an STi type RA, and has the R180. i checked them out prettty close when out of the car, and they seemed slightly different shape, and i know that they are now.
a test fit on my RS subframe in the backyard fit perfect, but the RA subframe has its bushing holes tweaked away from eachother. i thought the subframe was bent, but looking at it closer, the bushings are different than the RS ones, and the subframe had much more contour in the areas that the subframe would hit the body. so the RA subframe is longer (front to back) and looks aot beefier. another difference is that there is no rubber in the subframe where it bolts to the body. so, in general, my subframe extends about 1ish inches further back. i had to lower the subframe to get the brace on, and had to shim the outer bolt up points of the brace so the brace wouldnt be bent when tightened up.
moral: if you have a GC RA subframe it might not fit right, but will work. its also really loud, since theres no bushings to the body from the subframe. i also dont know if there are year differences between RA subframes.
OH i have a V5 RA with the r180!!! wich version do you have?
here's a pic of my rear diff. bushings.. so tell me if is the same as yours and this brace won't fit right.
elpapi336 is offline   Reply With Quote
Old 12-20-2006, 07:09 PM   #103
Hurley 2.5 WRS
Member Sales Rating: (3)
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
V4 RA
can you take a pic from beneath looking up at the bushings? thats a much easier way to see
Hurley 2.5 WRS is offline   Reply With Quote
Old 12-20-2006, 09:36 PM   #104
elpapi336
Member#: 82423
99 Real V5 JDM STI
V4 RA
here you go
Old 12-20-2006, 10:58 PM   #105
Kostamojen
Member Sales Rating: (7)
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
What was the problem with that one? Looks fine to me...
Old 12-21-2006, 08:35 PM   #106
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I got mine installed today. By the Olsen Rule of Modifications, it of course took about 3x as long as I expected it to, because even the simplest jobs must have something go wrong. In this case, the passenger side stud wanted to back out of the diff with the nut. Not a huge deal, and if it had been the driver side one there wouldn't have been any issues at all. But, due to the shape of the spare tire well, there's not enough room to get the passenger side stud all the way out. The driver side one I think I could have unscrewed and removed, but not the passenger side one. (You can see that in elpapi's picture with the red circles.) Actually, if I had scraped off the undercoating there that might have done the trick, as it was pretty close, but I didn't do think of that at the time. Anyway, I ended up unscrewing the stud essentially all the way, then grabbing the now-exposed unthreaded portion of the stud with a set of vice grips so I could unscrew the nut from the stud. I then used the two nuts that came with the brace to double-nut the stud to screw it back in, then installed the brace. Whew!
There is definitely plenty of play to be taken out of the mount back there. I had the car up on a lift, and used a screw jack under the diff as I was doing this, and could probably move the diff up and down at least 1/4", and probably more than that. Granted, that was with the nuts removed from the studs, but even with them installed and tightened down I'm sure there's some movement possible. The studs aren't a particularly tight fit in the center of the bushing, and the bushings themselves are soft (and old).
As you can see, the OEM bushings sit inside raised lips extending out from the face of the subframe, and the brace is designed to fit over those lips. I measured the diameter of one of those and got right about 61mm. I measured the height of the opening of the back side of the brace and got about the same 61mm, so it's a damn tight fit. Initially the brace didn't want to fit on there, so I put it in place, and then used the nuts on the studs to press it into position. Even with those two nuts tightened all the way down, the two bushing arms weren't flush with the subframe - there was probably a 1/8" or larger gap. Installing the hardware and tightening them down obviously took care of that. I'm curious, though, if the others who have installed this already found it they were able to immediately position it all the way flush against the subframe, or if they found it was a tight fit, too.
I had a short drive home from the shop, and didn't really romp on it are try any hard, high RPM shifts, so I can't say I noticed much difference yet. NVH didn't seem horrible, which is good.
Pat
Old 12-21-2006, 10:54 PM   #107
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
there was a little gap until I tightened it down.
but the install still went without problem. Sorry for your bad luck. Usually I'm the guy writing the sad story about a five minute install taking three days.
ImprezaRSX is offline   Reply With Quote
Old 12-21-2006, 11:10 PM   #108
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Same here
My only difficulty was dealing with my diffuser, other than that it went just perfect.
Old 12-22-2006, 01:35 AM   #109
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
I want a diffuser.
You got a thread on doing one of those?
Old 12-23-2006, 02:52 PM   #110
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
Originally Posted by elpapi336 View Post
here you go
it might be realtively the same. looks like your bushings are close to the spare wheel well like mine were.
Old 12-27-2006, 01:50 PM   #111
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I want a diffuser.
I think theres a big one in the interior/exterior forum on the 06/07 stock diffuser and installing it on older models.
