Old 10-25-2006, 11:13 PM   #1
NewSTI
Member#: 104420
05 GarageTuningSTI
BLK/Gold [email protected]
Default Which windsheild fluid ?
i'm planning to use WW fluid for my coolingmist just because it's cheaper and easier.. but i went to Kregan and AutoZone, most of the WW fluid dont have the formula on the bottle, so i have no idea what's in there...
So is there a certain brand that i can use that's been tested and i can find in Kregan or Autozone ??? they have blue, pink, green all different ones...
with pictures would be great, thankx alot.
NewSTI is offline   Reply With Quote
Old 10-25-2006, 11:17 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
I ran the cheap blue -20 stuff for a while. I think you want the cheapest stuff possible
methanol is poisonous so there should be warning labels on the bottle.
jays05 is offline   Reply With Quote
Old 10-25-2006, 11:42 PM   #3
living4surf
Member#: 85216
i wouldnt use windshield washer it maybe mostly meth but what is the rest of it and i wouldnt put things i didnt know what they were in my motor
living4surf is offline   Reply With Quote
Old 10-25-2006, 11:44 PM   #4
oldhat
Member#: 113036
SuperTech -20 at WalMart.
oldhat is offline   Reply With Quote
Old 10-25-2006, 11:53 PM   #5
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
You can buy ALKY for 9.99 and distilled water for a buck........ Unless your really hard up for cash, i would just put something in your car that you know is good.
JMK508 is offline   Reply With Quote
Old 10-26-2006, 12:18 AM   #6
NewSTI
Member#: 104420
05 GarageTuningSTI
i figured that if alky is $10, mix with 50/50 , that's like 4-5 times more than windshield fluid...
Old 10-26-2006, 12:18 AM   #7
NewSTI
Member#: 104420
05 GarageTuningSTI
what color is your fluid ??? blue ?
Old 10-26-2006, 07:16 AM   #8
jays05
Member#: 78165
05 STI 35r + e85
Old 10-26-2006, 02:37 PM   #9
smoSTI
Member#: 99962
2005 WRB STi
'88 Porsche 944
Why not just use distilled water? Its like 99cents a gallon.
smoSTI is offline   Reply With Quote
Old 10-26-2006, 02:42 PM   #10
wrx_gtp
Member#: 23831
2006 WRX
SGM
I let my washer fluid age in a titanium tank for 8 months in a temperature controlled cellar to allow the free radicals and oxidation molecules to reach their proper half life thresholds. That way the net weight wetbulb ratio is reduced my 40%. The same technique is done with all my fluids. Overall your car will have a 15% curb weight savings.
Oh, sorry... this method will only work for JDM type RA, spec C group N cars built on a Monday of every other leap year.
wrx_gtp is offline   Reply With Quote
Old 10-26-2006, 07:09 PM   #11
FastSubaru8
Member#: 115518
04 WRB WRX
Holla Acha Boy!!!
damn that counts me out
FastSubaru8 is offline   Reply With Quote
Old 10-27-2006, 11:42 PM   #12
living4surf
Member#: 85216
i can get meth for $5 gallon and at a 50/50 mix it is $3.00 gallon if that so wouldnt use WW fluid it just doesn't seem worth it for the little bit of savings
Old 10-27-2006, 11:44 PM   #13
oldhat
Member#: 113036
This is the first legitimately funny post I've read on NASIOC.
Old 10-28-2006, 01:19 AM   #14
NewSTI
Member#: 104420
05 GarageTuningSTI
finally i found WW that's mixed with only alcohol and water.. 1.2 pre gal
Old 10-30-2006, 12:25 AM   #15
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
So what brand is it? I considered running WWF, but I have a local source of race meth for about $2.50 a gallon. I buy distilled water by the case at Walmart for something like $0.50 a gallon.
The only reason I would doubt running WWF is that it may contain detergent, which I prefer not to inject into my cylinders. I do't want to wash down my bores. While this is probably not a huge problem, you never really know, especially when you are running something that you have NO CLUE what is actually in the container.....
bcblues is offline   Reply With Quote
Old 10-30-2006, 01:08 AM   #16
NewSTI
Member#: 104420
05 GarageTuningSTI
it's brand call " Peak" that i found in Pep boy ONLY...my friend is running th same wwf in his evo 9 , and some WRXs from GarageTuning are doing the same
Old 10-31-2006, 02:18 AM   #17
oldhat
Member#: 113036
Does anyone know the concentration of alcohol in Peak? It's the +32 stuff, so there can't be that high of a concentration.
Old 10-31-2006, 02:20 AM   #18
oldhat
Member#: 113036
By the way, there's a guy in Downey who sells straight meth.
Socal Performance
9723 Washburn Road
Downey, CA 90241
(562) 862-9122
Old 11-03-2006, 02:27 PM   #19
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
I really hate to dispute you findings, but I believe you will get incomplete ionization without a pink pig on both side windows. Sorry, but check the books.
drivin blind is offline   Reply With Quote
Old 11-03-2006, 03:13 PM   #20
bcblues
Member#: 17256
04 STi
drivin blind: I think Rally Pig needs to steer clear of alchy.
Old 11-07-2006, 10:36 AM   #21
gtx510
Member#: 66118
name someone in Downey that doesn't sell meth...
Deuterium, or "heavy water", is best
just don't use the stuff with soap in it...
gtx510 is offline   Reply With Quote
Windsheild Fluid doesn't squirt? |los| Service & Maintenance 14 01-21-2006 09:02 AM
Which Brake Fluid?? YonkerzImpreza Brakes, Steering & Suspension 8 05-13-2003 01:04 PM
('93-'01) Which Transmission Fluid to use? 2yLiTe Impreza Forum 6 04-29-2001 12:04 AM
Which Brake Fluid to Use? silverSurfer Brakes, Steering & Suspension 21 02-03-2001 12:27 AM
Which Brake Fluid? Why? Soboy Technical Forum Archive 3 07-26-2000 05:26 PM