Old 01-12-2007, 11:13 PM   #112
xS2k
Member Sales Rating: (18)
Member#: 85112
Oh, and in conjunction with the rest of my drivetrain mods, I no longer have ANY thunking or anything going on with hard acceleration Feels great!
Under hard acceleration and letting go of the gas, do you still get any thunk/clunk?
xS2k is offline   Reply With Quote
Old 01-15-2007, 09:40 PM   #113
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Nope.
Old 02-10-2007, 10:08 AM   #114
FederalAuditor
Member#: 34042
Will this support bracket fix the "trailor hitching" I'm getting? The name is pretty self explanitory, but in case anyone doesn't know, I mean the galloping jerky drivetrain slop you get when you're on and off load.
Also, did how much NHV did these add?
FederalAuditor is offline   Reply With Quote
Old 02-10-2007, 10:45 AM   #115
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I still get some trailer hitching if I'm not smooth on the gas while trying to creep along at low RPMs. I didn't find that NVH was too bad. I already had the "clunk killer" bushings at the front of the rear crossmember, and Group N drivetrain mounts - I would say that stuff caused more noticeable increase in NVH than this mount did.
Pat
Old 02-13-2007, 05:23 PM   #116
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Any of these drive train bushings/mounts will always help get rid of the slop or clunking, but once you stop one clunk, another will appear somewhere else. So I cannot say for sure if this will solver your problem, but I can say that it should help.
I have not installed these yet on my personal car so I cannot comment on the NHV, however a local customer of ours did and I was able to ride in his car and I could not notice a increase in NHV.
Please let me know if you have any other questions.
Thanks
Rick
RallySport Direct is offline   Reply With Quote
Old 01-27-2009, 09:01 AM   #117
53WRX
Member#: 161014
Can you still get these ?
53WRX is offline   Reply With Quote
Old 01-27-2009, 12:00 PM   #118
RallySport Direct
Member#: 33174
We are Open Late!
Yes sir
__________________
Old 02-01-2009, 11:21 AM   #119
subiesoho
Member Sales Rating: (10)
Member#: 164241
2007 wrx wagon
pearl white
this won't fit an 07 wrx wagon will it?
subiesoho is offline   Reply With Quote
Old 02-02-2009, 12:08 PM   #120
RallySport Direct
Member#: 33174
We are Open Late!
They are only designed to work on the 1993-1996 JDM GC8 and 1339-1995 USDM Impreza AWD.
__________________
Old 02-14-2009, 11:06 PM   #121
Tirpitz56
Member Sales Rating: (14)
Member#: 77728
2001 Impreza RS
how much are these brackets now shipped?
Tirpitz56 is offline   Reply With Quote
Old 08-24-2009, 08:25 PM   #122
AK SloPok
Member Sales Rating: (26)
Member#: 56464
12 Ram
Will these work with the Forester chassis? I gots all kinds of movement on my rear diff and very few solutions, I have an 04 XT, thanks.
AK SloPok is offline   Reply With Quote
Old 08-25-2009, 11:59 AM   #123
RallySport Direct
Member#: 33174
We are Open Late!
If you can post a image of your rear diff, this would help. Reason is that these where specific for the V1-V3 WRX/ 1993-1996 Impreza L, I know that the FXT shares allot of similar parts with the GD WRX, so that would probably be the one you need.
__________________
Old 08-25-2009, 06:24 PM   #124
AK SloPok
Member#: 56464
12 Ram
Not my rear but a Forester diff, you can see that there isn't the two additional holes like the STI, in fact the bushings themselves are different and much softer.
Old 08-25-2009, 06:37 PM   #125
RallySport Direct
Member#: 33174
We are Open Late!
This is the GD WRX/STi
This is early WRX right here
I currently run one of these on my GC, but dont have a FXT here. If you can let me know the bolt spacing between the 2 holes in the subframe, the distance between the diff bolts and the sub frame bolts, this way I can measure them on my GC and see if it might cross over. Only thing I am worried about is that beatrush is not listing it to fit on any car other then 91-94 Legacy, and 92-96 Impreza.
__________________
WTB: Beatrush rear diff bar for GC body calmnothing Private 'Wanted' Classifieds 1 06-27-2008 02:14 AM
Beatrush rear diff brace installed DroppedClutch South West Impreza Club Forum -- SWIC 16 01-23-2008 06:48 PM
FS: Beatrush Rear Diff Support Bar beaviscih Suspension/Brakes/Handling 21 09-02-2007 06:20 PM
Help with stripped nut on rear diff support burt_poppenga Brakes, Steering & Suspension 5 08-24-2004 12:59 AM
Whiteline rear diff support (KSB751) - help! teiva-boy Transmission (AT/MT) & Driveline 7 12-29-2002 07:14 PM
